IdahoDoug Samba Member
Joined: June 12, 2010 Posts: 10355 Location: N. Idaho
Posted: Sat Nov 13, 2010 12:16 am Post subject: Correct A/C compressor mounting bolts? |
Incredible. Glad I'm poking around the engine while waiting for my Famous Amos cookies to arrive. The A/C compressor mounting bolts are missing. These are the upper two bolts that hold the compressor to the heavy cast aluminum bracket to the right of the compressor. The previous owner put a couple smaller nut/bolts through them to hold it on. Nice. That would have lasted until I was in the middle of nowhere, then the compressor would have broken loose and taken out all my other belts. Note to previous owner: When something is mounted with a ginormous cast aluminum mount, it means large forces at work. So switching to bolts half the OEM size would be a bad thing.
Anyhow, does anyone know the correct size and thread? With neither one to use to match, it would save me time if someone knows. Thank you in advance.
DougM _________________ 1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2017 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential, 1990 burgundy parts Vanagon. 1984 Porsche 944, 1993 Toyota LandCruiser, 2002 BMW 325iX, 1982 Toyota Sunrader |
