camber shims.
Page: 1, 2, 3  Next
bug65
bug65 is offline
PostPosted: Sat Jan 29, 2011 6:34 pm    Post subject: camber shims. Reply with quote
i need to add some neg camber to one of my front spindles, would it be harmful to add two extra shims to the lower control arm in order to gain 2 deg. towards the neg. side. right now they are set as the shim chart specifies after measuring the off set.
thanks
jd
vwsteve
vwsteve is offline
PostPosted: Sun Jan 30, 2011 5:35 am    Post subject: Re: camber shims. Reply with quote
thanks
jd
It will not hurt. If I am thinking right though, you need to add them to the top to get more negative. They need to be added to the inside (toward center of car) of the link pin bushing. The number of inside shims is all that really matters. The outside ones really just affect the lenght of link pin sticking out the back. BTW, two shims will make a decent amount of change and you will need to set the toe in when you are done.
VOLKSWAGNUT
Fastest VW Belt Changer
Location: Flippin' a Belt........ .... Off-n-On ... NC USA
VOLKSWAGNUT is offline
PostPosted: Sun Jan 30, 2011 8:07 am    Post subject: Reply with quote
I sure hope you mean .2 degrees of Camber.
2 degrees would'nt be very good meaning you have something bent or something assembled wrong.
And no to correct you would need to add the shims to the inside bottom shim pack to give more negative Camber. It would basically push the bottom of the knuckle outward thus angling the spindle upward correcting your positive Camber and creating negative Camber.
0 degrees Camber tire/wheel is straight plumb vertical.
Negative Camber leans the top of the tire toward the car center.
Positive Camber leans the top of the tire tire outwards away from car center.
Or you can think about it the other way too.
Negative Camber leans the bottom of the tire outward
Positive Camber leans the bottom of the tire inward.
Dont get confused now, it means the same thing.
aka Ken {o\!/o}
Rebuilt to drive not decorate
Usually and often edited
bill may
bill may is offline
PostPosted: Sun Jan 30, 2011 10:34 am    Post subject: Reply with quote
do not do this.
Admin note: Bill Passed away - July, 2017
1965 panel bus-Kermit
"Camping is cheaper than therapy"
www.sv2s.com
www.steeringboxscrapers.net
SBS #100
http://www.thesamba.com/vw/forum/viewtopic.php?t=453617
drscope
drscope is offline
PostPosted: Sun Jan 30, 2011 11:49 am    Post subject: Reply with quote
You can NOT do this!
Camber is NOT set, adjusted or controlled by the shims.
Camber is set and controlled by the ANGLE which is cast into the link pin carrier!
Resetting shims off the chart means that the link pin carrier is no longer in it's proper angle to the control arm faces.
That will cause the link pins to bind up and wear out very quickly.
vwsteve
vwsteve is offline
PostPosted: Sun Jan 30, 2011 4:35 pm    Post subject: Reply with quote
Thanks for the explanation. This does make sense, once explained. I set my shims per the book and found that both wheels leaned in at the top when weight of car was on them. The wheel bearings were adjusted properly, so I added two shims to the top on both sides. Now the wheels do not lean. When parked on a flat surface, they was about 3/8 inch difference at the top and bottom edges of the wheel before. I have always adjusted my ball joint beams to 0 degree offset before and have had excellent tire wear, so I thought it would be good on the link pin beam also. So my question is, is the 3/8 inch too much, and how can it be corrected? Thanks
VOLKSWAGNUT
PostPosted: Mon Jan 31, 2011 6:57 am    Post subject: Reply with quote
Oh You CAN do this, but it can have an effect on life of the shims and links. It essentially will cock the shims and does put more pressure on the entire link, but it does work. It is not a prefered method though (as you can see from above) and I dont routinely do this to my own or my customers cars.
If the situation is to the point of measuring the plumb of the contol arm faces vs the link pin carrier something needs to be replaced to correct your condition. Yes I would say if you measures 3/8 inch difference from a plumb surface to the top of the wheel and the bottom of the wheel with the weight of the vehicle on the wheels, plus on a near perfectly level flat surface, it is too much.
I prefer slightly positive Camber on the front or zero. Positive Camber means the top of the tire is OUTWARDS Away from the car center (thrust line center). From what you posted you measured was negative Camber, TOP Inwards with the shims in the correct posistion.
