kalispell365 Samba Member
Posted: Sat Oct 02, 2010 1:39 pm Post subject: YES! you can fix your analog clock... |
i have been blessed with so much information on here and wanted to share a link i discovered(not my own).it really works,i just repaired my own.this is for the old non digital clocks.
http://www.pauldottrip.com/84vanagon/analogclock/analogclock.html
my clock now keeps time and has a noticable "click" sound made for each second.i am so stoked!  |
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 10305 Location: Mt Lemmon, AZ
Posted: Sat Oct 02, 2010 1:57 pm Post subject: |
| Glad you found that site... I used it about 5 years ago to fix the clock on my '84 and it has run fine since. Tried to track the site down again and thought it was gone forever. Still have that peanut can around here somewhere. |
Posted: Sat Oct 02, 2010 1:59 pm Post subject: |
| another helpful tip is the positive side of the capacitor has a longer wire on the radio shack units,i had to hunt for that information as well. |
DAIZEE Samba Member
Joined: January 26, 2010 Posts: 7552 Location: Greater Toronto Area Ontario West Side
Posted: Sat Oct 02, 2010 3:37 pm Post subject: |
I hope it works. Dead clock using up space irritates me to no end!  _________________ '09 2.5L Jetta 5 cylinder, 5 spd, super turbo, see thread in H2O Cooled Jetta, etc...
84 Vanagon GL Wolfsburg Westy WBX 4 speed (sold) |
Pascal Samba Member
Joined: January 13, 2006 Posts: 836 Location: Fredericton, NB, Canada
Posted: Sat Oct 02, 2010 4:55 pm Post subject: |
Yeah, I did mine last winter after the clock started acting up in the fall. It's been back to it's normal soothing tic...tic...tic...all summer  _________________ '84 Westy - 2.2wbx, GT Torque-Biasing Differential
'91 EA Cabby |
AndyBees Samba Member
Joined: January 31, 2008 Posts: 2684 Location: Southeast Kentucky
Posted: Sat Oct 02, 2010 6:24 pm Post subject: |
The clock in my ole '83 has been ticking for 27 years. However, the clock in the '84 has been "dead" since I've owned it (fall of '07).
Although I am in the process of installing a TDI engine and cluster, I think I'll go ahead and repair the Vanagon Clock using the link and info. _________________ '84 Vanagon Tin-top, ALH TDI, two trips to Alaska, 2014 & 16. 1989 Tin-top unmolested.
1983 Air-cool, 225k miles, 180k miles mine, seven trips to Alaska from 1986 thru 2003. 1975 Bay hopeful. |
rogerm Samba Member
Posted: Mon Oct 04, 2010 6:41 pm Post subject: |
| Just did it and now I have the time-Thanks |
erdonline Samba Member
Posted: Mon Nov 15, 2010 10:59 am Post subject: analog clock repair |
I'm wondering what the symptoms were for those of you who have used this repair. Was the clock not working at all?
My clock works intermittently, and I think I have discovered when it works and when it doesn't- it works in the warmest part of the day or when the sun is shining right on the instrument cluster. Once the sun is off of it, or the temp is down, the clock stops working.
To me this sounds like something different than the capacitor fix. Any ideas?
Ed _________________ '85 Vanagon Westfalia
'84 Vanagon 7-passenger
'98 Mexican air-cooled Beetle |
Posted: Mon Nov 15, 2010 6:03 pm Post subject: Re: analog clock repair |
| erdonline wrote: |
| ...My clock works intermittently, and I think I have discovered when it works and when it doesn't- it works in the warmest part of the day or when the sun is shining right on the instrument cluster. Once the sun is off of it, or the temp is down, the clock stops working... |
That describes exactly the symptoms of a dying capacitor(s). Mine was like that and got progessively worse -- since replacing the caps 5 years ago it has never faltered. |
whafalia Samba Member
Joined: January 28, 2009 Posts: 685 Location: San Francisco
Posted: Mon Nov 15, 2010 7:41 pm Post subject: |
| I'm looking forward to fixing mine, but then it will only be 4:20 twice a day. |
bangbus2.0 Samba Member
Joined: April 02, 2010 Posts: 30 Location: Bay Area, CA
Posted: Mon Nov 15, 2010 9:31 pm Post subject: |
| whafalia wrote: |
hahaha. i feel the same way. no matter when i get it my van its 4:20 due to my broken clock!  _________________ 1978 Datsun 280Z
1984 Vanagon GL EuroSpec 2.0L |
Mike Robinson Samba Member
Joined: June 18, 2010 Posts: 386 Location: Nanaimo BC Canada
Posted: Fri Nov 19, 2010 3:11 pm Post subject: |
This is a super easy repair.
I am so happy to have the clock working.
