Fitting 58-64 brakes on a split?
johan_l
johan_l is offline
PostPosted: Sat Oct 24, 2009 1:44 am    Post subject: Fitting 58-64 brakes on a split? Reply with quote
Is the task of fitting later rear brakes to a split as easy as on a late oval?
Which e-brake cables work the best. My early 51 split has the lever-dampers. Does it matter, or is it just to exchange left/right if cable is to short? Will the cable fit?
Is it better to stick to the split, which parts are then interchangable with later (and more easy to find) ovals? Or cheap and readily available...
I'd tried to read some posts and found out;
shoes - not
linings - yes?
cylinder - 2-bolt will fit?
drums - same as oval?
Johan, Sweden
1960 Karmann-Ghia coupé
1957 Oval window
Bastard Split window <-- Translate
