bajahucks Samba Member
Joined: March 04, 2008 Posts: 733 Location: north sandiego
Posted: Wed Feb 02, 2011 10:27 pm Post subject: white on oils cap |
| i looked at a 69 but tonite. pulled the oils cap and it had white gooey on it. it wasent alot just a litle. the guys said he just rebuilt the engine not to long ago. maybe from before? what causes this? let me know, going back tomorrow to drive it and look at it some more. thanks |
Lotrat Samba Member
Joined: December 08, 2007 Posts: 2528 Location: Vista, CA
Posted: Wed Feb 02, 2011 10:29 pm Post subject: |
What's up Hucks!
Moisture in the oil. It'll burn off once it's hot. Make sure the case isn't filled with water. |
dcdubs Samba Member
Joined: January 29, 2003 Posts: 860 Location: the Great Northwest
Posted: Wed Feb 02, 2011 10:35 pm Post subject: |
thats from not letting the car warm up a little before setting off. also some oils might have a detergent addative....whats a "sed a give" ? ha ha _________________ dcdubs/glcustoms
AllRightGarageDoorsNW.com |
Joel Samba Member
Joined: September 04, 2006 Posts: 11099 Location: NSW Australia
Posted: Wed Feb 02, 2011 11:02 pm Post subject: |
No it's not.
It's just from doing short trips where they car never gets up to temp.
letting the car Idle in the driveway to warm up is one of the worst things you can do to it.
Best way to get a car to temp is to drive it, just be easy on it for the first few miles.
even the VW manuals will tell you that. _________________ Quick little bug, you got a Porsche motor in that?
1974 Germanlook 1303 2.5 Suba-Beetle |
dcdubs Samba Member
Posted: Wed Feb 02, 2011 11:12 pm Post subject: |
so maybe i should say..... "always drive your vehicle thoroughly through at least one heat cycle prior to shutdown to ensure proper oil consuption and cleanliness of spark plugs" _________________ dcdubs/glcustoms
Joel Samba Member
Posted: Wed Feb 02, 2011 11:14 pm Post subject: |
Perfect  _________________ Quick little bug, you got a Porsche motor in that?
Posted: Wed Feb 02, 2011 11:22 pm Post subject: |
hey lotrat. think im gonna pick me up another bug. build for the stret tho.
thanks for all the help guys. |
Lotrat Samba Member
Posted: Thu Feb 03, 2011 1:19 am Post subject: |
| bajahucks wrote: |
I passed on a 65 awhile ago, but a buddy grabbed it. He's had a ton of baja's and never a street ride. His goal was to have a vw with turn signals and a horn. I think every VW owner has a goal to have one of each flavor. Either all at once or one at a time. |
Duane Samba Member
Posted: Thu Feb 03, 2011 2:49 am Post subject: |
| could be emulsified water/oil from condensation like stated, or could be white lithium assembly lube since he "just rebuilt it". Hard to tell without a picture and history. |
JerryMCarter1 Samba Member
Joined: January 07, 2007 Posts: 6199 Location: N.W. Phoenix
Posted: Thu Feb 03, 2011 5:47 pm Post subject: |
| X2 Duane |
JasonBaker Samba Member
Joined: February 08, 2010 Posts: 1642 Location: Cleveland, TN
Posted: Fri Feb 04, 2011 7:19 am Post subject: |
| I had some nasty white milky shit in the top of my oil cap too. Then I checked the breather box and it was filled with milky white oil foam and gas. Nasty shit, I dont think it was allowing the system to even breath properly. Which would explain why my motor has run like shit in the cold and pukes oil out from everywhere. I think you guys are right about getting it hot enough to burn off the moisture. Lack of flaps in the shroud is starting to catching up with me. |
68IHscout Samba Member
Joined: March 10, 2010 Posts: 3122 Location: santa ana ca
Posted: Fri Feb 04, 2011 7:29 am Post subject: |
| So what's a good run ? Ten miles sufficent enough to have the condensation burn off oil? |
Posted: Fri Feb 04, 2011 8:18 am Post subject: |
| 68IHscout wrote: |
Here's my best guess.
IMHO, I think there are too many variables to answer that correctly. Like what's the outside temps, what is the relevant humidity, oil temp at shut down, etc.... Each motor can also achieve normal operating temps at different rates too.
But, I do think that ten miles would be a good start if the outside temps were above 40 degrees and you have working flaps in the shroud. If that tens miles is uphill and there is a load on the engine it would build up some heat. |
Posted: Fri Feb 04, 2011 9:43 am Post subject: |
no
often it can take a lot-- the condensation builds daily ! |
BUGGED11111 Samba Member
Joined: February 03, 2006 Posts: 1828 Location: Oregon
Posted: Fri Feb 04, 2011 10:38 am Post subject: |
| you will see that gunk alot especially if you don't have flaps/thermostat on your car |
gt1953 Samba Member
Joined: May 08, 2002 Posts: 13957 Location: White Mountains Arizona
Posted: Fri Feb 04, 2011 12:45 pm Post subject: |
Mine has that issue from time to time so once a week whether it needs it or not I take it out on the Hy and run it at 65 mph for about 20 minutes out and then turn around and run it back total time 40 minutes the cabin heat is quite toasty not over heated. the best part is the lil bit of white slimy goo is all gone.
The cause is from not getting the engine HOT enuf. _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
vw_hank Samba Member
Joined: February 07, 2001 Posts: 5371 Location: Everett WA
Posted: Fri Feb 04, 2011 4:10 pm Post subject: |
| gt1953 wrote: |
The cause is from not getting the engine HOT enuf. |
same here,, git it out on A mt.road and enjoy the drive ever cruise the city at 4-5am on A Sunday morning? Seattle is about 20mil from me, And the place is A ghost town at that time its kinda cool  _________________ 1302s sunroof..
1600cc motor. Glenn ring 010. full toplineparts.com suspension. factory front disk brakes. Tram type-3 rear brakes. Hurst shifter. empi-8's. low-back's. tons of mods! |
cletus_zuber Samba Member
Joined: January 08, 2010 Posts: 2482 Location: Gladstone, Ore
Posted: Fri Feb 04, 2011 7:21 pm Post subject: |
gt and Hank-Agreed!
My lil ole 8 mile commute just doesn't heat the car up enough,
Take it every Saturday up to Mt. Hood, burn all that crap off, if I have to put the chains on then that's a bonus!
Job is gonna move in a few months, googlemaps says its a 40 min drive, that ought to do it If I can afford the gas... _________________ 1972 1302
HPMX 40's & 019 |
