Satellite Radio
oxsnot28
oxsnot28 is offline
PostPosted: Fri Sep 04, 2009 7:41 pm    Post subject: Satellite Radio Reply with quote
I have a 85 vanagon that I want to run a satellite radio in and was wondering where people before have mounted their antennas as well as how they routed them. Figured you guys would have some good ideas.
Thanks
Kevin
mrhooie
mrhooie is offline
PostPosted: Sat Sep 05, 2009 12:33 pm    Post subject: Reply with quote
i've heard of a few guys mounting it under the luggage rack and am lookign at trying it myself
http://www.thesamba.com/vw/forum/viewtopic.php?t=334686&highlight=satellite+radio
just do a search lots of good threads
85 Westy 1.9l h2o - the Winder mk II
Timwhy
Timwhy is offline
PostPosted: Sat Sep 05, 2009 1:06 pm    Post subject: Reply with quote
This is what I did with a truckers XM antena, this thing is so much better than those puck stlye antenas.
'15 Audi A3 Quattro
'09 VW Tiguan (dead)
'87 VW Westy
'91 Tin Top
'90 Cabby
syncrodoka
syncrodoka is offline
PostPosted: Sat Sep 05, 2009 1:22 pm    Post subject: Reply with quote
Do you get reception in heavy wooded sections and under bridges? I want to upgrade my antenna for those reasons. Is the stalk flexible or breakaway so that it doesn't rip out the mount if hit?
Timwhy
Timwhy is offline
PostPosted: Sat Sep 05, 2009 1:27 pm    Post subject: Reply with quote
Seems to work in wooded areas,don't know about under bridges for any antena?
The shaft is not flexible or a break a way, it would either bust the antena or the luggage rack if caught up on something.
I don't know if you are going to have any luck with all that you want a product to do, good luck!
'15 Audi A3 Quattro
'87 VW Westy
'91 Tin Top
'90 Cabby
BlackDogVan
BlackDogVan is offline
PostPosted: Sat Sep 05, 2009 1:48 pm    Post subject: Reply with quote
On a side note, I mounted my receiver base inside the ashtray & routed all the wires to it from below. Very clean looking & easy to adjust. When I take it out I can even close the lid!
hiram6
hiram6 is offline
PostPosted: Sat Sep 05, 2009 2:16 pm    Post subject: Reply with quote
Mine is mounted under the fiberglass luggage rack on my Westy, and I have the same reception I do on my other car, which has the puck style on a metal roof, with no fiberglass over it. XM radio, still have the same drop-outs in heavily wooded areas, and under long underpasses in the metro area.
1985 Westy, 1.9L automatic (Daisy)
1996 Mazda Miata
1998 Jeep Grand Cherokee 5.9 Limited
You can't lie around on the beach and drink rum all day.................unless you start first thing in the morning.
Captain Pike
Captain Pike is offline
PostPosted: Sat Sep 05, 2009 4:46 pm    Post subject: Reply with quote
Same thing but sirius.
LEARN TO SELF RESCUE
....Bad Sneakers....
albiwan
albiwan is offline
PostPosted: Sun Sep 06, 2009 5:48 pm    Post subject: Reply with quote
mine's right in the middle of the dashboard and it works fine. No need to try to get outside the car and run and hide wires.
singler3360
singler3360 is offline
PostPosted: Mon Sep 07, 2009 7:56 am    Post subject: Reply with quote
We bought our van with the puck mounted on the top of the back hatch. Not having any prior experience with satellite radio, I'm disappointed with how often it looses signal, even in areas I would consider fairly open. Is this par for the course or should I consider remounting it up front? Thx.
markmc90
markmc90 is offline
PostPosted: Mon Sep 07, 2009 9:17 am    Post subject: Reply with quote
Mine is on the dash also. It gets at least as good of signal as my jetta does with the antanae on the roof.
87 Syncro
Dogpilot
Dogpilot is offline
PostPosted: Mon Sep 07, 2009 9:35 am    Post subject: Reply with quote
Lazy old me put mine on the dash as well. I really don't have any real problems with reception. You can experiment. My XM is so sensitive to stuff directly above it, if I wave the meat wand, my hand, over it, it will cut out on reception. So I never put it under my luggage rack. I figured if it was that sensitive, it wouldn't be an improvement. Most fiberglass is transparent to RF, but many kinds to interfere with the signal, especially if it is old. Fiberglass can and does slowly absorb water. It is one of the big reasons for radome failures on aircraft. When the get too much water in the glass, well use your imagination.
Geology with a Syncro rocks!
98 Disco I
08 Range Rover SC
08 VW Rabbit S
1951 O-1G
paddyh
paddyh is offline
PostPosted: Mon Sep 07, 2009 1:17 pm    Post subject: Reply with quote
Sirius Sportster here. 'have a harness set up in our Westy and Golf, so we just have to move the head unit depending on what we're driving...ANyways, my antenna is mounted up from just below our windshield. We have a Bra fro gowesty that has a hole for the reg radio antenna on the drives side, so the Sat antenna fills that spot. I mounted the Head unit dock to one of those dash organizers and have all the cables running underneath thru the ashtray to be back of my deck and lighter socket...nice and clean. Never any issues w/reception.
81 A/C Westy
02 Impreza Wgn
Corwyn Premium Member
Corwyn is offline
PostPosted: Sat Oct 23, 2010 2:49 pm    Post subject: Reply with quote
I want to put the antenna under the cargo box, drill a hole in the roof and run the wire down the passenger-side A pillar to the stereo. Does anyone know what's inside that A pillar?
'90 White Westy ("White Lightning")
FAS Gen V 2.0
The Annual Baja Rally
~ Captain Ron ~
Timwhy
Timwhy is offline
PostPosted: Sat Oct 23, 2010 3:07 pm    Post subject: Reply with quote
Pretty sure that you can run wires down the A pillar, if it's anything like the drivers side. Your dome lights' wires are run through the A pillar on the drivers side.
A couple of problems to think about if you want to put the antenna under the luggage rack and drill a hole in the roof. The hole for the antenna's plug is much larger than is coaxial cable, so you'll have a larger hole to fill. The other thing is just putting the antenna under the luggage rack and reception. I hid my truckers xm antenna under and it worked fine, until I needed to put things up there. The reception was intermitten at best, so I put my antenna back the way I had orginally mounted it. I think that if you can go under the pop tops' sealing ring as an entery for the antenna. Then you could go under the headliner and then maybe through the A pillar. These coaxial cables are pretty easy to break, I recently broke my Tiguans'. Thought that they were not repairable, but I stripped the wires of the two inside the coaxial and then spliced them back together. The reception was there but I had to mess with the wires to get it right.
My truckers Antennas' cable is run down the front passenger side door when the Old Stand By Duct-tape hiding it somewhat. Not the best solution but it dose work without drilling holes into the roof.
'15 Audi A3 Quattro
'87 VW Westy
'91 Tin Top
'90 Cabby
msewalson
msewalson is offline
PostPosted: Sat Oct 23, 2010 6:14 pm    Post subject: Reply with quote
I have Sirius and mounted the puck style antenna on the dash, driver side. Same reception as are Subaru with puck style antenna mounted on the roof. Mounted the receiver to the front windshield using suction cup mount from the factory.
