Chad1376 Samba Member
Joined: January 29, 2005 Posts: 1435 Location: Henderson, Nevada
Posted: Mon Mar 22, 2010 1:29 pm Post subject: Zenith + SVDA? |
So I've had it with my 34 ICTs in the dirt - the constant float bowl flooding is driving me nuts. I'm thinking of simplifying my life by going with a single center mount carb.
I'd really like to find a rebuildable Zenith and start cleaning it up, but I don't want to give up my SVDA distributor. Is it even possible to tap the Zenith for vacuum? I searched and didn't find anything, so I'm guessing the answer is no, but I thought I'd check first. _________________ My never ending 1302 Autocross Project:
http://www.shoptalkforums.com/viewtopic.php?f=51&a...02b8f83f22 |
Russ Wolfe Samba Member
Joined: October 08, 2004 Posts: 25187 Location: Central Iowa
Bruce Amacker Samba Member
Joined: December 26, 2007 Posts: 1794 Location: Cleveland, Ohio
Posted: Tue Mar 23, 2010 10:33 am Post subject: |
Bruce Amacker wrote: |
I am also considering this task for my 2180/32NDIX. I have a couple of spare 32NDIX's and I bought an extra baseplate/throttle plate off of Ebay, I may try drilling it myself for a vacuum tap sometime this year and installing a vacuum advance distributor. I still have a hard time understanding why all of the engine builders recommend a mechanical only advance on the street. In my experience, a dual advance is best on the street..... |
If I knew for sure it could be tapped, and it worked, I'd be all over getting one of these. It seems like someone must have have already tried this over the course of 40+ years. Being that there haven't been 20 replies saying "no dummy, it's done all the time" makes me paranoid there might be a good reason why it can't be done.  _________________ My never ending 1302 Autocross Project:
73AZ Samba Member
Joined: August 04, 2010 Posts: 50 Location: Southern AZ
Posted: Mon Aug 09, 2010 3:32 pm Post subject: |
I am really interested in this too.
I plan to run a Zenith and would like to use the SVDA too, any info you guys find about this mod would be a huge contribution to the community. |
jsturtlebuggy Samba Member
Joined: August 24, 2005 Posts: 4610 Location: Fair Oaks/Orangevale, CA
Posted: Mon Aug 09, 2010 4:05 pm Post subject: |
Have you ever thought about using a single Weber IDF.
Most have a vacuum port on them.
It was the carb that replaced the Zenith for off road racing.
Easier to get parts for a Weber. _________________ Joseph
Elrod Motorsports
Motion Tire Motorsports
Into Volkswagens since 1960 |
kyle_pc_75 Samba Member
Joined: November 26, 2008 Posts: 511 Location: Park City, UT, USA
Posted: Mon Aug 09, 2010 4:46 pm Post subject: |
Why not ask John at AC.net and Art Thraen? John knows the SVDA, Art knows the Zenith. They work next door to each other, maybe you can convince them to stick their heads together and come up with something.
Kyle |
Posted: Mon Aug 09, 2010 8:25 pm Post subject: |
kyle_pc_75 wrote: |
Kyle |
Art did my 32NDIX and I wanted him to put a vac advance fitting in it while it was apart. He wanted nothing to do with it. Other than that, the carb/car runs AWESOME. It seems like he nailed the jetting but I haven't put a A/F on it to verify.
This could be a can of worms, because HOW MUCH vacuum at a given throttle and RPM is obviously very critical, plus this vacuum "curve" must be matched to a distributor to give "the right" advance and not too much. I can't blame him (much) for declining.
For example, I recently was playing with a '66 1300 with a 30PICT and the correct vacuum-only advance distributor. This thing gave 32* total advance at only 4"Hg! That's a hell of a lot of advance at only 4 inches of mercury! Now think of how sensitive these systems are and how hard it would be to dial in the right amount of vacuum and the right amount of advance at a given throttle angle. I'm sure this was all going through Art's mind when he declined.... _________________ '66 Deluxe Bus
'65 Standard Bus
Build threads:
'66- http://www.leakoil.net/forum/viewtopic.php?f=23&t=2888&sid=54d8dedfb3822f99c7f2ea430cb4e856
'65- http://leakoil.net/forum/viewtopic.php?f=23&t=4263 |
Posted: Mon Aug 09, 2010 9:39 pm Post subject: |
Art did my 32NDIX and I wanted him to put a vac advance fitting in it while it was apart. He wanted nothing to do with it. |
Good enough for me.
Kyle |
thesatelliteguy Samba Member
Joined: January 06, 2007 Posts: 1515 Location: Santa Rosa CA
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20864 Location: Just a tiny bit west of Yosemite Valley
Posted: Tue Oct 12, 2010 11:16 am Post subject: |
jsturtlebuggy wrote: |
Easier to get parts for a Weber. |
Careful on that statement... only "late" production one have vacuum ports, there is thousands of early production units out there with no ports.... I have two sets, with no ports....
Dale _________________ “Fear The Government That Wants To Take Your Guns"
joemama Samba Member
Joined: February 09, 2006 Posts: 1667 Location: La Crescenta, California
Posted: Tue Oct 12, 2010 11:34 am Post subject: |
So to the OP, cant you vent the bowls on 34 ict's? I have made this modification to all the carbs I have used offroad, including Holley Bugspray, Weber 40 idf, and yes even a Zenith 32, in all cases its a matter of adding a tube or fitting to the vent at the top of the carburetor, this should help |
Posted: Tue Oct 12, 2010 11:49 am Post subject: |
joemama wrote: |
I'm pretty sure the answer is "No". Last time I had my ICTs apart, I looked and the bowl vent is connected to a few internal circuits. I have another post here somewhere to find out if it can be done, but no-one has tried it.
The car runs great 95% of the time. It's just the 5% when I'm on whoops or going up a steep hill that it's a PITA. I've learned when to hold the throttle WFO to clear the gas and keep the car running. I'll swap stuff around one of these days, but it's not top priority. _________________ My never ending 1302 Autocross Project:
