Axel Andersson Samba Member
Joined: June 03, 2011 Posts: 132 Location: Sweden - Europe
Posted: Wed Jan 30, 2013 5:43 am Post subject: Gear shift housing - early cast version |
Up to what year did they use the cast gear shift housing? |
8287111 Samba Member
Joined: January 02, 2010 Posts: 141 Location: Finland
Posted: Thu Jan 31, 2013 2:14 am Post subject: |
They are always cast,if you mean cast iron,-43(or late-42)to-45/46. |
Posted: Thu Jan 31, 2013 7:40 am Post subject: |
This is the type I would like more info on. |
RareAir Samba Member
Joined: May 11, 2002 Posts: 14577 Location: 18 miles North of the border
kdfkid Samba Member
Joined: April 20, 2004 Posts: 396 Location: Hessisch Oldendorf Germany
Posted: Thu Jan 31, 2013 8:48 am Post subject: Shifter housing |
Hello guys,
i think erverone knows more stuff
The shifter here shown is the orginal one from the Berlin Rome car and it was casted. This is NO cheap aftermarket part.
These shifters were first used ob the 38 and W30 cars and eveb used untill early 1940. After this they had the pressed metell ones !
Bye Christian |
peter schepens Samba Member
Joined: April 17, 2003 Posts: 1032 Location: belgium Caesars camp
Posted: Thu Jan 31, 2013 11:06 am Post subject: |
yepp, That is the real deal and from 1939....read it like OLD. Only seen on 38/06 and Mathé's Berlin Rome car where this picture was shot in.
Cheers. _________________ Zelensis, glassfibre body made in Belgium , disigned and built on a VW platform About 25 body's built.
Hebmuller info wanted for http://www.hebmueller-registry.com/home.html |
Posted: Thu Jan 31, 2013 11:20 am Post subject: |
Here is the Protype replica of the 60K10, is this the same type of housing? |
bally Samba Member
Joined: April 29, 2006 Posts: 1199 Location: Melbourne, Australia
Posted: Thu Jan 31, 2013 12:02 pm Post subject: |
I wouldn't be surprised if it is the same type - the floorpan is original so the gear lever could well have been there the whole time.
Dave |
usariemen Samba Member
Joined: August 28, 2004 Posts: 1745 Location: Germany
Posted: Thu Jan 31, 2013 3:19 pm Post subject: |
That´s not the same. _________________ Master of my domain! |
splitjunkie Samba Member
Posted: Thu Jan 31, 2013 4:38 pm Post subject: |
usariemen wrote: |
That´s not the same. |
Not even close. _________________ Chris
Fishynos72 Samba Member
Posted: Mon Nov 11, 2019 10:49 pm Post subject: Re: Gear shift housing - early cast version |
*zombie thread warning*
Just curious if anyone had anymore information about these shifter bases?
Thought perhaps now the 39 number 6 has been restored some investigating may have happened.
I'll check my "first beetle" book tonight to confirm if it has one of these fitted or not
Edit
It appears to be cast alloy with a lovely coat of paint. I'm guessing as it sits higher the shifter stick itself would be different to suit.
Im curious if these are from a kubel of Schwimmer? _________________ Collector of all things Volkswagen, Hazet and Matra.
1957 old speed fun
https://youtu.be/8A7JyvR-eiA?si=q7Rxfxrspk6zCd6p
2005 Caddy panel van chaos
https://youtube.com/playlist?list=PL2xEOS4ROOAQkVmo-vvYzYY-rGMv3ZkHL&si=cnzqpamsnBr5HlMH |
