AC Unit Removal (permanently)? Done it?
hoipolloi
hoipolloi is offline
PostPosted: Fri Feb 25, 2011 1:30 pm    Post subject: AC Unit Removal (permanently)? Done it? Reply with quote
Well its raining. Its winter (finally, hey Im in California, its been beautiful for weeks!) and I want to DO SOMETHING!
So I am looking at my AC unit, which I have bashed my head on SO many nights when I sit up. And I notice the that front left corner seems slightly sagging (above the top right corner of the rear cupboard). So I want to fix this, but I have had the thought of trying to completely remove my AC unit to open up the entire area.
Has anyone ever done this? I am considering it and I at the least need to fix the sagging corner.
I will take some photos shortly...
Big Blue 1987 Weekender Vanagon
SyncroGhia
SyncroGhia is offline
PostPosted: Fri Feb 25, 2011 1:49 pm    Post subject: Reply with quote
Is this a tin top van or does it have a pop top?
If it's a tin ton, then you can remove it but the headlight will sag down as there is nothing to hold it up. You'll need to put in the bars which run through the loops above it and clip into the roof.
If it's a pop top, firstly I'm interested in the system complete and have the normal cupboard as a swap/part ex. Secondly, you should be able to remove it and have more space.
Removing the complete system (pipes, loom, condensor) etc is a fairly big job but can be done in a day. One thing I would suggest is trying to loosen the pipes going onto the condensor carefully and if they're not going to move, don't force them. You'll just take the threads off! Remove the condensor with the pipes attached to save it.
The rear cupboard is different as well to allow the pipes to run up behind it so you can gain space here as well.
MG
T3 Syncro 16 S6 Westfalia Limey SOLD
T3 Syncro 6x6 SOLD
T3 RS6 Bluestar
T3 Tristar Syncro 16 SOLD
T3 Tristar Syncro RHD SOLD
View user's profile Send private message Send e-mail Visit poster's website MSN Messenger Gallery Classifieds Feedback
CQ
CQ is offline
PostPosted: Fri Feb 25, 2011 4:15 pm    Post subject: Reply with quote
I removed all mine on my 82 Aircooled. Was not too bad to do. Left it all intact too just incase someday I or somebody else is looking for one.
82 Westy 'Betsy'
72 Bus 'Bertha' -Sold
Learning about 2.0L AFC Everyday.
hoipolloi
PostPosted: Fri Feb 25, 2011 4:26 pm    Post subject: Reply with quote
Got any photos? I would love to see what that looks like..
irgsmoore4
irgsmoore4 is offline
PostPosted: Fri Feb 25, 2011 4:57 pm    Post subject: Reply with quote
i have an 87 vanagon and i removed the A/C unit a few months back, we never used it and i lost count how many times i banged my head on it! It came out easy enough and the only trace now is the outline on the headliner , 4 screw holes in the liner, and the liner is missing inside the rear door on the side walls, as there is none behind the plastic panels, removing the motor was easy but the motor bracket is another story getting to all of the bolts is a pain, i pulled all the lines under the van and cut them at the condenser, (be warned the liquid is not good for you or your pets! the system in our van was dry,PO had bled it for removal but never got too it).
Ivan
99 Eurovan (The Tortuga)
87 2.1 WBX Vanagon ( Elsie ) sold
Wife,3 kids 1 dog(luna)
"Needle Noddle Noo"
canasync
canasync is offline
PostPosted: Fri Feb 25, 2011 5:07 pm    Post subject: Reply with quote
X 2
1987 Syncro
3 knobs
PumpeDüse TDI (17mm Garret Turbo, bigger injectors, stage 4 malone tune, intercooled)
Cruise Control
Planar Coolant Heater
Remote Start/locks
Custom Lift
Custom Bumpers with receivers
Coast Mountain Hightop - Comming Soon
1985 2wd Vanagon Pre-runner in the making
soon to be powered by 2.5L Subaru
Custom Lift
hoipolloi
PostPosted: Fri Feb 25, 2011 5:35 pm    Post subject: Reply with quote
photos?
Photos Please!
GMByers
GMByers is offline
PostPosted: Fri Feb 25, 2011 11:53 pm    Post subject: Reply with quote
"photos"....of what?
If you're looking for pictures of a Vanagon interior without the A/C tunnel, why not just look for some pictures, there are plenty of them here on thesamba.
And then there were two...downsized to 83 Doka &
74 Thing.
hoipolloi
PostPosted: Sat Feb 26, 2011 1:01 am    Post subject: Reply with quote
I could scroll through photos all day and have looked at a lot, I was hoping for a few shots specifically of the interior without the AC Unit, you know, looking back towards the rear or in from the back to see it without the AC. I guess I am not as good at searching with successful results, thought it easier to ask...didn't mean to upset you!
86syncrowesty
86syncrowesty is offline
PostPosted: Sat Feb 26, 2011 11:09 am    Post subject: Reply with quote
What about converting the A/C cabinet to a storage unit? Anyone have ideas on that? Mainly wondering how many holes would be left in the cabinet when the A/C is gone. Or would it be worth it - does the A/C unit provide some structure?
FWIW - Bentley has a good removal how-to.
1986 Vanagon -- Syncro, Westy
2.5L Subaru
irgsmoore4
PostPosted: Sat Feb 26, 2011 2:04 pm    Post subject: Reply with quote
head liner
inside the rear hatch drivers side
inside rear hatch pass side
sorry if the pics arent too good Cool
Ivan
"Needle Noddle Noo"
indytriple
indytriple is offline
PostPosted: Sat Feb 26, 2011 8:15 pm    Post subject: Reply with quote
This is what I did. I REALLY like this storage space. It holds a ton of stuff that is big that doesn't seem to fit anywhere else. It is very useful space in my opinion. I considered taking the cabinet completely out, but I'm very glad that I didn't. The cabinet still supports itself even with the A/C unit out of it except for the right/rear corner. You have to engineer some type of support there. There is a "hole" in the front side where the vents came in and out, but it conveniently allows access to the storage from the rear bench seat.
If anyone out there wants pictures, just put a reply up here, and I will try to oblige you in short order.
"See The Glass As Already Broken."
87 Vanagon Westy Auto Bostig
www.bluegrassbicyclecompany.com
86syncrowesty
PostPosted: Sun Feb 27, 2011 9:45 pm    Post subject: Reply with quote
Did you pull the A/C unit out with the cabinet and then reinstall the cabinet? Or somehow pull out the A/C unit without removing the cabinet? Just wondering, looks like via Bentley you have to pull it all apart.
2.5L Subaru
purplepeopleeater
purplepeopleeater is offline
PostPosted: Sun Feb 27, 2011 9:56 pm    Post subject: Reply with quote
I installed an early westy vent on my late cabinets, no head banging for me.
looks factory too and I keep my a/c!
indytriple
PostPosted: Mon Feb 28, 2011 7:13 am    Post subject: Reply with quote
I pulled the cabinet, removed the A/C, and then replaced the cabinet. That's the only way to do it. It's not that hard, especially when you aren't trying to salvage your A/C. As TK would begrudgingly say, "Rip and Strip!" I can't believe he hasn't commented on this thread. He hates A/C removal threads.
purplepeopleeater
PostPosted: Mon Feb 28, 2011 7:27 am    Post subject: Reply with quote
TK is sleeping and left me head thunder puss...so keep your a/c or i'll beat you with a NOS heater core (not to be confused with the $50 buck jobby)
