Sigeats Samba Member
Joined: November 10, 2008 Posts: 161 Location: San Diego
Posted: Tue Oct 27, 2009 5:28 pm Post subject: Slider window thing |
Wondering if anyone knows a place to get the little plastic thing that goes on the ends of the upper slider window track. I'm missing three of the four, and because both are missing from my passenger side the window sits to low to lock in the little groves on the inside. If these parts are long gone, does anyone know of a way to fix the window?
_________________ '84 Westfalia |
spitsnrovers Samba Member
Joined: December 17, 2005 Posts: 940 Location: Calgary, Canada
Posted: Tue Oct 27, 2009 6:20 pm Post subject: |
I made my own out of black plastic sheet, just thicker than the groove in the aluminum slider. Cut it down to length, leaving a slight raised piece at the outer end, and milled a slot.
Having a small milling machine does make it easier, but I imagine the same thing could be done with a hacksaw and files. _________________ '88 VW Westfalia
'75 Triumph Spitfire 1500 |
Posted: Wed Oct 28, 2009 9:14 am Post subject: |
Thanks . . . looks like I'll be making my own. _________________ '84 Westfalia |
Posted: Wed Oct 28, 2009 5:15 pm Post subject: |
Hey sigeats, check out the Gallery photos. Just posted the drawings I did for my home made slider glides. good luck. _________________ '88 VW Westfalia
Posted: Wed Oct 28, 2009 5:57 pm Post subject: |
Wow . . . that's rad. Cool diagram.
I ended up looking around the garage for something that would fit in the groove, and settled on 12-14 gauge wire connectors. You know those red plastic tubes you use to crimp wire together? Anyway, they fit nice and snug in the gap and slide pretty good on the rail. I just gently tapped them far enough in that you could no longer see them. Now my windows are the correct height and lock like they should.
Thanks for all your help! _________________ '84 Westfalia |
solarguy Samba Member
Joined: February 02, 2012 Posts: 85 Location: las vegas nv usa
TequilaSunSet Samba Member
Joined: May 30, 2012 Posts: 2109 Location: Philippines
Posted: Tue Nov 12, 2013 7:52 am Post subject: |
It's awesome that you have them... you spamming multiple old threads, not so much. _________________ Don't harsh my mellow...
1985 Hightower Vanagon 1.8T- Gone
1972 Panel Bus- Gone
1967 Bug- Gone
1964 Euro Sunroof Bug- Gone
1969/72/63 Sunroof Bug- Gone
1975 Brazilian Bug in the Philippines 🇵🇭- New to me |
