rebuilt lacks power
iamdonquixote
iamdonquixote is offline
PostPosted: Mon Jun 20, 2011 12:35 pm    Post subject: rebuilt lacks power Reply with quote
I have a rebuilt engine in my 61' bus, engine runs good but seems really doggy on hills.
here are the specs:
61' bus,
* big nut tranny , unknown gearing
Singleport 1600, rebuilt by Bob Donalds (RIP) rebuilt heads, dual relief case (AS) , doghouse oil cooler, alternator, 30/31 and an 009.
jetting is a 130 main I think I started with.
timing on the 009 set to 28 at full advance.
about 400 miles on the engine at this time.
runs smooth, no oil leaks but it just has about the same (lack) of power as the old unknown GEX did up the hills.
Any advice on what to check or double check?
thanks
Erik G
Erik G is offline
PostPosted: Mon Jun 20, 2011 1:17 pm    Post subject: Reply with quote
check compression and leakdown
is your distributor advancing?
what do your spark plugs look like
rusbus
rusbus is offline
PostPosted: Mon Jun 20, 2011 1:34 pm    Post subject: Reply with quote
If it were me, I would start by figuring out the gearing in the trans. You can easily compute the final drive ratio by jacking up one tire, making a chalk mark on the tire, and one on the crank pulley. Count the rotations of the wheel per rotations of the pulley and divide by two (since one wheel is stationary). Maybe you have a freeway flier with really high gearing.
[email protected]
jmp@ncounty.net is offline
PostPosted: Mon Jun 20, 2011 5:43 pm    Post subject: Reply with quote
Did Bob use his special low compression heads?
I know they did not put out the power of stock heads.
He like the lower comp head as he thought the engine ran cooler and lasted longer.
iamdonquixote
PostPosted: Sat Jun 25, 2011 9:59 pm    Post subject: Reply with quote
numbers from the compression test.
I did it with the engine cold because I didn't want galled up plugs.
#1 - 120
#2 - 120
#3 - 105
#4 - 130
a little bit of a bummer there, I wonder if I overheated it.
plugs looked normal though.
more diagnostics needed I guess
krusher
krusher is offline
PostPosted: Sun Jun 26, 2011 12:00 am    Post subject: Reply with quote
Have you tried total advance of 30 and 32 as a test, and what gas grade are you using?
(06:31:07) RoachGhia: "i drink dick way too fast"
quartermilecamel
quartermilecamel is offline
PostPosted: Sun Jun 26, 2011 1:31 am    Post subject: Reply with quote
105 on #3....valve adjustment?
Waiting for santa to drop off funky green. I can wish can't I????
TinCanFab
TinCanFab is offline
PostPosted: Sun Jun 26, 2011 3:00 pm    Post subject: Reply with quote
I would double check your valve adjust for sure! A couple hundred miles after the break in.......everythings expanding and contracting for the the first time as a fresh unit
iamdonquixote
PostPosted: Sun Jun 26, 2011 4:19 pm    Post subject: Reply with quote
that was after valve adjustment!
but I will double check it.
yes, I did try 30-32. In fact, I think that is where I was.
krusher
krusher is offline
PostPosted: Sun Jun 26, 2011 11:48 pm    Post subject: Reply with quote
So you tried 30 and 32 were either any better, and i also asked what grade fuel your using.
iamdonquixote
PostPosted: Mon Jun 27, 2011 7:31 am    Post subject: Reply with quote
no, advanced timing didn't seem to help.
using 93 octane but its the %10 ethanol stuff since thats all you can get in Massachusetts.
2Pack
2Pack is offline
PostPosted: Mon Jun 27, 2011 3:03 pm    Post subject: Reply with quote
Just throwing out some other ideas:
- Choke not opening fully due to incorrect adjustment.
- Throttle not open fully (or close) when gas pedal is at floor.
- Power fuel system in carb is clogged or restricted.
- Brakes dragging slightly.
And the worst one:
- Nothing is wrong with the engine.
Please buy my Treasure
krusher
krusher is offline
PostPosted: Tue Jun 28, 2011 12:55 am    Post subject: Reply with quote
A higher octane is harder to ignite so needs more advance. I run 87 in my bus with no pinging or high head temps and 32 degrees advance.
I tried a tank of 89 on a road trip and lost 2mpg.
As an experiment next time your empty try 2 gallons of 87 and some more advance. Also check your plugs, are they black are you running rich?
93 and lack of advance = hot engine.
Stanagon
Stanagon is offline
PostPosted: Tue Jun 28, 2011 7:29 pm    Post subject: Reply with quote
I have a similar set-up, but small nut boxes in my '61. Boston Bob 1600cc single port with 6v generator, single advance dist. (chinese made) and a Solex 30pict 1 carb. The engine is well broken in now, but always seemed to suck wind going up big highway hills. This Spring I changed from a 125 to 135 main jet and it REALLY helped a lot. Now I'm cruising along with plenty of power, for the most part.
Might want to bump that main jet up a bit if it's a 130.
Stan's Classic Service, specializing in air-cooled VWs:
http://www.thesamba.com/vw/classifieds/detail.php?id=614073
www.stanagon.com
My '61 Mango bus thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=110367
My '64 vert thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=386344
My '71 squareback thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=637709
