Oil starved Judson Vanes - Cautionary Tale
John Moxon Premium Member
John Moxon is offline
PostPosted: Fri Aug 13, 2010 3:47 am    Post subject: Oil starved Judson Vanes - Cautionary Tale Reply with quote
Picture of Judson Vanes that have not received sufficient lubrication. This might seem a puzzle as the Marvel Oiler was working perfectly and the car running on a 3 mile downhill stretch and not under load.
The answer is the car was coasting with only high vacuum in the manifold and as the Marvel Oiler supplies inversely to vacuum, it virtually cut off the oil supply to the blower with the pictured results.
Solution, engage lower gear and give the Judson a blast occasionally on long downhill stretches.
Fortunately it doesn't seemed to have damaged the rotor or chamber from pictures I've seen.
John.
Snort
Snort is offline
PostPosted: Sun Aug 15, 2010 9:54 am    Post subject: Reply with quote
I wonder if it would be helpful to add a portion of MM oil to the fuel tank in addition to the vacuum oiler.
PostPosted: Sun Aug 15, 2010 11:32 am    Post subject: Reply with quote
I had a Finnish guy send me pictures of his Beetle running with 1% 2stroke oil/gas mixture instead of lubricating the Judson with the normal Marvel Oiler.
I must say I wasn't convinced this alternative would work in the long term and he'd only put 100km on his Judson set-up at the time he emailed.
Perhaps I should find his email address and see if the Judson is still running.
Adding it to the fuel tank will disperse the oil and will be atomized as it passes through the carburettor before getting to the blower vanes. Normally the Marvel Oil is added directly to the blower after the carb and so I suspect in a more concentrated form.
John.
Russ Wolfe
Russ Wolfe is offline
PostPosted: Sun Aug 15, 2010 12:17 pm    Post subject: Reply with quote
Most 2 stroke engines run a richer oil mix than 1%, (about 4 oz of oil to 1 gallon of gas) but it goes through the crankcase after it goes through the carb, and then through a by-pass into the combustion chamber.
Gary: OK. Ima poop.
PostPosted: Sun Aug 15, 2010 12:40 pm    Post subject: Reply with quote
Maths is not one of my strong points but 4oz in a gallon is about 3.125% so I would think the Finnish guy would have run into lubrication problems pretty quickly.
As a supplement to a Marvel Oiler I wound think at least 2% would be needed but to be honest I'm just guessing here.
John.
Peter_Plade
Peter_Plade is offline
PostPosted: Mon Aug 16, 2010 9:55 am    Post subject: Reply with quote
Wow that looks crazy!
When I was running a Judson I drove through Kassel in Germany (that´s some pretty big hills) with no problems.
Can the vanes have been made from a wrong type of phenolic?
But good thing the rotor didn´t get any damage!
http://vw-bluehats.blogspot.com/
PostPosted: Mon Aug 16, 2010 10:00 am    Post subject: Reply with quote
Just the normal Phenolic Linen vanes from the normal suppliers. Confused
John.
Peter_Plade
PostPosted: Mon Aug 16, 2010 11:23 am    Post subject: Reply with quote
Okay it was only a thought.
But again good thing that only the vanes was damaged, and nothing more expensive.
Altema
Altema is offline
PostPosted: Mon Aug 16, 2010 11:55 am    Post subject: Re: Oil starved Judson Vanes - Cautionary Tale Reply with quote
That's an ugly picture! The horror! Since the Marvel Oiler supplies inversely, seems like you could also make a manual vacuum release operated by a choke cable to give the Judson a live-saving dose of oil on a long downgrade.
Paul
PostPosted: Mon Aug 16, 2010 12:05 pm    Post subject: Re: Oil starved Judson Vanes - Cautionary Tale Reply with quote
Paul
The other Vintage Oiler available is The Ampco...and that doesn't operate inversely to vacuum. I've been told a lot of Judson owners use this oiler and it works well although I'm at a loss to understand how the flow rate is set to serve as a lubricator for the Judson.
John.
kiwisteve
kiwisteve is offline
PostPosted: Wed Aug 18, 2010 5:13 am    Post subject: Reply with quote
ouch! Shocked what about running a direct line from the main engine oil system John like the Shorrock or Pepco do. This seems too obvious a solution so I must be missing something. That way you can do away with the separate bottle and bits. cheers, Steve
PostPosted: Wed Aug 18, 2010 5:33 am    Post subject: Reply with quote
The thing with the Shorrock and Pepco, is the vanes on former and interlocking rotors on the latter, don't run in contact with the chamber walls.
The Judson has friction heat to contend with as well as compression heat so the oil demand would be greater than the other two. The oil to the Judson also needs to be of a lighter weight (Marvel is about 5w).
