clutch gone...oil in bell housing.
Rev. Scott
Rev. Scott is offline
PostPosted: Sun Jun 07, 2015 6:34 pm    Post subject: clutch gone...oil in bell housing. Reply with quote
Was going to Kelley Park last month, when a relatively new clutch failed. Pulled the motor today, and there is significant oil in the bell housing, and clutch media on the flywheel, but the clutch seems to be dry...as does the inner flywheel. Help?
"I haven't seen one of those since I was shootin' at 'em!"
GI Joe
GI Joe is offline
PostPosted: Sun Jun 07, 2015 6:51 pm    Post subject: Reply with quote
if it's Engine oil, then There are two plugs in the block back there.... I believe one per half. Just above half way down, at about the 10 o' clock area(if looking at the flywheel end of the block. (I think that makes sense......?)
Pressed in plugs, like "freeze plugs" On a normal water cooled engine.
If it's transaxle fluid, then your input seal is dead....
Replace the plugs, turn the flywheel, and toss a new clutch in!
My £.02!
'74 Thing, "Our Thing"....Blue 181
http://www.thesamba.com/vw/forum/viewtopic.php?t=4...p;start=60
'71 Beetle RPU
http://www.thesamba.com/vw/forum/viewtopic.php?p=8080337#8080337
www.NLEOMF.com
Respect, Honor, Remember
