JHKahuna Samba Member
Joined: April 25, 2007 Posts: 3 Location: Longmont, CO
Posted: Sat Feb 26, 2011 3:08 pm Post subject: While the body is off... |
I have been looking through the various forums to see if there is a comprehensive list of upgrades to consider making while the body and pan is separated. I am working on a '69 sunroof.
I am thinking of such things as mid trans mount, clutch tube support (where it exits the pan,) tunnel access methods, wire routing conduit in tunnel (for later use,) traction bar mount...
I'm not saying I am going to do all of these things , just trying to flush out options so I work in the features I want before paint is applied.
Pictures would be awesome if you have’m! |
wompninja Samba Member
Joined: July 06, 2008 Posts: 2163 Location: Salt Lake City
Posted: Sat Feb 26, 2011 4:02 pm Post subject: |
I would rebuild, repaint everything and do every seal and bushing you can find. It's a million times easier to do that kind of stuff with the body off. Do new brake tubing as well. If you really want to go crazy put a mendeola front and rear suspension setup on it. _________________ Pics of my 1970 Satin Black Type 1 build |
Greezy Joe Samba Member
Joined: April 12, 2010 Posts: 1534 Location: Crawfordville, Fl
Posted: Sun Feb 27, 2011 7:07 am Post subject: |
Do the works, everything new and update brakes to disc, shocks, front and rear sway bars, all bushings etc. and all new steering components. You won't regret the extra handling performance and braking power. _________________ Current:74 Ghia Coupe w/ 2276
71 Ghia Vert w/ 1835
07 GMC Truck
12 Jeep Wrangler
73 Harley FLH 93 cid
89 Harley 883 Sportster (1200)
Owned before: 58, 69 Ghia Coupes, 64 Canvas Sunroof, 68, 72, 73, & 74 Bugs, 63 Single Cab, 65 Bus, 66 & 70 Camper
" Duct tape can't fix stupid, but it'll muffle the sound". |
