65tubacarrier Samba Member
Posted: Fri Nov 22, 2024 2:40 pm Post subject: Chip or casting flaw on SP intake port |
I'm trying to get my beetle back on the road after sitting for most of the last 7 years. I took off the intake manifold after punching a hole though the preheat tube trying to clear it (uuugh). Noticed this notch/chip/casting flaw on the right intake port. It was there before removing the gasket. The engine never seemed to have an issue with a vacuum leak in the past so my instinct is to just put it back together.
Should I do anything before reassembling? Would adding some gasket sealant be useful? Fill with JB weld? I'd prefer to not tear this engine apart as it ran well and I have a very limited budget for my "fun" car.
_________________ '65 Beetle |
Brian_e  Samba Member
Joined: July 28, 2009 Posts: 4068 Location: Rapid City, South Dakota
Posted: Fri Nov 22, 2024 3:57 pm Post subject: Re: Chip or casting flaw on SP intake port |
I would not think twice about a tiny careful application of JB weld right there. After it sets up, use a new razor blade to scrape it and surface it flat.
Brian _________________ So more or less the lazier and stupider you want to be, the nicer quality parts you need to buy.
-Modok
Narrowed beams, Drop adjustable spring plates, Bus disk brake and IRS kits.
www.type-emotorsports.com
https://type-emotorsports.com/collections/engine-parts |
Posted: Sat Nov 23, 2024 11:05 am Post subject: Re: Chip or casting flaw on SP intake port |
Excellent, I'll give that a shot. Thanks Brian! _________________ '65 Beetle |
