12vvr6 Samba Member
Posted: Sun Jan 02, 2011 6:00 pm Post subject: progressive carb kick my a$$ |
a little history into my story is probably needed to help diagnose my issue. i bought a decent running 66 standard with a engine from a 74 that has 1600cc dp, solex and 009 boush. i did a top end rebuild with new stock heads, pistons, rings, pushrods etc. i then bought a weber progressive 32/36 dfev and installed that. i installed everything and got it running. i set valves, timing,points, rejet the carb with Primary idle, 45 secondary 60, mains 125/190, air jets 160/180 it will idle and start just fine. i can slowly give it gas and raise the rpms with no stumbling or flat spots. but when i go wot the car will die/jerk/or backfire through the carb. i dont know what is causing this is my first carbed car anyhelp would be great. is it possible my accelerater jet could be to large and causing this it says 55 on my jet just wondering if this could be something. thanks for reading |
DarthWeber Samba Member
Joined: November 24, 2007 Posts: 7543 Location: Whittier,CA
Posted: Sun Jan 02, 2011 6:11 pm Post subject: |
You should have got Kadrons but this may help you:
http://www.thesamba.com/vw/forum/viewtopic.php?t=386388&highlight=progressive _________________
Mitey62 wrote: |
Swapped the Compufire for a Bosch blue and some points I had sitting around, started 1st crank. Took her out for a drive, pulls harder, more RPM, and runs smoother. I think I'll be sticking with points from now on. |
RockCrusher wrote: |
JB weld the case halves....that'll keep the fretting to a minimum.  |
gt1953 Samba Member
Joined: May 08, 2002 Posts: 13950 Location: White Mountains Arizona
Posted: Sun Jan 02, 2011 6:15 pm Post subject: |
Have you done a spark plug reading? _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
modok Samba Member
Joined: October 30, 2009 Posts: 27716 Location: Colorado Springs
Posted: Sun Jan 02, 2011 6:16 pm Post subject: |
How cold is it? |
Posted: Sun Jan 02, 2011 6:22 pm Post subject: Re: progressive carb kick my a$$ |
Gotta get more heat to the intake. _________________ It's just advice, do whatever you want with it!
"Like" our Facebook page at
and get a 5% off code for use on one order for VW Parts ON OUR PARTS STORE WEBSITE, vwparts.aircooled.net |
12vvr6 Samba Member
Posted: Sun Jan 02, 2011 7:17 pm Post subject: |
its around 42 degrees here. i have the preheaters hooked up but one of the preheater risers from the exhaust is clogged i drilled out the other side to help me get more he btat i broke a drill bit off in the other side and cant get it out so i am probably going to get a new exhaust. i think preheat may be some of the issue but not all. i took a heat gun and heated up the intake under the carb and it helped some but it still back fired throug the carb a couple of times during wop. is there anything else it could be. im already trying to fix the preheat issue but i feel it may be something more than that. |
12vvr6 Samba Member
Posted: Sun Jan 02, 2011 7:21 pm Post subject: |
i havent done spark plug readings yet but i did install all new ignition componets plugs,wires,point,condenser,rotor,cap. i will check them tommorow to put a check in the box but i fell like it is an a/f issue. |
modok Samba Member
Posted: Sun Jan 02, 2011 7:35 pm Post subject: |
It may be partly due to general coldness.
Your primary jets sound s little small, you could try a bit bigger maybe to see if it helps.
The way you descibe it sounds lean at full throttle.
You may be aware of this already but just in case:
One thing to keep in mind is this is a mechanical secondary. So I guess what you are supposed to do is not open the secondary at lower rpms.
Since you have a small engine it might not want FULL throttle till well past 3500 rpm or so.
If it had a vac secondary you would be able to floor it right off idle, but the manual secondary requires a careful foot.
The darn thing has so many drawbacks I don't know why anyone likes them, but some people like them, perhaps you will turn out to be one of THEM? hahaha |
Posted: Sun Jan 02, 2011 8:00 pm Post subject: |
we have a street header that is modified to work PROPERLY for centermount carbs. The non-stock headers that are available are improperly engineered for adequate preheat. _________________ It's just advice, do whatever you want with it!
12vvr6 Samba Member
Posted: Sun Jan 02, 2011 8:46 pm Post subject: |
which exhaust system are you refering to john? |
12vvr6 Samba Member
Posted: Sun Jan 02, 2011 9:00 pm Post subject: |
im guessing its the basic street header on the site i may give it a try john |
Posted: Sun Jan 02, 2011 9:02 pm Post subject: |
yes, the one with the Deluxe Preheat.
It is VERY effective. We'll have some temp #s to show how well it works. The beauty of good preheat is it makes your A/F richer without making the jets bigger, maximizing efficiency.
12vvr6 wrote: |
SRP1 Samba Member
Posted: Sun Jan 02, 2011 10:35 pm Post subject: |
Preheat not enough for sure, and the 009 distributor does not work well with that carb. When you order the exhaust get an SVDA distributor from AC.net at the same time. Your fighting two problems and will need both parts to correct the issue. |
RockCrusher Samba Member
Joined: August 03, 2010 Posts: 4596 Location: Parkesburg, PA
Posted: Sun Jan 02, 2011 10:50 pm Post subject: |
Agreed and agreed but no one mentioned the accel squirt yet. Look down the carb....with a mechanics mirror.....and see if you have any squirt at all when you crack the throttle fairly rapidly. No squirt? That is the place to start. Your symptoms sound like that. Junk in the squirt nozzle, bad pump diaphragm, etc.....
If you get a good healthy squirt then the other 2 things are your issue.
RC _________________ [email protected] Please use email for all general inquiries.
I will be happy to speak to anyone who has a serious inquiry (meaning real potential business for RC enterprises) or a parts order. Due to machining noise causing missed calls all calls will be returned promptly. |
SRP1 Samba Member
Posted: Sun Jan 02, 2011 10:53 pm Post subject: |
RC |
X2 Start with the little stuff, and work your wy up from there. |
