Starting to collect parts for a class 11 build questions
barrelroll
barrelroll is offline
PostPosted: Sun Nov 19, 2017 8:52 am    Post subject: Starting to collect parts for a class 11 build questions Reply with quote
I tired posting on class 11 coalition but there's not much traffic on there any more and I know there's a bunch of knowledge here.
I've been involved with chasing and prepping for 10 years, just never anything VW based. I'm getting ready to pull the trigger on a class 11 build and am going to start with picking up a couple lots of parts, getting parts prepped, and then pulling the trigger on a solid car missing a motor/ in project status once everything is ready to go in. The long term plan is to race the 1,000 once the car is dialed in, this isn't a "bucket list" build but more of a long term build a race program.
One of the lots has a 1600 dual port and the other is a '65, '69, '76, parts cars and a '71 pan. Both lots come with a ton of parts.I've seen how spares are huge in desert racing and we DNFed the 1,000 last year because our spare trailing arm was 6 hours away on the other side of the peninsula. My plan is to use the best parts of the lot to build the race car, acquire a bunch of spare parts, and sell what doesn't belong on a race car.
With the lot of parts I should have 3 Ball joint beams, 2 IRS transaxles, a complete 1600 dual port, a pile of sheet metal, a bunch of extra motor parts, and then a bunch of stuff that has no business being on an off road car like glass and interior parts.
I've Started to make lists of parts as far as what to keep and what to sell. Please give me some direction if this is the right stuff to keep
Here's my list of stuff I plan on keeping everything of
-Brake Drums & wheel bearings
-Spindles
-Front Trailing Arms
-Steering Boxes
-Tie Rods
-Front beam Springs
-Rear Trailing Arms
-Solex 30 Carburetors
-Starters
-Alternators/ generators
-Distributors/ plug wires/ coils
-Pullies/ belts
-Rubber Brake Lines
-Master Cylinders
-Wheel Cylinders
-Clutches
-Clutch Cables
-Throttle Cables
-Transaxles
-Hardware
-4 Lug wheels
Stuff I think I only need 1 extra of in addition of 1 of everything for the race car
-Doors
-Fenders
-Hood/ deck lid
-Tail Lights
-Bumpers
-Roof
-Steering Column
-Beam
-Parts to build a spare motor
Stuff I'm not sure if I should keep/ how much I should keep
-Stock Torsion Bars
-Spring Plates
-Fly Wheels
-Shifter/ Clutch Linkage parts
-Engine Tin/ Fans
-Wiring Harnesses
-Switches
-Exhaust parts
-Intake parts
-Type 1 CV's/ axles shafts/ stub axles
-Brake backing plates/ shoes/ brake hardware
Parts I plan on selling
-Glass
-Seats/ Door Panels/ Interior Parts
-Wiper parts
-Dash Parts
-Trim
-'65 Pan/ link pin beam/ transaxle
-Heater Parts
-Everything 6 volt
-Gas Tanks
-Multiples of stuff on the only keeping 1 list
What am I missing that I should be keeping?
What have you thrown out or sold and regret getting rid of?
Thanks a ton, once everything gets home I'll get a build thread started.
petrol punk
petrol punk is offline
PostPosted: Sun Nov 19, 2017 9:16 am    Post subject: Re: Starting to collect parts for a class 11 build questions Reply with quote
I don't have much to add, other than you can keep the T1 CV axles, machine the flange off, turn new 4130/4140/4340 flanges, and weld them on to have a T2 conversion stub axle. That's what I've been doing with my old T1 stubs.
36hp '56 European DeLuxe oval
'70 bug 1835cc
oldschool5er
oldschool5er is offline
PostPosted: Sun Nov 19, 2017 7:51 pm    Post subject: Re: Starting to collect parts for a class 11 build questions Reply with quote
Rules state you can now use disc brakes so lightweight quality disc brakes are better than drum for racing.
-Spindles
You should keep these even though you will probably replace them with modified stock, but these will be good as cores.
Keep
-Steering Boxes
Keep, even though there is some ongoing debate about allowing rack and pinion to stay in the rules.
-Tie Rods
Keep
-Front beam Springs
Keep even though you might be using sway a way or the like.
-Rear Trailing Arms
Keep, as you will be modding those or using them as cores.
Keep, unless you are going the low compression option and using a single two barrel.
-Starters
You are probably going to be using a SR17x or a high torque, but you might want to keep them for swap meets.
Keep the Alternators for cores.
Swap meet material.
-Pullies/ belts
Swap meet.
-Rubber Brake Lines
Trash.
-Master Cylinders
Trash.
-Wheel Cylinders
Swap meet, if you are going to Disc setup.
-Clutches
Swap meet.
-Clutch Cables
Trash.
-Throttle Cables
Trash.
-Transaxles
Keep.
-Hardware
Keep.
-4 Lug wheels
Keep.
-Doors
Keep all that match or work for the year body you plan on running.
-Fenders
Keep all that match for year of body you plan on running.
-Hood/ deck lid
Keep all that match your year of body you are running.
