Waikiki Boy Samba Member
Posted: Wed Dec 10, 2008 9:54 pm Post subject: Any info on installing new floor on 71 camper? |
| I have a 71 camper and I want to install a new floor. The old floor was full of rot. I dont know how thick the sub base of the floor should be or any other details. please help |
Lionhart94010 Samba Member
Joined: January 04, 2005 Posts: 1418 Location: SF Bay Area / Silicon Valley / So Cal
Posted: Thu Dec 11, 2008 12:20 am Post subject: |
Using the And’s to narrow the search = Floor AND Camper AND 71 AND Wood
You get:
From abuspilot
My OG flooring (lino and 3 ply subfloor) measures 5/16 of an inch. Keep in mind it has probably absorbed moisture over time and is a little thicker than factory specs
Yes, the flooring goes under all interior peices.
The flooring is not glued, if I remember correctly there are some screws that hold the floor down. When the table is set up the leg has a catch in the floor with 3 screws in it, measuring about 5/8 to 3/4 of an inch. They do go through the cargo at least in my bus. One other spot I am thinking of is the aluminum retainer at the cargo doors. I am pretty sure the screws went through the floor there as well (5-7 screws I think?). Lastly, can't remember this one for sure but there is a metal strip to wrap the bottom edge of the drivers side long wood panel. Part of it either screws into the lino/wood flooring or it screws into the cargo floor under the lino/wood flooring. Guys??
http://www.thesamba.com/vw/forum/viewtopic.php?t=101863&highlight=floor+camper++wood
An other post found by search above with good info :0)
http://www.thesamba.com/vw/forum/viewtopic.php?t=49736&highlight=floor+camper++wood _________________ Current VWs 71 T2 Westy SO-72/6(Miami), 71 Crew Cab, 2015 GSW TDI
Other owned VW’s 59, 68 1500s, 69 & 71 Bug’s; 72 & 73 S-Bug’s; 67 Westy, 67 Deluxe, Other 71 DC, 72 KG GT that now lives in Australia, 12 JSW TDI, 2015 GSW TDI, 2023 Tiguan
VW technical information sights
thesamba - www.ratwell.com - www.shoptalkforums.com/ - www.vw-resource.com - http://www.type2.com/
http://bobhooversblog.blogspot.com/ - www.aircooled.net/gnrlsite/resource/articles.htm |
theizzardking Samba Member
Posted: Thu Dec 11, 2008 10:39 am Post subject: |
i own a '71 westie and didn't even bother worrying about the floor height when i installed the pergo into my bus every thing fit perfectly and teh height was never an issue, i think as long as you don;t go to crazy with it ti should be fine, just remembber to end the flooring at the front of the westie bed in back i ran it completely under teh jump seat and the sink area and used a skill saw to cut out ports for the mounts of each jump seat and sink.
http://www.thesamba.com/vw/forum/viewtopic.php?t=304065&highlight=wanderer _________________ "Democracy is two wolves and a lamb voting on what to have for lunch.
Liberty is a well-armed lamb contesting the vote." - Benjamin Franklin
'71 westie "the wanderer" |
busmania Samba Member
Posted: Thu Dec 11, 2008 10:53 am Post subject: |
| hey izzardking, most of the pics in your thread dont come up anymore because they are in photobucket and have been deleted. ANy chance of updating them? I would also like to see the floor install as I will be doing this in the future. Thanks. |
baumer99 Samba Member
Joined: September 16, 2008 Posts: 61 Location: Victoria, BC
Posted: Thu Dec 11, 2008 12:46 pm Post subject: |
I have one suggestion, go with marine grade when installing a bus floor. I am new to samba forum posts, but always refer here first before I do anything. I have lots of photos, but unfortunately have not posted them yet. I hope to soon.
When I replaced my floor, I completly stripped the riveria cabinets, seats and flooring (the awful plywood and heavy fibreboard), ground out all rust and coated with undercoating for future rust protection. The floor was quite rusty due to leaky window seals. I also installed a layer of ashphat sound deadener.