I wouldn't like to make a great issue of the ugly pictures because it's not something you see very often on Judsons. It's more of a reminder than trying to say it's a usual scenario.
John.
Altema
Altema is offline
PostPosted: Wed Aug 18, 2010 2:16 pm    Post subject: Reply with quote
That is why the picture was so shocking, I've never seen anything that bad happen to a Judson before. Glad the rest of it survived!
Paul
HouseofGhia Premium Member
HouseofGhia is offline
PostPosted: Wed Sep 15, 2010 8:43 pm    Post subject: Reply with quote
Paul
Actually, the Judson body did not survive, it was damaged beyond repair so another body had to be sourced for the rebuild.
This Judson was starved of oil. Look at the vanes...thay are dry as a bone. Since this was my first Judson, I was always concerned about the oiling, knowing how important it was. I had religiously checked the drip rate and was setting it to 4 counts per drip....about half the recommended setting. I had filled the jar full of oil and there is about half a jar left....so oil was getting to the Supercharger. I didnt keep any mileage records so I'm unsure if a half jar equates to the 400 mile estimation mentioned in the install instructions.
What I found frustrasting was that before I would take the Ghia for a spin, I would check the oiler....and it would not be dripping at all....so I'd open up the valve about a half turn and it would start dripping like crazy....I'd close it up a half turn back to the 4 count per drip rate....and then take it out for a drive. At the end of the drive, it would still be dripping at the rate I set it at. This happened quite a bit and always made me nervous.
George Folchi performed the rebuild, and reported that the oiler valve was about 1/4 turn from being completely closed! George said this knob normally should be a full turn to a turn and a half to set a drip rate of 4 counts per drip. I did not touch the setting after pulling the oiler out to send back, so this was the setting the last time I drove it.
So...it could have been the oiler, could have been my set-up...not sure.
I have the new Supercharger back in my hands and will get it installed soon. I'll report back if there are any differences I can see in how the oiler operates.
Note: George said he gets about 200-250 miles on a half jar of oil. I will be noting the milage this time.
House of Ghia, since 1980
We Speak Karmann Ghia!!
retrowagen
retrowagen is offline
PostPosted: Sat Sep 18, 2010 11:04 pm    Post subject: Reply with quote
Mike, was this the source of the mysterious sound we were trying to pinpoint in Angels Camp? (sigh... bummer.)
David Ruby
President, Karmann-Ghia World Club
PostPosted: Sat Sep 18, 2010 11:34 pm    Post subject: Reply with quote
It appears so. It seems that the oiler was not oiling. It wasnt a bearing as I suspected, but rather a dry supercharger. Wink
The new Judson is installed. I ran it rich for about 20 minutes at idle, then backed it down to 3-4 seconds per drip. It's a whole new experience. Its quieter, and it doesn't appear to be running as hot. At 3-4 second per drip, the adjusting knob is almost a full turn from closed as George instructed.
I'll never know for certain what was up....but I highly suspect the oiler.
I'm just glad to have the Judson back and installed.....
Peter_Plade
PostPosted: Sun Sep 19, 2010 8:54 am    Post subject: Reply with quote
Nice to hear that´s back on the road.
PostPosted: Sun Sep 19, 2010 9:28 am    Post subject: Reply with quote
Yes good to hear it's up and running again.
I too found the operation of the Marvel Oiler pretty erratic. Not so bad once you set it and ran it over the length of a journey but when the engine cooled and had been standing at a show all day, I had to start from the beginning again to reset the flow rate for the journey home.
I had no mishaps over a period of 10 years so I suppose I can't really complain but the standard Judson instructions for setting the oiler is to set the flow on a warmed engine and check the flow every week...remembering in those days the car would have been used every day.
Over the 10 years I pulled the oiler apart and cleaned all parts quite a few times without ever getting it to run without constant attention. Confused
Maybe I was paranoid but when you realise what can happen if you ignore the oiler setting, it was a small price to pay for keeping things running smoothly.
John.
PostPosted: Mon Sep 20, 2010 10:01 am    Post subject: Reply with quote
I started the ghia up this morning after it sat for the weekend....the drip rate is at 1 drip per second....so there was some change. I'm reluctant though to reset it to a lower rate.....There isnt any smoking, so I'm going to leave it alone for now....better more oil than less.
I will likely not be driving it much through the fall and winter, so I wont have much to report on, but I'll keep updating this post on how things are going.
DANP85
DANP85 is offline
PostPosted: Fri Aug 16, 2024 12:54 am    Post subject: Re: Oil starved Judson Vanes - Cautionary Tale Reply with quote
Do we have any update on how the Judson is going?
