resurrection of '73
twomonkeysayoyo
twomonkeysayoyo is offline
PostPosted: Tue Dec 01, 2009 3:15 pm    Post subject: resurrection of '73 Reply with quote
Ok, so I'm bringing a '73 back to life. Pics Here:
http://picasaweb.google.com/twomonkeysayoyo/VolkswagenBug#
When I moved it I think I busted a brake line in the rear so I will have to replace all of those, but I'm trying to get a list of things I need to bring with me to get it running well enough to drive 60 miles to a different garage and am looking for suggestions. The garage it's in now is in a very rural area with few resources.
So far:
things I need before I get there
  1. Chirco tune-up kit
  2. Chirco Emergency Road Side Kit
  3. Rear Cage (shock absorber mount)
  4. rear cage mounts (shock absorber)
  5. exhaust system
Things I can get when I get thar from yon Advance Autoparts
  1. oil
  2. tranny fluid
  3. battery
  4. brake fluid
  5. brake lines
thesatelliteguy
thesatelliteguy is offline
PostPosted: Tue Dec 01, 2009 8:48 pm    Post subject: Reply with quote
why not just tow it the 60 miles to the other garage?
Toyotas are so bumpy it makes me sick, literally.
My build Page http://www.thesamba.com/vw/forum/viewtopic.php?t=383878
twomonkeysayoyo
PostPosted: Wed Dec 02, 2009 7:32 am    Post subject: Reply with quote
and then?
Whether I do this where it is (Hampton SC) or 60 miles from where it is (Aiken SC) makes no difference in my mind but 60 miles of back-road driving is a whole lot more sensible than 220 miles of I-20 for the first run. What I'm saying is the 60 miles is arbitrary; a goal for the few days I have after Christmas to get it running. The ultimate goal is to get it to Midway on the Alabama/GA border from South on the GA/SC border before the first of the year. Towing will probably be involved, but the less of it the better and the closer to I-20 I am the more likely I can get a friend to do it for me instead of paying out dear, dear fixit funds.
baja72
baja72 is offline
PostPosted: Wed Dec 02, 2009 10:39 am    Post subject: Reply with quote
If you want to make one trip let me know. I have a trailer we can put it on and bring it home. Give me a call or PM me. Bruce
I suffer from a serious disorder : Volkswagenitis
vdub411
vdub411 is offline
PostPosted: Wed Dec 02, 2009 4:51 pm    Post subject: Reply with quote
Don't forget plenty of WD40 and starting fluid. Cool
ZARJDR
ZARJDR is offline
PostPosted: Wed Dec 02, 2009 6:08 pm    Post subject: Reply with quote
after sitting that long one of the first things I would do is pull both ends of the fuel line and blow air through it. If you get good air flow, I would follow that with some brake cleaner or carb cleaner. Lacquer thinner or mineral spirits would also do in a pinch, then blow the line down again. A quick once over on the carb, filter etc is a no brainer.
2006 RAM 1500 HEMI 4X4 92 LT250
06 Raptor DP1776 Sandrail
02 HONDA 400EX
03 YAMAHA WR450F 74 BAJA
twomonkeysayoyo
PostPosted: Thu Dec 03, 2009 7:00 am    Post subject: Reply with quote
Ok, one of the things I forgot to mention I was gonna do was pull the gas tank and see if there's any buildup. You think this method might prevent me from having to do that?
