demon1018 Samba Member
Joined: September 12, 2009 Posts: 931 Location: crystal river, fl
Posted: Wed Mar 20, 2013 3:50 pm Post subject: turn signal wiring |
| im trying to fix the wiring in my 64 bus. in the wiring diagram for a 63, there isnt one for a 64, what are the 3 round things most of the wires attach to ? they are marked J, J1, and J6. also what is T1 that is right under them in the drawing? |
coolerthanelvis Samba Member
Joined: June 30, 2003 Posts: 924 Location: San Diego, CA
Posted: Wed Mar 20, 2013 4:19 pm Post subject: |
According to the Key (second column on the wiring diagrams page, right next to the diagrams ), J is the Flasher Relay, J1 is the Emergency Light Relay, and J6 is the Emergency Light Switch. T1 is a "Cable Connector". The turn signal switch has 6 wires soldered to it and this allows them to be connected to the rest of the wiring. It's just a male-male 1/4" spade connector with a clear-ish rubbery covering, very similar to the 3-legged connectors on the other wires, labelled T. _________________ Shawn
SV2s member #420
'68 Westy
"Do or do not, there is no try."
-Silent Bob |
Posted: Wed Mar 20, 2013 4:27 pm Post subject: |
| coolerthanelvis wrote: |
According to the Key (second column on the wiring diagrams page, right next to the diagrams ), J is the Flasher Relay, J1 is the Emergency Light Relay, and J6 is the Emergency Light Switch. T1 is a "Cable Connector". The turn signal switch has 6 wires soldered to it and this allows them to be connected to the rest of the wiring. It's just a male-male 1/4" spade connector with a clear-ish rubbery covering, very similar to the 3-legged connectors on the other wires, labelled T. |
um , damn i didnt see that. im an idiot. thanks |
Posted: Wed Mar 20, 2013 4:37 pm Post subject: |
ok , studied the sch some more with this newly acquired info ! now on my bus there is a round cyl shaped thing to the left of the fuse box. which one is that and were is the other. i know were the emergency light switch is  |
Posted: Thu Mar 21, 2013 8:44 am Post subject: |
The round can up near the fuse box is the flasher relay. The emergency light relay is over on the passenger side, just above and inboard of the headlight bucket. One thing that is not on the wiring diagram is the big round red light just left of the speedo pod. With your emergency lights flashing, this red light should flash, too. It's connected to one of the wires at the emergency switch. _________________ Shawn
SV2s member #420
'68 Westy
-Silent Bob |
