ryohey Samba Member
Joined: August 08, 2007 Posts: 562 Location: Plains, PA
Posted: Wed Nov 18, 2009 3:41 pm Post subject: 69 Beetle On pan restoration project |
| I finally decided to take the plunge and start taking my bug apart to get some paint on it. So far it looks good, I have some rust up by the passenger side wheel well and some on the drivers side. I dont know if it is all the way through yet. I have never tried something like this and have very little knowledge of some things ie: bodywork. I have read and read and read all I could. If I run into issues I sure I will get good advice here and from people I know. Here are some pics of the process so far not much, but a start. http://s122.photobucket.com/albums/o278/ryohey/ |
vierfalcon Samba Member
Joined: May 11, 2007 Posts: 173 Location: Doylestown, PA
Posted: Wed Nov 18, 2009 4:22 pm Post subject: |
| Looks solid. Take your time and do one thing at a time. Remember the old "measure twice and cut once" adage. Hold onto everything even if you think the replacement will fit or work without issues. Good luck. |
jhicken Samba Member
Joined: October 24, 2003 Posts: 9479 Location: Fallbrook, CA
Posted: Thu Nov 19, 2009 11:34 am Post subject: |
You've got a great base and are way ahead of the game. What are your plans?
-jeffrey _________________ Der Kleiner Kampfwagens |
ryohey Samba Member
Posted: Sat Nov 21, 2009 1:15 pm Post subject: |
| I am just going to keep it stock for now. future plans include installing some dropped spindles with disc brakes and bumping up the engine to a 1776. Just took out some carpeting and the tarboard on passenger side. Floors look good except for a small hole in the back looks like it was put there not from rust. I found some rust on the inside fromt he fresh air box drain area and I think that the hole in the back was for water drainage for the pan. I just put up some pix.http://s122.photobucket.com/albums/o278/ryohey/ |
ryohey Samba Member
Posted: Tue Nov 24, 2009 7:10 am Post subject: rear heat ducts question |
| Im have gotten a little further with getting the interior gutted out. Im asking this question before I actually look, but can the rear heat ducts under the rear seat be taken off, is there a bolt or screw or are they welded to the body. Thanks |
Endicott jb Bondo King
Joined: February 17, 2008 Posts: 1902 Location: Havre, MT
Posted: Tue Nov 24, 2009 9:23 am Post subject: |
They are welded in but I have heard of people cutting them out and welding a sort of patch panel over them. I believe it was an issue in hotvw's that shous a pan that they cut out the heater ducts so they could mount a roll bar. _________________ Josh
OORAH!!
1965 vw beetle(Mayble)
1968 vw beetle(Caroline)
1974 VW Panel Bus
2003 Dodge 2500 5.9 Cummins(Katey)
.|_____|.
(0\_!_/0)
Don't drink and post
http://i540.photobucket.com/albums/gg353/endicott_jb/IMG_20110113_085237.jpg
When life throws you curveballs switch to boomerangs. |
ryohey Samba Member
Posted: Thu Nov 26, 2009 2:29 pm Post subject: |
Here are the pics of the pan They look really good. I am going to hit them with some rust stop by kbs. If you look you can see the 11/11/68 on the tunnel.
[/img] |
Posted: Thu Nov 26, 2009 10:44 pm Post subject: |
Dude, your passenger side pan looks like mine except the battery tray of mine is rusted out. _________________ Josh
OORAH!!
1974 VW Panel Bus
.|_____|.
(0\_!_/0)
ryohey Samba Member
Posted: Thu Mar 18, 2010 8:02 am Post subject: |
Well I got the kbs rust stop coating on yesterday and it has dried looks good. I also pulled the engine and started cleaning the engine compartment, I have some more to do there. Here are some updated pics.
