ldsvwguy Samba Member
Joined: September 16, 2003 Posts: 1023 Location: Saratoga Springs, UT
Posted: Mon Jul 27, 2009 8:47 pm Post subject: Engine dying once warm |
I have been having a new issue as of late. Once my engine has warmed up, it dies when it tries to idle. For example, I drove about 15-20 minutes on back roads cruising about 40. I hit a stop sign and the oil light flickered then the bus stalled out. It took about 20-30 seconds to start it up again and it did the same thing at the next stop sign. I have to keep my foot on the gas to keep it alive when stopped after it warms up. It cold starts fine and idles fine when cold. After driving, if I hit up a store and the bus has a chance to sit for 1/2 hour or so it runs fine again until it warms up. I have looked up threads about vapor lock but am not sure if that is what it is. I also am not exactly sure how to fix it if it is.
I am running a 1776 with dual 40 kads. |
Campy Samba Member
Joined: January 10, 2005 Posts: 4933 Location: Chico, CA
Posted: Mon Jul 27, 2009 11:57 pm Post subject: |
The carburetors could need rebuilding. Remove the spark plugs to see if there is a buildup of carbon on them. If you had a stock carburetor I would have thought that the choke valve was not opening all of the way. _________________ Don't worry; be happy. (Baba) |
sconord Samba Member
Joined: February 22, 2005 Posts: 704 Location: Dallas Texas
Posted: Tue Jul 28, 2009 3:02 am Post subject: |
I had the same thing and could not figure it out- I had a bad condenser on my distributor. The ceramic in the condenser cracks and when hot expands changing the way it handles the voltage\impedence/whatever.
I replaced the distributor (petronixs)and problem was gone.
IMO- From my experience. May not fix yours, but did for me. _________________
beatleeater wrote: |
you're a freaking genius |
Posted: Tue Jul 28, 2009 10:06 am Post subject: |
I have a petronix in it and the carbs were rebuilt about 3 months ago. Any other ideas? |
Nor_AL_67 Samba Member
Joined: December 18, 2007 Posts: 663 Location: Huntsville,Alabama
Posted: Tue Jul 28, 2009 10:10 am Post subject: |
Have you checked for vacuum leaks around anything that connects to the intake manifold(s)? Spray starter fluid (or wd40) to see if the idle changes. _________________ 63 Sedan
61 Rag
67 Type 1 Sedan
63 Type 2 Standard Walk-thru
69 Ghia
68 912
Amateur Versus Rusty Bus! |
BulletBus Samba Member
Joined: August 17, 2005 Posts: 1276 Location: Panama City Beach
Posted: Tue Jul 28, 2009 12:24 pm Post subject: |
Pertronix could be bad also. That happens more than you would expect. _________________ 53 Hatch Barndoor
If it's not a bus, it's bus money waiting to happen. |
arthurnugen Samba Member
Joined: January 11, 2005 Posts: 3081 Location: The PNW, where "going green" means rolling with moss.
Posted: Tue Jul 28, 2009 12:51 pm Post subject: |
Nor_AL_67 wrote: |
Have you checked for vacuum leaks around anything that connects to the intake manifold(s)? Spray starter fluid (or wd40) to see if the idle changes. |
This was my problem once as well, except on a 16000DP. Took the manifold off and it wiggled, the pieces were so loose. Crappy aftermarket part. _________________
cdennisg wrote: |
Lawyers don't deserve buses. |
zozo wrote: |
Don't worry too much. You can always trust a lawyer. |
ALWAYS WEAR STEEL-TOE BOOTS IN THE GARAGE!
1965 Bus (Riviera camper)
1972 Bug 'vert
1967 Bug sunroof
1961 Ghia 'vert
1957 DKW 3=6: 3 cylinder 2 stroke! |
67slownlowBus Samba Member
Posted: Fri Aug 06, 2010 2:43 pm Post subject: SAME PROBLEM what did you figure out? |
I am having the same problem. What did you figure out it was? I am in a 67 bus. Drives great for about 20 minutes after that as soon as i hit a stop light it dies. What did you find out???? |
Culito 11010101
Joined: December 07, 2006 Posts: 5878 Location: Columbia Missourah
Posted: Fri Aug 06, 2010 3:59 pm Post subject: |
arthurnugen wrote: |
Nor_AL_67 wrote: |
This was my problem once as well, except on a 16000DP. Took the manifold off and it wiggled, the pieces were so loose. Crappy aftermarket part. |
 _________________ © CJ Industries, Inc.
'64 standard w/2.0L type 4
'62 bug
johnnypan wrote: |
...dont pay no attention to Culito,he's a cornhole.. |
Keysar Samba Grammar Tutor
Posted: Fri Aug 06, 2010 4:38 pm Post subject: |
Hmmm The only thing I can think of is the idle adjustment? _________________
Clara wrote: |
...but mainly perfecting my tossing peanuts shells out the window into the air scoops technique. |
Posted: Sat Aug 07, 2010 2:08 pm Post subject: |
Vacuum leak when warm- something loose.
Missing engine tin could cause block or heads to overheat- loss of compression. Check your engine temp when it dies.
Ideas only.
I am trying to diagnose it with my new 1600 dual port, but mine idles don till it stalls. But , mine starts up easily. _________________
Cptn. Calzone Samba Member
Joined: June 27, 2007 Posts: 1872 Location: S>E>Alabama
Posted: Sat Aug 07, 2010 2:56 pm Post subject: bus dies |
Check all of the fuel lines are clear and the sock in the tank, when the motor draws fuel as it runs the crud could block the flow.Stop and the crud falls away.Also Ck the coil, a bad coil will die when hot, and finally put you to walking. my .02 _________________ 71 westfalia
67 912 Porsche Quintilla
67 Single Cab aka my work horse |
Culito 11010101
Posted: Sat Aug 07, 2010 4:00 pm Post subject: |
sconord wrote: |
Ideas only.
I am trying to diagnose it with my new 1600 dual port, but mine idles don till it stalls. But , mine starts up easily. |
I always thought it would be the other way around...when things heat up, they expand and might seal up.
Check your valves, too - if they're too tight, they could cause some idle problems when hot. _________________ © CJ Industries, Inc.
'62 bug
johnnypan wrote: |
Matt Miller Samba Member
Joined: October 24, 2005 Posts: 282 Location: Costa Mesa, California
Posted: Sat Aug 07, 2010 7:35 pm Post subject: |
Sounds like you're overheating. |