.2 degree (either negative or positive) Camber is generally not enough to consider exteme, unless you have an issue where the cross Camber (side to side) difference is opposite of each other then it can induce a drifting or pulling feel.
aka Ken {o\!/o}
drscope
drscope is offline
PostPosted: Mon Jan 31, 2011 9:38 am    Post subject: Reply with quote
Sorry, you can NOT set camber with the shims! You may think you are, but it ain't!
Think about it. You have just enough play in the link pin bushing for the link pin to go through. NO extra room.
The faces of the trailing arms are parallel to each other and so is the link pin hole through the arm.
If you reshim to adjust, you are changing space between the link pin bushing and the trailing arm face.
BUT the ONLY way for the link pin carrier (which controls the camber by the angle cast into it) to change it's angle would be if you have slop in the link pin bushing.
If the bushing is tight, it can not allow the carrier to change it's angle in relation to the ground.
So if you do this, The bushing which is SOFT will wear very quickly into a wobbled out hole. At that point, yes the camber will change, but you are back to having so much slop in your bushings that paint lines on the pavement may just throw you into the next lane.
VOLKSWAGNUT
PostPosted: Mon Jan 31, 2011 9:46 am    Post subject: Reply with quote
I agree to disagree. Shims are for arm offset, not truly for Camber adjustment.
aka Ken {o\!/o}
bug65
bug65 is offline
PostPosted: Tue Feb 01, 2011 7:32 am    Post subject: Reply with quote
wow, you all are really against shimming off the chart. i am planning to just disassemble and take another measurement. i know there is some ware in the link pins but the car drives very straight and supper smooth. it also has a lack of caster due to the rake of my car. i think i will order caster shims and see if that helps my tires last a bit longer.
thanks for all the replies.
jd
drscope
drscope is offline
PostPosted: Tue Feb 01, 2011 8:39 am    Post subject: Reply with quote
The faces of the trailing arms are not parallel to each other. That's the reason for needing the shims.
Basically, you are taking that distance and filling it with shims so everything stays square.
The link pin comes through the carrier and the hole in the trailing arm. There is not supposed to be any slop in the holes which they go through.
So to change the angle of the link pin carrier in order to adjust camber, the link pin would HAVE to angle in the bushing.
It CAN NOT do that unless it is wallowing out the bushing, no matter how many shims you put behind it. Unless you bend the link pin.
You are NOT using the shims to set camber. You use the shims to make sure the link pin carrier is square to the trailing arm faces.
Hold the link pin carrier with the bushings in your hand so it is upright. Slip the link pins into the bushing. Now lean the carrier over to simulate camber.
If you are paying attention, you will see the link pins changed their angle in relation to the ground.
So unless the hole through your bushings, or the hole through the trailing arm changes it's angle, putting shims in where the chart says not to isn't going to give you the results you think it is.
VOLKSWAGNUT
PostPosted: Tue Feb 01, 2011 3:23 pm    Post subject: Reply with quote
Technically you can add or reduce Camber by adding or taking away shims, but it comes at a big cost....the link pins, shims and bushings just wont last and will wear out faster than normal. The issue is as Dr. Scope has pointed out when you ad (or take away) the shims it creates an issue where the shims and carrier basically dont fit flush and flat.
When he states link pin relation to the ground he means the horizontal level of the pin in comparison to the road surface or better a level surface. With the incorrect shim amounts, and assembled, you think the pins are tight, flat and everything is fine, it is actually appling more force on one side of the shims and trying to cock the pin in its bore. It will wear the shims and bushings out quicker, thus eventually eliminating the Camber you have tried to correct. Thats the reason for properly measuring the offset and installing the correct shim amounts per side and location. Then measure the assembled Camber and if out of specs, replace worn, bent or tired weak parts to correct.
Think about it this way. Assemble just the lower pin and tighten it up. If the gap for the top shims is greater than the amount of shims required, you essentially would have to try and force the carrier tight against the trailing arm which will try to twist the lower arm or upper arm and put more side load pressure on everything, thus binding and wearing when in use. The purpose of measuring the offset, is to be sure that the carrier, shims and arms surface all lay flat on each other, with as low as possible side loads on the bushings and pins, so everything works together smoothly.
Arrow Caster is not normally a contributor to tire wear unless you are constantly turning. Like a road race car. Think of Caster as a stabilty enhancer for straight driving. The more Caster the more stable. Caster also contributes to the return rate to center of the steering wheel. The majority of tire wear is toe and tire pressure, well and Camber if it's extreme.
