Looking for a valve seal
DandK 56'
DandK 56' is offline
PostPosted: Fri May 14, 2010 8:01 am    Post subject: Looking for a valve seal Reply with quote
Can someone please point me where i could find those small black rubber seals, about 1/8 inch thick, that go around the valves?? I tore 2 of them last night and cant find them anywhere...hell, i dont even know what they are called. Will post pics if necessary
motor is a 1800type 4 out of a 74 westy. any help finding some that i can purchase would be appreciated. thanks
Doug
SGKent Premium Member
SGKent is offline
PostPosted: Fri May 14, 2010 8:26 am    Post subject: Reply with quote
which valves?
there are small seals that go around the fuel injectors.
George Carlin:
Skills@EuroCarsPlus:
busman78
busman78 is offline
PostPosted: Fri May 14, 2010 8:29 am    Post subject: Reply with quote
Valve Stem Seals, like for the valves in the head? None were ever used on VW AC engines, but Chevy used them. Check you local auto machine shop, even NAPA should have them.
DandK 56'
PostPosted: Fri May 14, 2010 8:37 am    Post subject: Reply with quote
Yes busman the the valves in the head. they were on there when i pulled the valve springs and removed the valves so i assumed they were supposed to ge there. Would you suggest not running them then? I apologize if i am asking goofy questions but i dont recall this being addresseed in the manual.
SGKent is offline
PostPosted: Fri May 14, 2010 8:42 am    Post subject: Reply with quote
VW never really used them although some type 1 kits included them at one time. There are two styles - one was a rubber o-ring that went around the valves and the other style requires that the guide be lathed for them, and they pressed on. I would just toss them.
George Carlin:
Joey
Joey is offline
PostPosted: Fri May 14, 2010 8:48 am    Post subject: Reply with quote
Yep, you don't need 'em. They'll only get hard and break and end up in your oil screen anyway.
Joey
‘60 Kombi - '74 Bus - '79 Panel - '65 Beetle
bsairhead
bsairhead is offline
PostPosted: Fri May 14, 2010 8:52 am    Post subject: Reply with quote
The ( Stem seal ring ) is not installed on 1973 and later models. The seal rings can be service-removed from 1972 dual carburetor engines. Bentley-Engine and Clutch, page 36 Fig. 11-1
DandK 56'
Very cool to know guys!! Thanks for your help. its appreciated Very Happy
