a new prospect
Benjamin Arron
Benjamin Arron is offline
PostPosted: Fri Jan 22, 2010 9:37 am    Post subject: a new prospect Reply with quote
Newbie here again, i have a chance to pick up a 81 van with a sunroof(factory, metal) cheep(500$). 103k on the odo. usual surface rust , light to medium(in drivers foot well). One 1/4 inch hole under rear window.The body is straight with exception of a dent the size of a baseball on drivers side rear wheel arch. the van has sat for four years with a full tank of gas. P.O states the clutch died on a trip. He had it towed home bought a sachs clutch,a creeper , ramps, a service manuel and lost interest.(all go w/van) My thoughts were to get this running ( i will need help from the board later), and eventually turn into a camper. Or, use it as a donor vehicle for a future camper . Or , run and hide,again . thanks for your input Ben.
P.S. the last camper i passed up, is back on C.L. for $5800 from $1700, i could have had it for,still complete with the same dents &238k. Its crazy out here , bidding wars for vans .A few guys buying up the best ones(easiest to fix )and turning huge profits.I'm green with envy. This is ment to be a hobby
NorBullitt
NorBullitt is offline
PostPosted: Fri Jan 22, 2010 11:53 am    Post subject: Reply with quote
Replacing the clutch isnt a huge undertaking if you got a bit of spare time and maybe a friend to help with the removal and refitting of the transmission. And if you're handy with a welder, the rust should be doable as well (I personally hate bodywork involving rust removal). The price of the car sounds cheap tho, and I love those sunroofs. This might be the car for you Smile If the state of it is worse than you thought you could always sell it again, maybe even without loosing money.....
1967 Bug (euro)
RC82
RC82 is offline
PostPosted: Fri Jan 22, 2010 12:16 pm    Post subject: Re: a new prospect Reply with quote
It will become more than that real soon. For me, it was a obsession after the first trip.
PS I got my 82 air cooled for $1800.00 with everything working.
Benjamin Arron
PostPosted: Fri Jan 22, 2010 10:04 pm    Post subject: Reply with quote
if it becomes a donor, what model years are inter-changeable with the body(that is are all vanagon bodies the same), and which engines will fit (easyist to install). thanks Ben
