Reserve fuel tap and engine size / horsepower
teamasr
teamasr is offline
PostPosted: Thu Jan 01, 2015 8:02 pm    Post subject: Reserve fuel tap and engine size / horsepower Reply with quote
Is there a capacity limit with using a fuel reserve tap and the size of engine you can run?
I have 63 bus, which came with a gas gauge, but want to add the reserve tap so that I can easily turn off the fuel when replacing lines and such but wondering about capacity.
Will run a 2017 motor with duel weber's.
glideking
glideking is offline
PostPosted: Thu Jan 01, 2015 8:16 pm    Post subject: Reply with quote
I see no problem running a tap along with a gauge. I think any street engine you build will still flow enough through the tap. Make sure you reset the tap to the long tube after each fill up so if you forget to look at your gauge you still have some reserve.
Kurt
"The more I get done the less it looks like I did anything"
1959 Single Cab Restoration"Funky Truck"
http://www.thesamba.com/vw/forum/viewtopic.php?t=5...highlight=
1965 21 Window Restoration Thread (From old photos)
http://www.thesamba.com/vw/forum/viewtopic.php?t=6...highlight=
1963 Panelvan build "Tyvanosaurus Wrecks"
http://www.thesamba.com/vw/forum/viewtopic.php?p=8351639#8351639
55samba
55samba is offline
PostPosted: Thu Jan 01, 2015 8:32 pm    Post subject: Reply with quote
I ran a 2110 in an Oval, FK8, SE heads, Webber, and a fuel tap, no issues. The only problem I ever had was racing a V8 and my tap cut in during the race! That was embarrassing!
