ok now
joeridesabike
joeridesabike is offline
PostPosted: Wed Sep 01, 2010 8:13 pm    Post subject: ok now Reply with quote
alright so I have a 1600cc dp in my 71 (duhh) but anyways when its running it idles pretty high, I'd say about 1100 and there is an occasional backfire but as soon as you get on the gas and its under a load it seems to run fine and not sputter or backfire. So it only does it when its idling and being revved in neutral. Anyone have any ideas? thanks
lupin..the..3rd
lupin..the..3rd is offline
PostPosted: Wed Sep 01, 2010 8:15 pm    Post subject: Reply with quote
Go through the idle adjustment procedure for your carb. I assume it's a 34 pict 3?
http://www.vw-resource.com/34pict3.html#carb
Also check the usual things to make sure everything is in order first. Valve adjustment, point gap, etc. No sense in tuning the carb if something else is out of whack.
spotco2
spotco2 is offline
PostPosted: Wed Sep 01, 2010 8:40 pm    Post subject: Reply with quote
Sucking air somewhere.
69 Beetle
VW's are not just a car, they're an adventure!
joeridesabike
PostPosted: Wed Sep 01, 2010 8:45 pm    Post subject: Reply with quote
if it was sucking air wouldn't it do it while I was driving it?
forested665
forested665 is offline
PostPosted: Wed Sep 01, 2010 9:50 pm    Post subject: Reply with quote
not if its coming through a vacuum port. the increased vacuum through the throat of the intake will compensate for the leak once your at speed.
View user's profile Send private message MSN Messenger Classifieds Feedback
joeridesabike
PostPosted: Thu Sep 02, 2010 8:29 pm    Post subject: Reply with quote
Ohh that makes sense. but I just needed to adjust it a little more turns out it was running a little to rich now it runs like a champ but thanks for the help anyways guys
