what transmission is this?
thext94
thext94 is offline
PostPosted: Mon Feb 07, 2011 5:45 pm    Post subject: what transmission is this? Reply with quote
Can anybody tell me what type of tranny this is? I've always assumed it is stock but I never actually confirmed it.
Thanks,
Tyler
Russ Wolfe
Russ Wolfe is offline
PostPosted: Mon Feb 07, 2011 5:53 pm    Post subject: Reply with quote
That is just a single side cover trans.
1973 and newer.
Gary: OK. Ima poop.
thext94
thext94 is offline
PostPosted: Mon Feb 07, 2011 6:09 pm    Post subject: Reply with quote
hmm...so maybe my bug isn't a '67...
XLR8
XLR8 is offline
PostPosted: Mon Feb 07, 2011 6:12 pm    Post subject: Reply with quote
yeah that's a 73'+ tranny. unless it has had IRS conversion AND a diff tranny placed in it's life then no it isnt 67. but somehow i think it's a bitsa. they are so easy to work on you never know how many miles they have really done when you buy them either. (parts from 3 diff cars, 5 diff speedo's etc lol)
this isnt the tranny in your big tuff baja is it?
"But that parts not user serviceable!"
"Mate, everything's user serviceable."
joescoolcustoms
joescoolcustoms is offline
PostPosted: Mon Feb 07, 2011 6:23 pm    Post subject: Reply with quote
It is a '68 or earlier pan in the picture. It was formerly a swing pan and now has a IRS conversion.
The tranny is a late '72 up to a mid year '74. Most likely a 3.88:1 ring and pinion, but could be a rare 4.12:1. Would have to see the first two alpha digits on the tranny number to be sure which ratio, but if I was betting, I would pick the former. The number is just below the upside down "VW" emblem in the photo.
Bad News Racing 2018 NORRA 1000 3rd in Class
Looks like it was painted with a live chicken,polished with a brick and buffed with a pine cone
thext94
thext94 is offline
Well it's been coverted to IRS, but not sure about the tranny swap. The guy I bought it from was a sketchy dude, never replied to any e-mails about what was in it or anything.
And yeah it is the tranny in my baja . . . Embarassed is that not good? haha
larryvance66
larryvance66 is offline
PostPosted: Mon Feb 07, 2011 6:33 pm    Post subject: Reply with quote
That's an AT 3:88 tranny alright. You can see where the pivots have been welded in to convert your car to an IRS. The PO prbably just doesn't even kn ow these things so he avoids you. I have a converted '64. I find the AH 4:12 R/P tranny turns my 31's much better than the AT. I'd like to see the rest of your car. Any pics?
I got a Volkswagen for my wife....Best trade I ever made!
XLR8
XLR8 is offline
PostPosted: Mon Feb 07, 2011 6:47 pm    Post subject: Reply with quote
ok then...i just crawled under my bug and took 2 photo's of the tranny numbers.
ive got what looks like 113 301 10 under the upsidedown VW symbol
and on the bottom visible from below the frame horn: DC4775109
does that mean anything to anyone?
i only THINK ive got a 3.88r/p AT gearbox. but dont know for sure and the numbers mean nothing to me. Confused
joescoolcustoms
PostPosted: Mon Feb 07, 2011 6:55 pm    Post subject: Reply with quote
Here is the location of the number needed:
larryvance66
PostPosted: Mon Feb 07, 2011 6:56 pm    Post subject: Reply with quote
XLER8=You need to look on the right side next to framehorn in front of CV. Should be stamped in starting with two letters. You do have IRS right?
joescoolcustoms
PostPosted: Mon Feb 07, 2011 6:57 pm    Post subject: Reply with quote
If it is indeed a "DC" code tranny, it is from a Type three and has a 4.12:1 ring and pinion.
XLR8
XLR8 is offline
PostPosted: Mon Feb 07, 2011 6:59 pm    Post subject: Reply with quote
that makes perfect sence since it is single side cover and has been converted to twin IRS spring plates AND type 3 rear brakes.
well well well this is welcome news Very Happy
larryvance66
PostPosted: Mon Feb 07, 2011 7:05 pm    Post subject: Reply with quote
here you go:
http://www.vw-resource.com/transaxle.html#codes
XLR8
XLR8 is offline
PostPosted: Mon Feb 07, 2011 7:23 pm    Post subject: Reply with quote
epic win, i didnt want to have a 3.88 r/p cause i wanted to run larger tires without having to buy a different r/p and all that stuffing about. so now all i gotta do is get some bigger tires then break this tranny and get a 6-rib lol
no wonder the autostick super went faster than this one at 4000 LOL.
had that thing wound up to "oil" (off the clock) on the speedo with a 1600sp engine Laughing
thext94
thext94 is offline
PostPosted: Mon Feb 07, 2011 7:28 pm    Post subject: Reply with quote
Thanks for all the info. Does anybody know the strength of these trannys? know they probably aren't strong, but am I looking at a replacement trans sometime soon if I beat it fairly hard off-road?
Here's some pics of my car Larry
There's also a bunch in here, most of them are my baja
http://s960.photobucket.com/albums/ae83/thext94/
Tyler
larryvance66
PostPosted: Mon Feb 07, 2011 7:46 pm    Post subject: Reply with quote
Nice ride. Seen it on here plenty. The AT is actually a little tougher than an AH but the AH is a little lower. If you want to break it do as I did. Dump the clutch in soft sand with a 4 puck clutch. PO put the clutch in . Don't know what he was thinking! Think I'm wanting to get into a bus box also.
XLR8
XLR8 is offline
PostPosted: Mon Feb 07, 2011 8:12 pm    Post subject: Reply with quote
any idea how a DC tranny would compare then?
btw. sorry for hijacking the thread Embarassed
joescoolcustoms
PostPosted: Mon Feb 07, 2011 9:19 pm    Post subject: Reply with quote
The weekest part of a single side cover, (SSC) tranny is the shift forks. About the time the switch was made to the SSC, they changed to brass shift forks. Hard speed shifting will break them.
The DC tranny, if it has dual side covers should have steel shift forks, and hold up just slightly better for hard shifting.
Both trannies have a week first gear. The SSC tranny that has a offset top rib, (came out in late '74) has a stronger 1st gear set, but will still break under pressure.
If you beat on anything hard enough, it all will break. If you are trying to run it like a race baja, expect a very short life from it.
byrddog151
byrddog151 is offline
PostPosted: Sun May 04, 2025 4:46 pm    Post subject: Re: what transmission is this? Reply with quote
Can anyone help me identify this transaxle and/or transmission? What year would it be. I’m needing to replace the wheel bearing so I need some information to get me headed down the right trail. Thanks in advance!
Dale M.
Dale M. is offline
PostPosted: Sun May 04, 2025 6:34 pm    Post subject: Re: what transmission is this? Reply with quote
Basically it's a 61-68 swing axle..... They come in two versions ... Short axle or long axle... Bearing should be same for both versions...
And the joint for the boot should not be directly on top (12 o'clock), it should be either between 10 and 11 o'clock or between 1 and 2 o'clock....
