Dellorto Drip - How the heck?
Page: 1, 2, 3, 4, 5, 6  Next
Marv [UK]
Marv [UK] is offline
PostPosted: Mon Apr 05, 2010 11:23 am    Post subject: Dellorto Drip - How the heck? Reply with quote
I've now had enough of the dell drip on my 36's
My bus has just gone in for a 2 grand resto so it will last for long enough for me to get enough cash together to have the full 20K job done in a few years time but on the way, my motor developed a missfire
Now I know the misfire is probably ignition based given the bus sat for 2 months without being turned over and it wasn't missing before so I know it's nothing too drastic to fix, but now I have the chance, I want to fix my Dell Drip that is getting ridiculous. I mean, both of them fully drain overnight and it's pissing me off.
Before anyone says anything, I can't send my carbs to Art Thraen, not because it's over $100 per carb to fix, no, but because I live on a different continent and postage either way would be over $100.
Besides, I'm capable enough to do it myself as I have a passing knowledge of carbs having rebuilt a few in my time.
The trouble is, I don't know where the 'Dell Drip' originates in the carb. I know it's a corroded lead plug in the guts somewhere, but does anyone have any photos of where it is and a 'shopping' list of what I need to fix it. I've a 1/16" NPT plug tap and steel plugs but is that enough or is it too big. How do you get the little blighters out?
Cheers
The opinion of the author as expressed does not always reflect that of the author nor does he extend any apologies or assume any liability or responsibility for its content or lack thereof or for any lack of humour of the reader of any content at all, anywhere, ever. The reader agrees to all risk by reading it and is advised that any ‘issue’ is theirs alone as they chose to read it.
nathansnathan
nathansnathan is offline
PostPosted: Mon Apr 05, 2010 11:41 am    Post subject: Reply with quote
Funny I just posted about this in the 'update' thread, kind of.
What started my problems was the drip
http://www.thesamba.com/vw/forum/viewtopic.php?t=405033&highlight=lm1
I've taken things apart about 4 times now and looked everything over. I think the problem is the needle inlet valves. The spring plunger gets cocked, the float gets bent out of adjustment, and the valve never gets closed, is how I think it goes.
I hope the berg glass ball valves will be better than the cb performance replacement inlet valve.
DarthWeber
DarthWeber is offline
PostPosted: Mon Apr 05, 2010 11:49 am    Post subject: Reply with quote
Marv, barring someone showing up here with a 'miracle' cure you could always e-mail Art (or Dave) and ask for their expertise.
Mitey62 wrote:
Swapped the Compufire for a Bosch blue and some points I had sitting around, started 1st crank. Took her out for a drive, pulls harder, more RPM, and runs smoother. I think I'll be sticking with points from now on.
RockCrusher wrote:
JB weld the case halves....that'll keep the fretting to a minimum. Laughing
Marv [UK]
PostPosted: Mon Apr 05, 2010 12:33 pm    Post subject: Reply with quote
I could but I'm wary of that sort of thing simply because I can't send them out to get them done by those guys. It's all well and good asking for something in private but something not freely given is not something I can share with others if you see what I mean.
Not that I was going to go and do a tutorial on it or anything but thats not the point
nextgen
nextgen is offline
PostPosted: Mon Apr 05, 2010 12:54 pm    Post subject: Reply with quote
Hi I have the same set of 36 since they were in my 914 and have 100k on them and one rebuild.
I don't drive the bug in the winter and when I start it, well when I get it started, ha, it runs on a few cylinders at a time, backfires especially when I let off the gas, loss of power etc.
Also it would be hell to start it.
I say Ok here we go again.
I was told by Art the carb guy to pump it the magic 15 times after the electric pump stops clicking. The car starts almost instantly.
I clean the air cleaner, pull the jets and blow them out. stick a can of Barrymans B12 or seafoam in with a full tank and in 15 mins of trying to keep it running, it all clears. Voom!!! Then on to the highway for a 30 min run at speed to get gum out completely..
I used to go nuts. Not any more, it is what it is. If you dont' run some the stuff through your accel pump and jets get some yellow waxy gook and you will notice poor accel.
Could be something else but that was only a $4.00 fix it tip.
email: [email protected]
The TYPE IV UPRIGHT CONVERSION MANUAL
BEETLE MAGNETIC DEFLECTOR SHIELDS
LETS TALK DUBS https://www.youtube.com/results?search_query=joe+cali+ghia https://letstalkdubs.libsyn.com/ep-200-joe-cali-ty...qI3xJTCzjs
Marv [UK]
PostPosted: Mon Apr 05, 2010 1:11 pm    Post subject: Reply with quote
Normally, I'd pump 3 to 4 times and it would start after a couple of seconds. After leaving it for a while, no amount of pumping will do it because I'm running a mechanical fuel pump. I have to crank it until the pump gets gas to the carbs and that can take quite a long time. I know it's the dreaded drip as the carbs have always had them.
I was hoping that someone would post a couple of pics saying "here it is" and you need a 1/x th " npt plug to fix them.
The drip is doing my head in and I don't want to hack into the carbs without knowing where the problem is.
I guess I'll have to do it the old fashioned way
nathansnathan
PostPosted: Mon Apr 05, 2010 1:32 pm    Post subject: Reply with quote
Maybe you have something different than I do.
THis, from the shoptalk forums:
The Dellorto drip comes from corrosion, and degredation of the lead plug that seperates the idle-air inlet gallery from the fuel feed to the main jet. There's two in each carb; one per barrel. When this plug leaks, raw fuel from the float bowl will drain from the main fuel feed into the idle-air passage, and down to the progression ports, and the idle-air mixture screw.
seen here: http://www.shoptalkforums.net/viewtopic.php?f=1&t=71362&view=next
modok
modok is offline
PostPosted: Mon Apr 05, 2010 4:43 pm    Post subject: Reply with quote
I've done it, but I don't have any pictures for you.
