2000 beetle a/c help
Forum Index -> Water-cooled VW Share: Facebook Twitter
veedubbud
veedubbud is offline
PostPosted: Wed May 04, 2011 6:39 am    Post subject: 2000 beetle a/c help Reply with quote
I have a 2000 vw beetle and the a/c doesnt work. It has freon in it and the cooling fans work but I have no power to the a/c compressor clutch. I've checked the fuses on top the battery for melting and corrosion but they look ok. I know the compressor is controlled by the cooling fan module but the fans work. Also i'm not sure if this is normal but the fans will run for 10 minutes after the car is shut off. Any help is greatly appreciated thanks!!!
Looking for any Bud Clark VW Dearborn MI, license plate frames
73sports
73sports is offline
PostPosted: Wed May 04, 2011 3:47 pm    Post subject: Reply with quote
Just because the fans work, doesn't mean the fan module is okay. It's mounted under the battery, so all sorts of havoc can occur in there. It could also be the pressure switch.
I will never lie, but sometimes the truth changes.
Central Jersey VW Society
Reply to topic    Forum Index -> Water-cooled VW All times are Mountain Standard Time/Pacific Daylight Savings Time
