Mick Ord Samba Member
Joined: April 26, 2008 Posts: 203 Location: Vancouver, BC
Posted: Sat Jan 15, 2011 7:41 am Post subject: Sewfine carpet kit- Advice/Tipps ??? |
About to install a new sewfine carpet kit into my westy ( now a 7 passenger/carat set up )......not having done one before, is there better way of doing it/sequence I should follow ??
Any tips etc would be greatly appreciated- the interior is completely stripped, no seats etc.
Thxs _________________ 1991 Syncro Westy- 2.5 Suby
1989 Syncro Tristar ( sold)
1988 2wd Tristar- about to start resto/rebuild !! |
JPrato Samba Member
Joined: December 15, 2006 Posts: 791 Location: Livonia, NY
Posted: Sat Jan 15, 2011 8:23 am Post subject: |
We did the middle piece first then the floor and then the other pieces. You want to make sure there are no gaps where they meet. If I remember correctly the front piece that runs under the pedals and heater needed to be positioned so that you got the best fit between the sides, bottom and top. Take your time and position the pieces dry first, then glue them down when know where they go.
_________________ Joe
87 Syncro Tin Top project
84 Westy, 2.5L Subaru power
06 Subaru 2.5 turbo in waiting
46 Cessna 140 |
FNGRUVN Samba Member
Joined: October 27, 2007 Posts: 2237 Location: Fort Collins, CO
Posted: Sat Jan 15, 2011 7:08 pm Post subject: |
I've done a couple of these and I started with the seat pedestals first followed by the wheel hump pieces, then the center followed by the front two pieces. The two front mats go in last. I dry fit it first then glue it up a little at a time. Don't let the glue dry too long before fitting the pieces in case you need to adjust the fit. Be careful how you overlap the pedestal piece and the wheel hump piece around the battery lid. It will be obvious how it overlaps when you're there, just don't glue the wrong flap. _________________ "Democracy is two wolves and a lamb voting on what to have for lunch. Liberty is a well-armed lamb contesting the vote." - Benjamin Franklin |
