rear shock bolts
piruvan
piruvan is offline
PostPosted: Mon Oct 26, 2009 4:08 pm    Post subject: rear shock bolts Reply with quote
First time replacing my rear shocks with some new Bilstein HDs. Looks easy and straightforward but the inside upper nut looks kinda hard to get at. I mean the space between the upper shock mounting tab and the bodywork (engine compartment wall?) seems really tight. Like my wrench is too fat to get in there and hold the nut.
Any rear shock R&R tips re: this and in general?
'89 Vanagon GL "Whitestar" Wolfsburg edition. 4-speed, 2.1L
'06 Accord EX-L 5-speed
insyncro
Banned
insyncro is offline
PostPosted: Mon Oct 26, 2009 6:26 pm    Post subject: Reply with quote
The nut is tacked inplace.
Just pull the bolt
dylan
iiigoiii
iiigoiii is offline
PostPosted: Tue Oct 27, 2009 2:30 pm    Post subject: Reply with quote
i'm also going to do this shortly...i'd also like to hear any other tips that anyone has on doing the rear shocks.
i seem to remember someone recommending spraying all the threads in question with a penetrant several days before starting the job, and repeating a few times...true?
1984 Westfalia Wolfsburg Ed. w/ Subaru EJ22 power
DLJ
DLJ is offline
PostPosted: Tue Oct 27, 2009 2:37 pm    Post subject: rear shocks Reply with quote
Its easier than you think. Just remove upper bolt, nut is tacked to body.
