Posted: Fri Jun 21, 2002 12:33 pm Post subject: Seat Changes Thru The Years... |
Can someone tell me what the year changes for seat frames were for lowback seats? I know what years the material/covering changed, but did the frames ever change? I need seats for my '62, and want to make sure I get the "correct" ones for that year. If they never changed, then I guess I can get any seats as I will probably end up recovering then anyway.
DaveR
'62 Rag |
VWAdam Samba Member
Joined: February 14, 2002 Posts: 3347 Location: Birmingham, Alabama
Posted: Fri Jun 21, 2002 1:07 pm Post subject: Seat Changes Thru The Years... |
I think that the seat frames themselves were the same from 1958-1964. The material changed though. They were smooth vinyl. Go to www.wolfsburgwest.com , they have seat covers and they show the differences between the patterns and the material. |
RareAir Samba Member
Joined: May 11, 2002 Posts: 14577 Location: 18 miles North of the border
Posted: Sat Jun 22, 2002 8:06 pm Post subject: Seat Changes Thru The Years... |
The seat frames you are searching for are 1958-64, but 1956-57 will also work. The difference is about 10mm.
The easiest visual check would be the way the seatback adjusts. If it has a "hook-like" arm on the side, you DON'T want it. It should just feature a small eccentric knob on the outside.
As for '55 & earlier, you'll know due to price as the ones you want are around $10-$50/pr '55-earlier are priced at nearly $300/pr |
