BallJoint notches don't line up with slot
garbug
garbug is offline
PostPosted: Thu Jan 14, 2010 10:23 pm    Post subject: BallJoint notches don't line up with slot Reply with quote
The notches on the upper and lower balljoints I just installed where way off from the actual slot of the balljoint. So I installed them with the slot as best as I could to 90 degrees from the torsion leaves or beam. I used balljoints for lowered front ends and I have avis adjusters welded in for a full drop. Just checking to make sure I don't need to buy 4 new balljoints.
garbug
garbug is offline
PostPosted: Thu Jan 14, 2010 10:25 pm    Post subject: Reply with quote
The uppers in the pics were not as bad as the Lowers... The lower BJ notches were way off. I figured this was wrong because if you loned up the notches you could still be 180 degrees out. how would you know which way the offset should be.
Max T.
Max T. is offline
PostPosted: Fri Jan 15, 2010 8:22 am    Post subject: Reply with quote
If they are not lined up correctly they will bind. Press them out and realign.
garbug
garbug is offline
PostPosted: Fri Jan 15, 2010 11:30 am    Post subject: Reply with quote
I thought i read some ball joints have the notches in teh wrong spot. sould the notches be perfectly centered with the ball joint slot.
