911pickup Samba Member
Joined: March 06, 2004 Posts: 625 Location: Near Goats on the Roof
Posted: Fri Jun 02, 2017 10:14 pm Post subject: Grounding Mallory distributor |
I'm installing a Mallory Unilite distributor, which has a ground wire.
Can anyone give me a good location for the ground wire in the engine compartment? |
mondshine Samba Member
Joined: October 27, 2006 Posts: 2813 Location: The World's Motor Capital
Posted: Sat Jun 03, 2017 4:52 am Post subject: Re: Grounding Mallory distributor |
I used a Unilite distributor on my '71 Super Beetle for years when it was my daily driver from ~2008-2013. The brown ground wire was connected with a ring terminal to the M8 stud that secured the distributor clamp.
At that time, the Unilite modules had a bad reputation for self destruction, or at least over sensitivity to voltage spikes, etc.
I had chosen not to use the Mallory power filter because, if you read their literature carefully, Mallory made no guarantees of its efficacy.
Per the advice of Century Performance (a big Mallory advocate) I had installed an additional ground strap between the engine case and the chassis.
This setup worked reliably for me until I sold that car in 2013.
I should mention that, on the Super Beetle, I was using the Unilite module to trigger a Mallory Hyfire CDI. A CDI makes for a big reduction of the switching current across the Unilite module; possibly giving the module an "easy life".
Good luck, Mondshine |
Posted: Sat Jun 03, 2017 12:28 pm Post subject: Re: Grounding Mallory distributor |
I've heard about the quality issues with the newer Unilite distributors.
Mine is an oldie. I had it installed on my Porsche 356 replica way back in 2004/5. It did go through an engine fire and was rebuilt in 2010. I'm not sure what new parts were used, so I could end up with the module going south.
I'll ground mine to the same place you did. |
Posted: Sat Jun 03, 2017 2:28 pm Post subject: Re: Grounding Mallory distributor |
Well here's another tidbit for your amazement:
I had a couple of 605 module failures when I was using the Mallory distributor in another car.
When I bought my Super Beetle, around 2008, after some trepidation; including considering having Prestolite (parent company of Mallory back then) convert the distributor to single points, I went with the 6100M, the so-called e-spark module which, according to Mallory, was engineered to lower the cost of manufacture to compete with Pertronix type triggers. It is machine assembled (as opposed to hand assembled like the original 605 module). I was amazed that in this century, Prestolite was hand assembling electronic components
Interestingly enough, the e-spark modules (6100M) were yellow, not red which tells me they were the same as the Accel 2005, also a Prestolite product, which is identical form and function to the (Unilite) e-spark... at 80% of the street price.
Anyway, now that Mallory is owned by MSD and not Prestolite...who knows?
Personally, I have been using cast iron Bosch distributors for a few years now, and I'm happy with them.
Posted: Sun Jun 04, 2017 7:44 pm Post subject: Re: Grounding Mallory distributor |
Mond, who would you recommend buying a cast iron Dist. from these days? Considering adding one to the spare box. Won't be able to see you guys this year, had a great time last year, though, and as retirement looms large before me, hope to see you all in the future. Cliff and Janet Waugaman |
Posted: Sun Jun 04, 2017 7:52 pm Post subject: Re: Grounding Mallory distributor |
If you want a cast iron distributor that is thoroughly checked out and ready to run, Glenn Ring is the man.
(Hope the administrator won't delete this shameless plug)
