C/V boot kit?
richtrek
richtrek is offline
PostPosted: Sun Nov 08, 2009 9:08 pm    Post subject: C/V boot kit? Reply with quote
My right rear boot is torn up and needs to be replaced.
Should I simply replace the boot, or do the whole kit?
Are the boots, and boot kits, the same for Bug, Thing, etc.? I found kits and boots at "Airhead" auto at a much better price than the price for the full boot kit at the Thing Shop. Any suggestions on the best place for the boot, or boot kit?
Thanks!
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Sun Nov 08, 2009 9:10 pm    Post subject: Reply with quote
Not all boots are the same. I've seen a number of the split in less than a year. I only use Lobro boots.
Thing boots are not the same as a Beetle.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
norcalmike
norcalmike is offline
PostPosted: Sun Nov 08, 2009 9:38 pm    Post subject: Reply with quote
if your going through the trouble of removing the axle and taking it apart, at least do both on that axle. it is cost effective to do one prematurely
richtrek
richtrek is offline
PostPosted: Sun Nov 08, 2009 10:08 pm    Post subject: Reply with quote
I just spoke to my brother and he said that there are boot replacements that are split the length of the boot and clamps on. He said that it is far less work than pulling the axle, etc. Is that correct? If yes, where could I pick up this type of boot?
Thanks.
Bruce
Bruce is offline
PostPosted: Sun Nov 08, 2009 10:48 pm    Post subject: Reply with quote
richtrek wrote:
....there are boot replacements that are split the length of the boot and clamps on.
Don't listen to your brother. A split boot is crap compared to a solid boot. It only takes 15-20 min to pull the axle off.
norcalmike
PostPosted: Sun Nov 08, 2009 11:29 pm    Post subject: Reply with quote
ive never seen those for IRS. they are split on swingaxle. dont be lazy. even if they make a split boot for IRS axles, skip past them and get the one piece