Before pic engine compartment
After
I will be, hopefully, taking it to the my body guy within a month, If my wife quits spending my beetle money!!!! |
ryohey Samba Member
Posted: Fri Jul 09, 2010 4:18 pm Post subject: |
Well it has been a slow process. No painting being done this year, because as in my an earlier post Wifey spent the funds....lol. Oh well I am looking at as a blessing in disguise so I can do it right. I took the front suspension off and painted the torsion tubes and arms, getting new ball joints pressed in, new tierods, got the drop spindles and backing plates painted. I was thinking of changing the color of the car entirely, but the more I look at it Im thinking of keeping it the original diamond blue. I will post some pics tomorrow _________________ 69 bug restoration thread http://www.thesamba.com/vw/forum/viewtopic.php?t=387230&highlight= |
Jeckler Samba Member
Joined: September 27, 2005 Posts: 2718 Location: Mesa, AZ
Posted: Fri Jul 09, 2010 5:14 pm Post subject: |
For curiosity's sake, does your car have a VIN plate in the lower left corner of the windshield and/or on the driver's B pillar, under the latch? The latter will include the build date punched out. _________________ Andy
'63 Bug rebuild here.
Did you know that sellers can't charge a fee to accept PayPal?
| bill may wrote: |
| I am the crabby old guy. |
Knowledge is knowing that a tomato is a fruit.
Wisdom is knowing not to put it in fruit salad. |
ryohey Samba Member
ryohey Samba Member
Posted: Tue Aug 03, 2010 10:36 am Post subject: |
just an update. finally got my arms back with the new ball joints, backing plates, arms, torsion tube and dropped spindles coated with kbs rust stop also coated the frame head. let me know what ya think. Just taking my time and trying to do it right.
ryohey Samba Member
Posted: Sat Sep 18, 2010 11:38 am Post subject: |
Making some progress. Installed the beam, torsion arms with the new ball joints. got the passenger drop spindle on new long tie rod assembly and new dampener everything is going together nice. also got the new wheel cylinders and brake shoes on the backing plates here are some pics
69vduber Samba Member
Joined: April 23, 2008 Posts: 442 Location: Spring Texas
Posted: Thu Oct 21, 2010 7:45 pm Post subject: |
I like your build tread .. I too am restoring a 69. I need to lift the body off and replace pans . Other than paint I'm basicly at the same place as you .. I have drop spindles and disk brakes to install. I also gutted the wiring but carfully marked everything .. The original loom was not in bad shape or hacked. Good job.  |
ryohey Samba Member
Posted: Tue Dec 07, 2010 1:30 pm Post subject: |
Well winter is upon us. Never got it to the body guy this year. Thats fine gave me some time to do some other things. Reindexed the rear one inner notch. Now I am working on the underneath wire brushing and going to hit it with KBS rust sealer. Here are a few pics.
will update when this is done _________________ 69 bug restoration thread http://www.thesamba.com/vw/forum/viewtopic.php?t=387230&highlight= |
ryohey Samba Member
Posted: Tue Jan 18, 2011 12:25 pm Post subject: |
bottom of pan completed with kbs coatings turned out nice.
I have the front done other that reinstalling MC and hard brake lines. Im turning my attention to the rear end underneath. going to be dropping the transaxle and getting to the area above it. _________________ 69 bug restoration thread http://www.thesamba.com/vw/forum/viewtopic.php?t=387230&highlight= |
ryohey Samba Member
vwman10 Samba Member
Joined: December 22, 2010 Posts: 127 Location: Northbrook, IL
Posted: Thu Mar 17, 2011 11:42 am Post subject: KBS RUST STOP |
Did you use the whole " KBS Rust Stop System" or just the paint? I have a few areas on my 74 Vert that looks like your pans. Can I bypass the use of the KBS etching and just give the area a good wire wheel cleaning and just paint it? Do I need the KBS primer also. Thanks. _________________ VW Owner Beginner
Present Car: 74 S.B Convert. 86K Miles
Last VW Owned & First Car : 1962 |
ryohey Samba Member
Posted: Thu Mar 17, 2011 12:12 pm Post subject: |
I use thed etch, but not the metal ready. I just wired wheeled the junk off, cleaned as good as I could with simple green, etched it and painted the kbs on. seems like it is holding well. _________________ 69 bug restoration thread http://www.thesamba.com/vw/forum/viewtopic.php?t=387230&highlight= |
