Swellchaser Samba Member
Posted: Mon Jun 14, 2010 9:51 am Post subject: Suggested Battery for Westy |
Hey Folks,
So I am running the basic setup on my Westy, plus a small stereo with 2 speakers. Just wondering what brand/specs battery you suggest. Especially CCA & RC. Picked one up @ Canadian Tire but it's only about 565 CCA but I feel it should be more. I was in a bind and had to purchase a batter and this was the only place open at the time and they had only one model that fits the van.
Thanks |
Perales Samba Member
Joined: May 07, 2007 Posts: 2046 Location: Nova Scotia
Posted: Mon Jun 14, 2010 9:56 am Post subject: |
Call the CAA. (you are a member aren't you?)
I use one of their batteries and it is great. (even has a built in strap for easy removal)
They will bring it to you and install it for no charge.
They have a good guarantee as well. After 2 years I needed a boost (Kids left the interior lights on)
Since it was one of theirs, they decided that I should have a replacement and they gave me a new one on the spot. _________________ -- 1987 Westfalia automatic (Captain Vino) |
Posted: Mon Jun 14, 2010 10:15 am Post subject: |
No not a member But I should be..
What are the specs on your battery? |
speedygeorge Samba Member
Joined: November 28, 2009 Posts: 283 Location: Victoria, BC
Posted: Mon Jun 14, 2010 10:38 am Post subject: Re: Suggested Battery for Westy |
| Swellchaser wrote: |
Hey Folks,
Thanks |
Get rid of the crappy tire battery before it leaves you stranded somewhere, their batteries are complete crap. |
Posted: Mon Jun 14, 2010 10:41 am Post subject: |
| What would you recommend? |
Posted: Mon Jun 14, 2010 10:43 am Post subject: |
I am not really sure. I am away from my van for a few days, so I can't check. They arrive with a truck full of all shapes and sizes, fully charged, and will fit the correct one for you. _________________ -- 1987 Westfalia automatic (Captain Vino) |
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 10292 Location: Mt Lemmon, AZ
Posted: Mon Jun 14, 2010 1:27 pm Post subject: |
I am under the impression (certainly could be wrong) that there are only a couple of manufacturers of batteries -- so whether you pay a lot or pay a little you may be getting a similar battery if the numbers are the same.
I have never had a problem with just a cheap battery from that store some don't like. Thoughtfully maintained and not expected to serve more than 5 or 6 years they seem fine and cost a fraction of what AAA and others get. They too have a no-hassle return policy should the battery fail prematurely.
BTW -- I do have an aux battery that runs all miscelaneous stuff so my main battery is mostly for starting, running & headlamps. |
RCB Samba Member
Joined: September 05, 2005 Posts: 4143 Location: San Francisco-Bay Area
Posted: Mon Jun 14, 2010 4:21 pm Post subject: |
I had an Interstate MT41 installed back in January of 2008 and its treated me fine. Has 815 cranking amps and 650 cold cranking amps. Thats just one option  |
climberjohn Samba Member
Joined: January 11, 2005 Posts: 1840 Location: Portland Orygun
Posted: Mon Jun 14, 2010 5:09 pm Post subject: |
x2 on the Interstate group 41 suggestion (for a starting battery not an aux battery) _________________ '86 Westy, 2.5 Subaru power
Know your limits. Exceed them often. |
scottjk Samba Member
Joined: May 31, 2006 Posts: 485 Location: Salt Lake City, UT
Posted: Mon Jun 14, 2010 5:16 pm Post subject: Bosch |
I've started using Bosch because of their 3 year no hassle return policy.
Scott _________________ 1985 Westfalia 2.5L EJ |
Posted: Mon Jun 14, 2010 7:52 pm Post subject: |
Interstate MT41 |
Jamos Samba Member
Joined: July 08, 2005 Posts: 766 Location: Lake Tahoe, CA
Posted: Mon Jun 14, 2010 8:45 pm Post subject: |
I just did some battery research about a month ago...
Most of the Group 41 batteries you'll find have a 650 CCA rating.
You can also use a Group 48 battery. They fit in the vanagon box with no probelm, but are not as long as a 41, so you'll want a hold-down or something to fill the space so it doesn't slide around.
