Carbs not idling down after acceleration
jbow1076
jbow1076 is offline
PostPosted: Wed Dec 22, 2010 10:52 am    Post subject: Carbs not idling down after acceleration Reply with quote
I recently rebuilt my dell 40's for my 2054cc engine and when I give it gas and rev it up, it says rev'd for a while and then eventually idles down.
I have it jetted with 200 main/air, 170 main/gas and 55 idle. The carbs are synched. I have the mixture control screw backed out 2 1/2 turns and also tried it with 3 turns (didn't make a difference). I also get an occasional carb back fire as well. Am I running it to lean? What could be causing this? Thanks! Jeff
supaninja
supaninja is offline
PostPosted: Wed Dec 22, 2010 5:40 pm    Post subject: Reply with quote
You've got a vacuum leak somewhere.
get a can of carb cleaner and spray the carbs and mani while its idling. the idle will shoot up when you spray the leak.
http://i5.photobucket.com/albums/y163/chucky1974/ninja.gif
Nick
Megasquirted Type 4 powered Notch http://www.thesamba.com/vw/forum/viewtopic.php?t=427890&postdays=0&postorder=asc&start=0
Blog of Doom http://supaninjanick.wordpress.com/
View user's profile Send private message Send e-mail Yahoo Messenger Facebook Classifieds Feedback