Mike |
johnt55 Samba Member
Joined: March 15, 2011 Posts: 30 Location: Houston, TX
Posted: Tue Mar 15, 2011 6:33 pm Post subject: |
Have an '81 Westy without the analog clock. Bought an analog clock on eBay which seems to work well when connected to 12 volts. But perhaps I've made a mistake? Please read on...
The owner's manual says that the clock is adjusted by simply pushing in on a button, (which I assume protrudes through the clear plastic front cover) and turning it. Problem is, since my Westy never had a clock in the first place, I don't know what this looks like and the shop manual doesn't show a picture of this either. Although the clock runs well and the ancient circuit foil tests ok, the unit I have doesn't have any knob on the front to adjust the time and the existing clear plastic instrument cover in my Westy has no hole for this knob since it never came with a clock in the first place. What I have now is the rather blank disc where the clock face would be and the gas gauge located at the bottom the same as the gas gauge/clock combo, (to make sure the original purchaser was constantly reminded they were too cheap to opt for the extra-cost option).
So, anyone know where I might find a picture of what this looks like when correctly installed? (Or even a written description?) The clear plastic with a hole in the middle? The mysterious Volkswagen clock knob?
Thanks in advance! |
GMByers Samba Member
Joined: December 07, 2008 Posts: 642 Location: Retired in NW PA
Posted: Wed Mar 16, 2011 1:16 am Post subject: |
John,
I installed an analog clock in my Doka. I carefully removed (hot exacto-knife) the non-holed clear plastic and replaced it with one with a hole. Careful placement and sparing use of clear glue was my friend in this project.
Check with speelyjoe in the classifieds. He is always advertising clocks. You can probably score the plastic and the rod that goes to the middle of the clock from him. _________________ And then there were two...downsized to 83 Doka &
74 Thing. |
Posted: Wed Mar 16, 2011 8:58 am Post subject: Analog Clock |
Thanks for the information about your analog clock experience!
Assuming that I'm somehow lucky enough to drill a hole in the plastic crystal without it breaking, (that is a big assumption!) can you tell me, draw/take a picture, etc., which shows what just the knob looks like? Especially the end of it where it connects to the clock's spindle and adjusts the clock's hands?
On very close inspection I noticed two notches on the end of the spindle where it looks like something would fit.
See attached photo...
Had another photo but was not able to upload it. |
Posted: Wed Mar 16, 2011 2:11 pm Post subject: |
John,
Sorry you don't like my experience. No I don't have pictures of the knob or knob end.
Good luck on your endeavor. _________________ And then there were two...downsized to 83 Doka &
74 Thing. |
ricebowl Samba Member
Joined: November 01, 2011 Posts: 48 Location: Louisville, KY
Posted: Sat Dec 03, 2011 8:54 pm Post subject: |
I have time! Thanks to finding this post. I went through all of the instructions, at the link in the first post step by step and now have a very functional, ticking clock. Thanks Paul!
The Chinese puzzle he was talking about was pretty hard to figure out until I realized the the tamp and fuel gauges slid out from the plastic mount by releasing a couple of tabs. then the clock mechanism slid right out.
The soldering was also a bit tricky since I'd never tried it before but understood the theory. I just took my time and watched a couple of Youtube demonstrations and got it on the first try.
I didnt have a peanut can, but just used what I had within reach to hold the clock and protect the arms/face while soldering.
Here's that link again.
http://www.pauldottrip.com/84vanagon/analogclock/analogclock.html _________________ Have fun and stay safe,
-Eriic |
plummerdesign Samba Member
Posted: Sat Jul 07, 2012 10:27 pm Post subject: |
Love the how-to for repairing the clock.
That said, it seemed to go well but in the end- the clock does not work.
May have purchased some bum capacitors or got the board too hot unsoldering. Unsure.
One thing I do know is that I tried a new Weller battery operated solder pen. It came with batteries (which were dead), but once new ones were installed- it seemed to run out of power way too soon. This tool will not stay in the cabinet; back to ‘Depot it goes.
Now to find a working analog clock…
Cheers,
Jeffery _________________ It is old and green and it makes me grin.
1984 Westfalia 1.9 |
Posted: Sun Jul 08, 2012 4:54 pm Post subject: |
UPDATE:So this afternoon I went and re-soldered in a new capacitor. On the bench the clock worked great. Nice.
Reinstalled the instrument panel and…no clock.
Is there a fuse dedicated to the clock? Maybe I have a bad foil. Hmm.
Anyone?
Cheers,
DAIZEE Samba Member
Posted: Sun Jul 08, 2012 5:00 pm Post subject: |
That's why I'm probably not going to try fixing it. The temp gauge doesn't work but that may because I have an actual temperature gauge added; the fuel gauge doesn't work, the analogue clock doesn't work. mmm is it the foil?
Can you test the foil anyway? Can you bypass the foil for the clock to work? _________________ '09 2.5L Jetta 5 cylinder, 5 spd, super turbo, see thread in H2O Cooled Jetta, etc...
