Mberglo Samba Member
Joined: January 13, 2020 Posts: 387 Location: Huntsville, AL
Posted: Thu Jan 28, 2021 1:40 pm Post subject: How much room behind glovebox |
| I currently have my dash out and am curious about the distance between glovebox and the nose sheetmetal. I need to find a place to mount a small bluetooth amplifier, and if I have 1.5inches available, mounting behind (in front) of the glovebox would be ideal. |
SGKent  Samba Member
Joined: October 30, 2007 Posts: 42958 Location: at the beach in Northern Wokistan
Posted: Thu Jan 28, 2021 2:33 pm Post subject: Re: How much room behind glovebox |
I can't tell you exactly what it is, but I mounted my amp on the airbox tube. You have to be careful because some areas are double wall and some are single. If you choose a single area you will put the screw right thru the nose.
here are some photos from the gallery what it looks like with the nose skin off.
Canned Water - the new California approved parts cleaner (except in a drought in which case rub it with sand).
George Carlin:
Skills@EuroCarsPlus:
"never time to do it right but always time to do it twice"
Posted: Thu Jan 28, 2021 3:18 pm Post subject: Re: How much room behind glovebox |
| Yes, that would suck. |
pioneer1 Samba Member
Joined: February 11, 2008 Posts: 2074 Location: Ontario Canada
Posted: Thu Jan 28, 2021 4:22 pm Post subject: Re: How much room behind glovebox |
How about above the radio where the original speaker was? _________________ "Always waiting for tomorrow ruined everything"
'85 Porsche 911 Targa
'76 Westfalia project |
Posted: Thu Jan 28, 2021 5:30 pm Post subject: Re: How much room behind glovebox |
| That might work. Attached to the metal dash cover? |
SGKent  Samba Member
Posted: Thu Jan 28, 2021 6:00 pm Post subject: Re: How much room behind glovebox |
The center air box has a tube on each side that runs out to the doors. That is a perfect place to mount something and where I mounted an amp, and an extra fuse box. The fuse box, and a small VDO gauge light trimmer are on the left side and the speaker amp on the right under the glove box.
You can mount on the cabin side of this tube. The screws will stick into the tube and not bother anything like my fuse box and the light trimmer.
George Carlin:
"never time to do it right but always time to do it twice"  |
mikedjames Samba Member
Joined: July 02, 2012 Posts: 3451 Location: Hamble, Hampshire, UK
Posted: Fri Jan 29, 2021 2:17 am Post subject: Re: How much room behind glovebox |
There is a fair amount of space in a wedge shaped volume above the glove box and behind the plastic hoses going up to the dash. You might have to make a bracket to suspend it in mid-air, and the installation might get in the way of putting in the glovebox liner. _________________ Ancient vehicles and vessels
Abscate Samba Member
Joined: October 05, 2014 Posts: 24466 Location: NYC/Upstate/ROW
Posted: Fri Jan 29, 2021 4:01 am Post subject: Re: How much room behind glovebox |
There is tons of room behind the glove box. Itβs in front of the glove box that is more difficult  _________________ πΊπΈ πΊπΈ πΊπΈ πΊπΈ πΊπΈ πΊπΈ πΊπΈ π π π |
