Vanagon tin engine air seals Cali 1980 AC
LordHuron95
LordHuron95 is offline
PostPosted: Sat Mar 15, 2025 7:54 pm    Post subject: Vanagon tin engine air seals Cali 1980 AC Reply with quote
Hello all,
While looking at parts, I came across a few rubber seals that go on the engine tin to help seal the compartment for inside/outside air. They come up on cip1 and have the vanagon listed, but only go up to 79 so I'm not sure if they'll fit or not, was wondering if anyone has tried them.
This one I think would go around the two heater pipes on either side of the access hatch behind the licence plate: www2.cip1.com/vwc-021-119-627-b/
This goes around the oil filler tube: https://www2.cip1.com/vwc-021-119-953/
And this one I think would go in the hole the oil pressure sensor goes, right behind the distributor. Although its top looks more sloped than my van's tin looks: https://www2.cip1.com/c16-021-957/
I did ask cip1 the same question at least about the first seal, they said no they dont fit, but I'm wondering if that's just because that's what their site says in the fine print, even when the product name states 80-83 vanagons. Confused
Never swing a mean loop. Never do dirt to man nor animal.
-1980 Vanagon Westy
Wildthings
Wildthings is offline
PostPosted: Sat Mar 15, 2025 10:45 pm    Post subject: Re: vanagon tin engine air seals Cali 1980 AC Reply with quote
Check other sources to see what they give for part numbers. The boot for the oil pressure switch looks correct, but can't say for sure about the others.
Fiddlestyx
Fiddlestyx is offline
PostPosted: Sun Mar 16, 2025 5:40 am    Post subject: Re: vanagon tin engine air seals Cali 1980 AC Reply with quote
When I rebuilt my engine I couldn't find any of those seals (except the oil sensor boot), so unless they started making them again those are not the correct ones.
I cut up a pool noodle and stuffed it in there, it works.
1983 Vanagon Westfalia Air-cooled
1973 Super Beetle
markswagen
markswagen is offline
PostPosted: Sun Mar 16, 2025 2:26 pm    Post subject: Re: vanagon tin engine air seals Cali 1980 AC Reply with quote
both to my eyes, look very close to what would be there on a vanagon engine.
619 201 0310
