how do i get the door panels off?
codysmith123456
codysmith123456 is offline
PostPosted: Tue May 25, 2010 2:55 pm    Post subject: how do i get the door panels off? Reply with quote
i feel like a retard asking but i cant figure out how to take off the door handle and the window roller upper to pul of the door panel.. i need those off to pull it. so how do i do it??
'69 Baja Build http://codysmith123456.blogspot.com/
http://www.thesamba.com/vw/forum/viewtopic.php?t=419396&highlight=
'74 Super Baja
http://www.thesamba.com/vw/forum/viewtopic.php?p=5108216&highlight=#5108216
spotco2
spotco2 is offline
PostPosted: Tue May 25, 2010 3:02 pm    Post subject: Reply with quote
They are both held on with a screw.
On the door handle, pull the handle back, take a small flat blade screw driver and pry out the black plastic insert. You will find a small phillips head screw holding the chrome part on the door.
I don't know what window handles you ahve but most have a screw through the center of the piece that attaches to the regulator. There might be a plastic cover over it also.
Can you post a pic of what you currently have?
69 Beetle
VW's are not just a car, they're an adventure!
wbrown45
wbrown45 is offline
PostPosted: Tue May 25, 2010 3:08 pm    Post subject: Reply with quote
Pry the cover off of your window crank (if it black plastic it should be either a thin plastic cover that comes off or a plug in the middle of the center pivot of the crank). There is small screw (4 or 5 mm) that is removed. On the inside door handle there is another small screw behind the cover that can be pried off. After removing this hardware the door panel can be carefully pried away from the door using a wide blade type of tool. A dull metal scraper usually works well. When all of the clips are free from the door lift up the panel to release it from a tab that holds the center of the panel to the door. Save all of the clips and boots. When you reattach the panel make sure to lube the regulators, and reattach, or make some type of plastic that will protect the inside of the panel.
OK Thang
Gary
Person of Interest
Gary is offline
PostPosted: Tue May 25, 2010 3:18 pm    Post subject: Re: how do i get the door panels off? Reply with quote
Top of this forum: Late Model FAQ "Sticky's"- *Read before posting* where you'll find this: Window Regulator How-To
West Virginia State Board of Education v. Barnette, 319 U.S. 624 (1943)
codysmith123456
PostPosted: Tue May 25, 2010 3:52 pm    Post subject: Reply with quote
here is a picture. i got the door handles but am stuck on this..
couldnt get the pic to come up so here is the link.
http://tinypic.com/r/2ebx3wk/6
'74 Super Baja
doc1369
doc1369 is offline
PostPosted: Tue May 25, 2010 3:59 pm    Post subject: Reply with quote
what! I don't even Shocked . You sure your in the right place?
Fatchicks: Daily drivers, donor cars, collectibles. What can't they do?
codysmith123456
PostPosted: Tue May 25, 2010 4:06 pm    Post subject: Reply with quote
what do you meen? i need some help gettin it off.
'74 Super Baja
doc1369
doc1369 is offline
PostPosted: Tue May 25, 2010 4:12 pm    Post subject: Reply with quote
Thats not a stock crank for a 68-??? bug. Thats aftermarket or from another year/car. Give us the year and model to help out.
toyvergnugen
toyvergnugen is offline
PostPosted: Tue May 25, 2010 4:21 pm    Post subject: Reply with quote
That style of handle was on 67 and earlier cars. That is why a previous poster ask if you were in the right place. Regardless. Those handles are held on by a small pin. Push in on the panel and look around and you should see a hole where the pin locks it to the window regulator. You will need a punch to tap it out. I believe the hole is tapered so unless it is buggered up it is One way only. Many times the pins get lost when they are tapped out so watch where it lands. People replace the pin with all kinds of stuff. Cut off nails, small pierces of coat hanger etc. If that is on a 68 and newer car no telling what you will find.
The other possibility is that someone just hammerd it on a late model regulator and it is just jammed.
codysmith123456
PostPosted: Tue May 25, 2010 5:26 pm    Post subject: Reply with quote
oh ok. my bad the guy before me musta switched em out or something cause the bug they were on was a 69 on a 71 frame. well i got them out so thanks for the advise.
'74 Super Baja
TonyPgh
TonyPgh is offline
PostPosted: Tue May 25, 2010 7:57 pm    Post subject: Reply with quote
Laughing Laughing Laughing That raised your eyebrows huh?.... Laughing
1968 Type 1
https://youtube.com/c/SladesVWBeetle
View user's profile Send private message Visit poster's website Facebook Classifieds Feedback
Joel
Joel is offline
PostPosted: Wed May 26, 2010 12:13 am    Post subject: Reply with quote
just looking at the pics the body of the yellow one is a 66-67 model
probably a 67 going by the push button handles
Quick little bug, you got a Porsche motor in that?
1974 Germanlook 1303 2.5 Suba-Beetle