When I reinstalled the floor, I put a (5/8"?) marine grade plywood subfloor, it's heavier, but no knots and can withstand some moisture. It is also about three times as expensive, if you can find it. I live on the coast in a boat manufacturing area. The subfloor and all other attachments were done with stainless steel hardware (screws, bolts etc.). The subfloor does fit nicely into the recess in the floor, but does not go all the way to the sliding door, if you want to keep the floor low and level.
I then installed prefinished teak flooring across the back and also inbetween the drivers seats (not continuous though because of the heat vents). I used a wider maple flooring panel to fit the wider space between the end of the teak/subfloor and the sliding door sill.
I have to say, it's been over two years and the flooring is still solid and looks great. The only riveria part I reused was the pull out seat. I also installed custom maple cabinetry, tables, new door and kick panels, seats, but that's a different post.
One thing I did notice that was not expected, was the overall weight of the van was about the same, but the majority was redistributed to the floor with the heavier subfloor and teak flooring and lighter maple cabinets. Believe it or not the handling was improved with the shift in weight, a nice benefit.
towd Samba Member
Posted: Thu Dec 11, 2008 1:15 pm Post subject: |
| Is there a reason, to not run the plywood under the bed ? |
Posted: Thu Dec 11, 2008 1:23 pm Post subject: |
| towd wrote: |
that standard size plywood is fine under the bed but with the extra height of the pergo the bed won't lay flat on the steel bit over the engine compartment along with height probs with the other amenities in that area.... _________________ "Democracy is two wolves and a lamb voting on what to have for lunch.
towd Samba Member
Posted: Thu Dec 11, 2008 3:11 pm Post subject: |
I'm cutting my plywood now or just did, 4'x5'.
the interior I have with this Bus,, I think is a mix of west and Rivi and may end up only using the bed which the frame is welded angle iron to make the hinging part.
by have wood under the bed, it seem mounting anything would be easier, plus less holes in the steel floor ( leaks = rust )
for plywood, I'm using 3/4" MDO often used as cement forms or sign board .. It's very dense plywood and will hold screws quite well... maybe a bit on the heavy side, but this camper stuff has press board parts. Which are going away |
peaceful warrior Samba Member
Joined: January 22, 2005 Posts: 5271 Location: Taoswest, USA
Posted: Thu Dec 11, 2008 3:12 pm Post subject: |
This a good thread also. I put measurements and photos of the subfloor in the thread.
http://www.thesamba.com/vw/forum/viewtopic.php?t=304597&highlight= _________________ "Two things are infinite: The universe and human stupidity; and I'm not sure about the universe." Albert Einstein
"Notchboy" says "Man up!"
"Tram" says " My bus is bigger than your bus."
66 13W Deluxe, 68 Westfalia, 87 Syncro.
TOOB Member #15
Brian |
natep73 Samba Member
Joined: November 02, 2008 Posts: 86 Location: Milwaukie, Oregon
Posted: Sun Apr 19, 2009 6:17 pm Post subject: front floor |
baumer,
did you put the flooring in the front as well, I can kind of see it in one of the pics, do you have any pics of the front floor?
thanks _________________ 69 Bug (died)
73 Superbeetle (sold)
73 Thing (sold)
80 Vanagon weekender(sold)
01 Eurovan MV (sold)
01 Eurovan GLS (sold)
03 Eurovan Weekender
03 New Beetle Convertible
73 Riviera (sold)
74 Thing
2021 ID. 4 |
hopeod Samba Member
Joined: October 20, 2020 Posts: 8 Location: Newfoundland,Canada
Posted: Sat Mar 23, 2024 1:33 pm Post subject: |
| baumer99 wrote: |
One thing I did notice that was not expected, was the overall weight of the van was about the same, but the majority was redistributed to the floor with the heavier subfloor and teak flooring and lighter maple cabinets. Believe it or not the handling was improved with the shift in weight, a nice benefit. |
Wow! I see you have posted a lot on here and have well documented many things about your bus. Any chance you made plans for this furniture layout? I need to make new stuff for my bus- i do have the old for templates but this is awesome/ a little different than stock _________________ A jack of all trades is a master of none, but better to know a lot about many things, than all of just one! |
