Rear Wheel Bearing Removal
[email protected]
lehrsr101@aol.com is offline
PostPosted: Fri Jun 14, 2002 2:32 pm    Post subject: Rear Wheel Bearing Removal Reply with quote
Hello;
I am in the process of installing a rebuilt trans on my 66 Type 1. I can not find a good decripition onhow to remove the rear wheel bearing without possibly destroying it. Please help and if you have any learning experiences on installing a rebuilt trans with my own axles, let me know also. Thanks
Rick
brian rogers
brian rogers is offline
PostPosted: Thu Jun 20, 2002 10:17 am    Post subject: Rear Wheel Bearing Removal Reply with quote
You shouldn't reuse the bearing after taking them off. Find a pair of bolt and grind the head on one side to slip into the races between the balls, shaped like an L. Get them long enough to reach past the axel shaft through a GOOD puller. Be sure to use a GOOD grade 8 or 8.8 DIN bolt. 1/4", 5/16" x 3-4" works for me.