I found a Group 48 that had 700 CCA at my local Kragen autoparts.
Wal-mart has the cheapest prices I found, and apparently have a very liberal return policy, although my local store had no idea how it worked... _________________ '86 Wolfy Westy Weekender
2020 Audi Q5 |
Orbitald Samba Member
Joined: August 12, 2004 Posts: 320 Location: Oakland, CA
Posted: Thu Jun 09, 2011 4:33 pm Post subject: |
Wondering about the Group 48 batteries. I bought one thinking it would fit in my battery box but the battery is over 7" tall. Which is too tall for my main battery box. What am I missing?
Here is what the Interstate website says for Group 48:
11-3/8 x 6-7/8 x 7-1/5 (L x W X H)
Thanks,
David R.
Oakland CA _________________ '87 Syncro Westfakia, 1.9TD ADE (AAZish), 068 Injection Pump, K03 turbo, 2.5" exhaust, Mercedes nozzles, SAAB Blackstone charge-cooler w/ 800cfm fan, Micro-1000 EGT sensor pre-turbo, boost at about 13psi, 235/70/16 with stock gearing |
tclark Samba Member
Posted: Thu Jun 09, 2011 5:32 pm Post subject: |
Yea I read that. So many people seem to think the Group 48 fits in a Vanagon though. What gives?
Are they removing the battery box top?
Or???
D _________________ '87 Syncro Westfakia, 1.9TD ADE (AAZish), 068 Injection Pump, K03 turbo, 2.5" exhaust, Mercedes nozzles, SAAB Blackstone charge-cooler w/ 800cfm fan, Micro-1000 EGT sensor pre-turbo, boost at about 13psi, 235/70/16 with stock gearing |
Stockurai Samba Member
Joined: May 06, 2011 Posts: 42 Location: New Britain, CT
Posted: Thu Jun 09, 2011 5:39 pm Post subject: |
Optima deep cycle batteries. they never die, and they can be tossed around.
on the expensive side, but its a gel not a lead acid.
[edit] not sure if they fit though! I still use the one my van came with! _________________ 1990 Vanagon Transporter 2.1L [the fridge] - Daily Driver for College Commuting
| Dogpilot wrote: |
| Besides, Yuppies cannot run to a dealership and give a credit card and just buy one. You have to breath life into it, kind of like an Egyptian afterlife thing. Once you resurrect it, it becomes your buddy. It is unusual and has character. |
davevickery Samba Member
Joined: July 16, 2005 Posts: 2887 Location: Fort Collins, CO
Posted: Thu Jun 09, 2011 6:58 pm Post subject: |
| Orbitald wrote: |
D |
I have a Grp 48 from Walmart called Maxx-48. Fits fine under the driver seat in an 87 westy. I did the same battery in my 91 syncro passenger van. No mods to make it fit, it fits width wise perfectly, it has a few extra inches lengthwise to fit an aftermarket isolator or what-not, and it isn't too tall. I lay something over the terminals so they don't contact the metal hinged cover plate. Pretty good specs on the battery too, closely matches the Grp 41 under the pass seat. |
Posted: Thu Jun 09, 2011 7:01 pm Post subject: |
Under the drivers seat OK.
But has anybody put a Group 48 under a passenger seat?
I don't think it fits...
ShootingFish Samba Member
Joined: July 25, 2010 Posts: 330 Location: Portland, OR
Posted: Thu Jun 09, 2011 7:57 pm Post subject: |
I went with the Interstate Group 41 also and have been really happy with it. _________________ SF
Props aren't just for boats....
'88 2WD ALH-TDI Westy
'90 Syncro 16 Doka  |
Jamos Samba Member
Posted: Thu Jun 09, 2011 8:28 pm Post subject: |
I'm running that group 48 Kragen battery I mentioned above under the passenger seat. It fits height-wise without a problem. No mods necessary.
I've been running the group 41 from Wal-Mart as my aux. battery.
Funny though, I just looked up a battery group size chart...
and they all list the group 48 as longer and taller than a 41.
The 48 I have is definitely shorter than the 41.
Weird. _________________ '86 Wolfy Westy Weekender
2020 Audi Q5 |
