Headlight Switch Illumination
schundy38
schundy38 is offline
PostPosted: Fri Apr 16, 2010 9:17 am    Post subject: Headlight Switch Illumination Reply with quote
Is the headlight switch supposed to illuminate. I know there is a small bulb and socket in the switch in my 92 cabriolet that illuminates the light switch when the ignition is turned on. When I had the instrument panel out yesterday I noticed there was a place for the bulb and bulb holder in the switch but they were not there. Sad I looked around and did not see any unattached wires. I am in the process of fixing the light in the fan indicators and was going to order a bulb and holder for the headlight switch if it could be illuminated.
87 Vanagon (sold)
1973 Type 181
71 Super Beetle
03 F-350
90 BMW 325ic
syncrodoka
syncrodoka is offline
PostPosted: Fri Apr 16, 2010 9:21 am    Post subject: Reply with quote
Vanagon headlight switches aren't lit from the factory. If you look into the back of the switch you will notice that there isn't a way for the icon to be illuminated. They can be modded though.
syncrodoka
PostPosted: Fri Apr 16, 2010 9:27 am    Post subject: Reply with quote
Here is a writeup I did to mod the switch. You need to harvest the bulb connector from another car, get a different switch and do some very minor wiring. It is one of my favorite mods, especially after a long drive and the eyes are too tired to see in the dark for the switch.
http://www.thesamba.com/vw/forum/viewtopic.php?t=273226&start=80
danfromsyr
danfromsyr is offline
PostPosted: Fri Apr 16, 2010 10:52 am    Post subject: Reply with quote
we do a similiar mod with the campers in our family,
use a colored LED hooked to constant +12v, makes the switch very easy to spot in the dark when I want to only hit the lights
Abscate wrote:
