VWMan#30 Samba Member
Posted: Mon Jan 24, 2011 5:08 pm Post subject: yet another predicament... |
| i am thinking about dropping my 64 baja body on a late model pan. with irs and bj front end. what are some draw backs other than bj. i will keep the bj front. second....my tires will rub the long travel torsion tube how can i fix this? thanks for helpn |
KrAzY-BaJa Samba Member
Joined: May 22, 2008 Posts: 1409 Location: Sacramento CA.
Posted: Mon Jan 24, 2011 6:25 pm Post subject: |
| 30's are very close. i will be using stock arms. not heavy off roading just occasional mud holes. will it work? |
tanner_122 Samba Member
Posted: Mon Jan 24, 2011 6:30 pm Post subject: |
| VWMan#30 wrote: |
My friend has 31"s u can see how close it is
_________________ 91 jeep Cherokee "TANK" |
Posted: Mon Jan 24, 2011 6:32 pm Post subject: |
| so 30's? and my pop doesnt believe that swingaxle will lean out when lifted. he says it will be fine and not to worry about it. but i dont wanna wear out tires that fast |
Posted: Mon Jan 24, 2011 6:35 pm Post subject: |
| VWMan#30 wrote: |
Haha show him this pic of mine then
And they don't eat the tires that fast _________________ 91 jeep Cherokee "TANK" |
Posted: Mon Jan 24, 2011 6:36 pm Post subject: |
| how fast do they wear out |
Mal evolent Samba Member
Joined: March 31, 2009 Posts: 2924 Location: San Antonio, Nuevo Mexico
Posted: Mon Jan 24, 2011 6:43 pm Post subject: |
get shorter torsion bars and flat caps. _________________ 73 Beetle Baja, Ghia front brakes, Type 3 rear brakes, 2220 ( 94 X 80 ), Weber Progressive, Bosch SVDA, '97 Mustang seats
Baja Bugs for Volkswagen Virgins: Index |
Posted: Mon Jan 24, 2011 6:44 pm Post subject: |
| can i run torsion bars out of a older bug? and use caps from that bug? if not how long? |
Phoxxanator Samba Member
Joined: September 06, 2010 Posts: 112 Location: Arrowsic, ME
Posted: Tue Jan 25, 2011 5:50 pm Post subject: |
| tanner_122 wrote: |
| VWMan#30 wrote: |
And they don't eat the tires that fast |
Umm, my wheels definitely camber IN at the top. Is that bad? haha.
Tires have been on the bug since around '85, if that gives any indication how long they last. I'm more worried about the dry rot than the tread loss.
Lotrat Samba Member
Joined: December 08, 2007 Posts: 2528 Location: Vista, CA
Posted: Tue Jan 25, 2011 5:58 pm Post subject: |
| VWMan#30 wrote: |
Yes you can. You need the short bars, spring plates, and outer grommet.
Before:
After:
31s are too big for a stock rear end. They will rub all over the inside of the wheel wells. 30's won't rub if you keep the stock bump stop. Hibbards book show how you can beat the wheel wells to fit 31s if you are stuck on getting them. |
jeff930 Samba Member
Joined: October 15, 2009 Posts: 376 Location: Pismo Beach
Posted: Tue Jan 25, 2011 6:09 pm Post subject: |
| If you're not running it hard will 31's still rub?? |
Posted: Tue Jan 25, 2011 6:21 pm Post subject: |
| i am going to swap my swinger for an irs on my 64 pan. i will just cut the spring plate and drill holes for the trailing arms to bolt to. |
Posted: Tue Jan 25, 2011 6:38 pm Post subject: |
| jeff930 wrote: |
nope u will be fine.. u have between 1/2" and 1/4" _________________ 91 jeep Cherokee "TANK" |
Lotrat Samba Member
Posted: Tue Jan 25, 2011 6:47 pm Post subject: |
| jeff930 wrote: |
Define "not hard". Like on the streets? Maybe. At highway speeds, a large 31" tire could balloon and rub the torsion tube.
I have both 30s and 31s on rims ready to go. I also have short torsion tubes... I am going to run the 30's. I'd rather have the 1/2" extra suspension travel than the 1/2" of ground clearance. |
Posted: Tue Jan 25, 2011 7:02 pm Post subject: |
| Lotrat wrote: |
| jeff930 wrote: |
Fire roads mostly. Think I have 31's now but they are gone smooth and I never got to see them new. |
