rtroy Samba Member
Joined: June 03, 2009 Posts: 260 Location: California
Posted: Thu May 09, 2024 4:37 pm Post subject: |
SplitPersonality wrote: |
If one were to put a Porsche-head on a VW 30/36HP engine case/cylinders....from what type of 356-engine would this nead need to come from? Only the 2-piece engines, or would a 3-piece head fit onto a 2-piece case? |
Only 2PC engines work: BOTH the head stud locations AND the cylinder spacing are different.
I've built quite a few... If Stefi's still making those heads, that's the way to go!
RT _________________ Richard
Karmann Ghia and Porsche 356 enthusiast
Founder, The Karmann Ghia Club of N. America |
wagen19 Samba Member
Joined: November 16, 2007 Posts: 59 Location: germany
Posted: Mon May 20, 2024 3:09 am Post subject: |
rtroy wrote: |
RT |
There are some possibilities based on 356 pre A engines
a) 1100 ccm till 9ī54
b) 1300 and 1500 ccm
Its rather easy to built a 356 engine in a VW 24,5 HP-case, when you go 1100 ccm-based. VW crank and rods, 356 Pistons, Zylinders, heads, and valve-train. The VW-case can remain untouched, not machined.
Well, the parts are rare and so some sort of problem.
Pistons were 73,5 mm stock, but i have a used set also in 75,5 mm, not knowing where it really comes from. Getting 75,5 mm Porsche-style-pistons, you can go with used 75,0 mm VW cylinders und machine them up for 75,5 mm.
The Porsche 1100 Zylinders have the same diameters and lengh as VW cylinders, only a bigger wall, matching VW case as well as 24,5 PS heads.
Early 356 gmund-engines used single-port VW-heads.
Then for the new Porsche-designed dual port heads, late 49 onwards, there were at least 3 in details different versions for 1100 ccm heads till 9ī54. (lying around in my humid cellar) The first 2 versions had 4 x M6 studs for the intake manifolds, the third version has the common 3 x M 8 studs. All newer 356 manifolds fit the last 3 x M8 version. Sorry, I still donīt know, how long the 4 x M6 heads were originally used, guess late 50 to early 51. Who knows better?
For 1300 or 1500 ccm VW cases, 24,5 or 30 HP must be machined, at least for cylinders. Porsche crank bearings have 60,25 mm outside, VW only 60,0 (standard)
Once, the case is machined, itīs rather easy going, solving some minor further tasks. But going pre A Porsche engine, due to rare and expensive parts, there are lots of $$$ per HP at the end. Porsche is always interesting, mostly good, but never ever cheap!
For 1300 and 1500 ccm Porsche engines, there are some different heads with 8 mm or 10 mm valve shafts and small round or bigger oval intake channels. But all of these (pair) of heads fit the stock 80 mm alu-cylinders with hardchrome surface. (aftermarket in GG and maybe alu/nikasil)
There were aircraft engines with 74 mm Porsche crank, combined with good cooling 80 mm alu cylinders and 80 mm flat pistons, for ex from early 2-piece Porsche industrie engine and machined cheap VW 30 HP heads along with cheap (may be a bit boaring) VW cam and valve-train.
Designed for 1500 ccm, output around 42 HP at 3000 RPM (for airplane-use)
A rather tasty and good invisable combination in single-carb, or period in dual carb-setup for beetles and co. |