Here is the chart for perfect world VW's . You may find out yours may be off the chart. Sometimes the perfect world used 50 year old VW doesn't exist.
Here is the VW manual Camber reference.
aka Ken {o\!/o}
drscope
drscope is offline
PostPosted: Tue Feb 01, 2011 8:15 pm    Post subject: Reply with quote
Yes, what he said better then I could! ^^^^^^
61SNRF
61SNRF is offline
PostPosted: Tue Feb 01, 2011 11:28 pm    Post subject: Reply with quote
So in other words, just fix the problem and stop screwing around with the shims. The factory specifications are all you need to go by.
If the beam and frame are straight, get some new control arms to start with. I know with Ball joint arms you can look at them when they're out and be able to tell when they're bent. They bend in the bearing portion too, you can see this with a straight edge held against the bearing surfaces.
Once your offsets are within max specs, the shimming will be easy.
As long as you have good bushings and the spindles are not bent you will be in specs on camber.
-Bruce
An ounce of prevention is worth a pound of cure.
vwsteve
vwsteve is offline
PostPosted: Wed Feb 02, 2011 4:01 am    Post subject: Reply with quote
Thanks for the explanations. It looks like basically, the trailing arms need to be offset by 7mm and you adjust shims to get that. Worn or loosely adjusted link pins or worn king pins or loose wheel bearings will all create more negative (wheels leaning in at top) camber when the weight of the car is on the wheels.
EMPIFLAKE
EMPIFLAKE is offline
PostPosted: Wed Feb 02, 2011 5:48 am    Post subject: Reply with quote
IMHO it depends on what your building! Once you lower the car its all custom from that point! These cars dont have a way to adjust camber other than the shims or maybe looking for new arms or carrier with the degree your looking for. Shims are the ONLY way to adjust it and yes in might wear your link pin bushings and pins earlier! But even original setup can wear crazy! Ive seen it ! The reason is not keeping your linkpins adjusted and tight! And most people dont even mess with them so! With having no other way to adjust camber I would do it with shims aswell! keep it greased and adjusted and rool it! Cool
VOLKSWAGNUT
PostPosted: Wed Feb 02, 2011 6:33 am    Post subject: Reply with quote
EMPIFLAKE wrote:
IMHO it depends on what your building! Once you lower the car its all custom from that point! ! Cool
The above statement is a very good and valid point. Any vehicle that has been altered from stock, throws the OEM specs out of the window. Plus I will ad used cars are that USED. Parts on these grow tired after years and years of unmaintenanced and borderline abused use.
aka Ken {o\!/o}
drscope
drscope is offline
PostPosted: Wed Feb 02, 2011 10:06 am    Post subject: Reply with quote
You still don't understand how this works.
SHIMS DO NOT ADJUST CAMBER!
Camber is COMPLETELY AND TOTALLY controlled by the angle cast into the link pin carrier!
So unless you are machining new link pin bushings, or casting a new carrier with a different angle cast into it, YOU CAN NOT ADJUST CAMBER WITH THE SHIMS.
Go back and look at the picture on the previously posted shim chart.
Do you see the angle between the top and bottom link pin? You can't change the amount of shims in the ABC or D position to adjust camber because the link pins will CONTINUE to be horizontal.
So the only thing you will accomplish is having too much space in the "A" position if you try to adjust camber by adding shims to the "C" position.
That is because the link pins will CONTINUE to be horizontal because of the tight tolorance of the hole through the link pin bushing and the control arm.
If you machine off set bushings for the link pins to go through, then you can change the camber angle, but even then it will be determined by the angle in the bushings, NOT by the placement of the shims.
You think you can do this because you are adding more shims to the "C" position, so that should push the bottom of the wheel out, but the truth is the link pin carrier just can't lay over the way you think it can.
Snort
Snort is offline
PostPosted: Wed Feb 02, 2011 11:32 am    Post subject: Reply with quote
Bentley manual reminds us to check the offset of the torsion arm link (I always call it the link pin carrier) when calculating the shim pack. If the offset is greater than +/- 0.2mm from the correct value of 7.0mm, then add the deviation into the torsion arm offset measurement.
KTPhil Premium Member
KTPhil is offline
PostPosted: Wed Feb 02, 2011 12:16 pm    Post subject: Reply with quote
Stressed and worn link pins are a great way to lose a wheel, a barrel o' fun at freeway speeds. Trying to set camber with shims invites just this occurance.
Page: 1, 2, 3  Next