To get to the offending plug and fix it requires faith.
You have to remove the outside plug.
Then shove a screw into the hole and grab the unseen plug to pull it out.
Then you clean real thorough and glue the unseen plug back in it's proper place.
To at the very least you need to know what size screw to stick in the hole, and where to stick it, to do this deed.
I don't remember what size. The unseen plug is cup shaped though, I remember that much. That's how you can grab it.
DarthWeber
PostPosted: Mon Apr 05, 2010 4:58 pm    Post subject: Reply with quote
Glue?!?
modok
modok is offline
PostPosted: Mon Apr 05, 2010 5:09 pm    Post subject: Reply with quote
Yep. Locktite or epoxy. I used epoxy.
Unless you have a source for oversize unseen dell plugs.
I have been running all kinds of fuel parts held together with epoxy and solder and locktite for years. They hold up fine.
And I'm not the only one.
The secret to glueing things is you need a near press fit and lots of surface area. This qualifies.
DarthWeber
PostPosted: Mon Apr 05, 2010 5:16 pm    Post subject: Reply with quote
Ahh, I see!
nextgen
nextgen is offline
PostPosted: Tue Apr 06, 2010 5:55 am    Post subject: Reply with quote
Well, Modok may have the answer, but does not sound easy. I believe that is my problem. If I do not drive the car for a week I have to pump it the 15 times. After that it starts on the first turn of the key. The float bowls drain out and have to be refilled. Mine is not as bad as some people because it takes at least a week to drain. Lead seals , would be logical. They are only a press fit and I can see lead turning into a white power, forming at the contact points from corosion then breaking down and leaking.
Type 5 Joe
Banned
Type 5 Joe is offline
PostPosted: Wed Apr 07, 2010 12:04 pm    Post subject: Reply with quote
Do not put glue in this area.
You would run the risk of really screwing up your carb if you got glue in the wrong place.
I would send these out for repair to a qualified Dellorto specialist.
I can do this, or there are others who know this repair.
This passage is filled from the factory with a .187" diameter lead shot (sphere) that is swedged in place. It is difficult to get to.
I cast a special alloy of lead / antimony in a mold I have created to replace all the lead plugs when I rebuild a DRLA carburetor.
Dead soft lead is too malleable and will not set and stay under vibration, pressure, and other present operating conditions.
I do this to all my Dellorto rebuilds.... Any other way is not truly rebuilt. You would not believe the amount of crap I pull out of carb passages that have been dipped, bead blasted, and made to look "pretty".
Rolling Eyes
If you would like to contact me, just email through one of my ads on here...
I don't use the P.M. service on here.
Marv [UK]
PostPosted: Wed Apr 07, 2010 2:06 pm    Post subject: Reply with quote
Rolling Eyes
easier said than done is a qualified dellorto specialist. In this country, the repair would cost more than the carbs. They are specialised in vintage lotus and the like.
I am more than capable of doing the work, I just don't yet know what exactly I am going to do. Guess i'll have to pull the 2 lead plugs on the back and see whats in there. Won't be for a while though, my bus is at the doctors and has to be done before i get the carbs off. The resto man needs the engine in to move it about for a while Sad
Still, when I get it back, it's all good. Guess I can always fix the other pair I have even if they aren't broken. (they need throttle shafts etc)
Where did I put my slide hammer?
Type 5 Joe
Banned
PostPosted: Wed Apr 07, 2010 2:41 pm    Post subject: Reply with quote
I thought you had Dellorto UK or whatever....They will not help you?
The exchange rate is quite favorable to you U.K. guys.... Has been for a long time, and I wish it was the other way around.
The best way to learn how to do this repair is to sacrifice a crummy Dellorto, run it through the bandsaw and then the milling machine.
This will give you the exploded view you will need.... Even then you will be fishing in the dark when you repair your carb.
Its not easy, but it can be done.
I would still recomend you just send them in to be made brand new again in every possible way.
modok
modok is offline
PostPosted: Wed Apr 07, 2010 6:25 pm    Post subject: Reply with quote
You sure man? I could swear mine had little cup shaped plugs.
Shoot, now I want to pull one apart and find out.
Type 5 Joe
Banned
PostPosted: Thu Apr 08, 2010 5:49 am    Post subject: Reply with quote
Yes I'm sure... Laughing
A cup shaped plug would be extremely difficult to get oriented to go in the hole, way down deep in the abyss.
It gets installed way down in a blind hole.
A round shot shape will go right in, if you are careful.
Usually , the plug will just fall out or will come out if you hit the carb body with a dead blow hammer. They show evidence of fuel corrosion, carb cleaner corrosion, ect...
They are all due to be replaced in my opinion.
Marv [UK]
PostPosted: Thu Apr 08, 2010 11:19 am    Post subject: Reply with quote
oh there are many places to send them, but cost effective they aren't.
I'd also love to sacrifice a dead carb, but I don't got none
modok
modok is offline
PostPosted: Fri Apr 09, 2010 3:14 am    Post subject: Reply with quote
ok, I pulled one out.
SOB didn't come easy. Looks like it WAS a lead ball, bout .138" diameter (3.5mm?), or at least that's what size it is now.
Perhaps the "cup shape" I recall was what it looked like after I drilled and tapped to get the suckers out? My memory is horrible.
I maintain it is possible for you to fix your carbs because I managed it myself once, but I can't remember WTF I did exactly.
Do you want me to cut it up for a cross-section view?
74 Thing
74 Thing is offline
PostPosted: Fri Apr 09, 2010 8:44 am    Post subject: Reply with quote
Please post photos when you cut it up for a cross sectional view. Thanks.
Page 1 of 6
