Rocker Shims
cgflightmech
cgflightmech is offline
PostPosted: Sun May 29, 2011 11:52 pm    Post subject: Rocker Shims Reply with quote
I am making some upgrades to my motor. Its a pretty basic DP 1641, dual 34's, 003 distributor, single quiet pack. I am installing CB Performance 1.25 rockers, and swivel feet adjusters. The swivel feet don't allow enough room to set some lash in the valves. Is it normal to shim the rocker blocks to get a proper valve gap. Any advice would be welcome. Thanks...
(0\_!_/0)
Sean W. Crowley
91-1039 Laaulu St. #23B
Ewa Beach, HI, 96706
808-292-9952
jfats808
jfats808 is offline
PostPosted: Mon May 30, 2011 12:01 am    Post subject: Reply with quote
You need to set up your valve train geometry and get either precut or cut to fit pushrods. In your case it would be ok with HD aluminums. You dont have room cause your stock length pushrods are to long.
2276 IDA's 86C 11-1 DD
Rockstar Suzuki wrote:
You might as well put 10 year build in your bullshit sig, as it will NEVER run. Also your a dick
You can always learn something new, even from a fool.
Check your oil levels routinely!
GDOG57
GDOG57 is offline
PostPosted: Mon May 30, 2011 12:41 am    Post subject: Reply with quote
When you run swivel feet they are longer,so you have to shim up the rocker shaft or cut push rods to length. Usually CB's swivel feet come with shims.
'57 oval window deluxe,Agave green(L240) 2276cc w/51.5 IDA's
'57 type 2 panel ( L31 dove blue) project daily driver,Singleport 1955cc
'69 Squareback (L30A Royal Red)
modok
modok is offline
PostPosted: Mon May 30, 2011 12:43 am    Post subject: Reply with quote
If these are the porsche style, the "foot" ones, then it is usual to grind the rocker back about .060" at least and also use about .060 shims under the rockers. That is usual for mid .400"s valve lift
The shims usually come with the kit.
vgajames
vgajames is offline
PostPosted: Mon May 30, 2011 5:03 am    Post subject: Reply with quote
this... Wink
mark tucker
mark tucker is offline
PostPosted: Mon May 30, 2011 8:43 am    Post subject: Reply with quote
or remachine the end of the rocker where the foot contacts it,I have never seen any new ones that were even on the end.you probably need shorter pushrods too. and dont forget to check the oil gally hole&slot for proper oiling, it may need some help.Ive seen those varry 3-4 threads also.
