mikes69baja Samba Member
Posted: Wed Nov 18, 2009 8:29 pm Post subject: Type-1 TO Type-2 Coupler |
Is anyone using the Type-1 TO Type-2 Coupler made by EMPI to connect a 3rib tranny to a stock shift rod. I believe the connector allows you keep the shift rod in the tunnel without using a 10deg kit. Im just wondering if it works. |
Ed Carp Samba Member
Joined: July 22, 2008 Posts: 213 Location: sonora california
Posted: Wed Nov 18, 2009 8:39 pm Post subject: |
i have that set up. it works just fine. at first i couldn't get it to hookup. angle seemed wrong and was just a hair to short. i pulled the shift tube and found it was quite bent. so i stuck it in a press and simply bent it back as straight as i could. hooked it up and shifts fine. only used it for a weekend at pismo so far. and you know if anything is gonna break it'll do it out in the dunes. but i do plan on putting the shifter on top of the tunnel when i can afford. _________________ 1969 money pit, i mean baja.
chenoworth look alike sand rail
i believe bugpack rail? |
dirtkeeper Samba Member
Joined: February 19, 2008 Posts: 3252 Location: Left of everywhere
Posted: Wed Nov 18, 2009 8:57 pm Post subject: |
Ed Carp wrote: |
i have that set up. it works just fine. at first i couldn't get it to hookup. angle seemed wrong and was just a hair to short. i pulled the shift tube and found it was quite bent. so i stuck it in a press and simply bent it back as straight as i could. hooked it up and shifts fine. only used it for a weekend at pismo so far. and you know if anything is gonna break it'll do it out in the dunes. but i do plan on putting the shifter on top of the tunnel when i can afford. |
I think the stock shift rod has a bend in it
and if it works fine why are you considering putting it on top of the tunnel? |
Posted: Wed Nov 18, 2009 9:36 pm Post subject: |
I think all the shift rods have a bend in them. Good to know it works. I have not been able to make up my mind on how im going to mount my new 002 tranny. finally decided on not using the 10 deg kit. |
thesatelliteguy Samba Member
Joined: January 06, 2007 Posts: 1515 Location: Santa Rosa CA
Posted: Wed Nov 18, 2009 9:57 pm Post subject: |
not trying to steal your thread, but what other ways are there to mount the 002 trans? if you use a 10 degree kit, the coulper has to be out of the tunnel? _________________ Toyotas are so bumpy it makes me sick, literally.
My build Page http://www.thesamba.com/vw/forum/viewtopic.php?t=383878 |
Posted: Wed Nov 18, 2009 10:30 pm Post subject: |
well the two main ways are to use the 10 deg kit which mounts the trans on an angle to put the nose cone in the tunnel. if u use the bus to bug mount the shift rod sits on top of the tunnel. unless u use the empi adaptor. The 10 deg kit seems like a rip off to me pacific customs wants $165 for it. Bus to bug is like $35.00 |
Gary Massin-Ball Samba Member
Posted: Fri Dec 04, 2009 2:32 pm Post subject: |
I have the bug to bus in my rail with the aluminum adapter. It was short too so I took the welds off the end of the tube and was able to slide the sleave out 1/2" I needed and welded it back up.
I was skeptical about the strength and accuracy of the adapter but it works fine and I really can't tell the differene from the bug trans set up.
I did install a new shift ball in the linkage in the nose cone and boxed the carrier to make it stiffer. I also because the main bearing had pounded into the nose cone about .040 to .060" I had the nose cone milled down and installed a beef plate between the nose cone and housing. |