-Tail Lights
-Bumpers
-Roof
If you are going to need a roof then more than likely you are going to need ¼ panels, pillars, on and on also. Maybe just easier to find another body if you roll it.
-Steering Column
Rules allow you to make one now but you might want to save hub spline.
-Beam
Keep.
Keep what is rebuildable or used as cores.
-Stock Torsion Bars
Swap meet.
-Spring Plates
Keep for use in mock ups or pattern making.
-Fly Wheels
Keep
Keep
-Engine Tin/ Fans
Keep
-Wiring Harnesses
Keep
-Switches
Swap meet.
-Exhaust parts
Swap meet.
-Intake parts
Keep all dual port.
Swap meet as you will be buying high quality billet from race suppliers same with CV’s.
None of that needed if you go to disc.
-Glass
-Wiper parts
-Dash Parts
-Trim
-Heater Parts
-Everything 6 volt
-Gas Tanks
L5wolvesf
L5wolvesf is offline
PostPosted: Mon Nov 20, 2017 1:08 pm    Post subject: Re: Starting to collect parts for a class 11 build questions Reply with quote
I essentially had access to a lot of parts similar to what you've described. While we didn't use all of them we did some trading for other things we needed. Also, having spares is always a good thing in any race program. It would have been difficult and more costly if we did not have what we got.
Where are you planning to run before Baja?
Good luck.
Amonster Motorsports
SNORE # 1196 sponsored by:
- www.356carburetorrescue.com/home.html
- Barnwerks Fabrication & Welding
- ArtSpeed Graphics
“Racing's important to men who do it well. When you're racing, it's life. Anything that happens before or after is just waiting.”
S. McQueen
barrelroll
PostPosted: Mon Nov 20, 2017 1:50 pm    Post subject: Re: Starting to collect parts for a class 11 build questions Reply with quote
The rule changes like discs, upgraded spindles, steering column is only in SCORE as of now and I'd like to build a car that's legal everywhere.
Good luck.
I've seen first hand how having multiple spares in a point to point race can make or break a race. I figure having "junk" stock parts like clutch or starter in as many chase trucks is better than having nothing.
YORR and BORE races are the closest through SNORE really isn't much farther and has a much better turnout.
I dragged the first lot of parts home last night that had a most of a motor and a bunch of random parts in it. I filled up a long bed truck and there's another load tonight. A lot of it has no use for a class 11 but it should be good trading fodder. The guy had a VW shop at one point and was sick of moving the junk, I wish some of it wasn't out in the rain, luckily the motor stayed in side. Some of it's used parts, some of it's new, and some of it is all ready in the dumpster. Unfortunately it's a fuel injected block so it won't work for an 11. There were 2 30 pict 1 carbs and 1 or 2 sets of dual part heads, 2 1600 cranks, 7 rods (hopefully the 8th is in tonight's load), some 4 lug wheels and that's just the beginning of what I had time to sort through.
overdrive
overdrive is offline
PostPosted: Mon Nov 20, 2017 11:09 pm    Post subject: Re: Starting to collect parts for a class 11 build questions Reply with quote
Do your self a fave and just buy a used 1-2 1600 they can be had for 10-12 K, You spend close to that for a 11 car from scratch.
And you will be running a car that other racers don't hate. Smile
barrelroll
PostPosted: Tue Nov 21, 2017 4:42 pm    Post subject: Re: Starting to collect parts for a class 11 build questions Reply with quote
The golf cart team I'm crew chief for bought a "high end" but "older" (2 or so seasons old) used car and I'm over dealing with someone else's hand me down. He has a new car on order because of the used car headaches. I realize coming comparing a utv to an 11 or 16 is kinda apples to oranges but still I'd rather build a car. I'm pretty sure a 10k 1600 will be an out dated clapped out car needing a full prep with some issues and no where close to competitive. I realize building a car is around double what I could buy a used car for.
Building the car will give me a much better understanding of how the thing works/ how to work on it in a pinch. I'll know what I'm getting/ how many race miles are on everything. Starting out with a couple parts hoards has given me a pile of spare parts. Selling the parts that don't fit/ belong on an 11 should help replenish the piggy bank and make some local VW connections.
Haha. I was pretty close to pulling the trigger on a class 3 when the old lady vetoed the class 3 and said build a class 11. Considering last year at the 1000 she was the only chick on a team of 12 and was a better asset to the team than some of the guys I'll listen to what she says. I've always wanted an 11 since I saw dust to glory in college living back in the Midwest. Now I'm at the point in my life where I think I can pull it off finically and I've been around desert racing long enough to hopefully avoid some mistakes and seen what's really involved in racing. Maybe we are just special but we enjoy a good challenge and the nightmare of logistics involved in trying to get a class 11 to the finish line.
MI-Bug
MI-Bug is offline
PostPosted: Tue Nov 21, 2017 8:41 pm    Post subject: Re: Starting to collect parts for a class 11 build questions Reply with quote
Looks like you are local to the projectbaja.com guys. You may want to pick their brains once they get back in town. Smile
overdrive
PostPosted: Wed Nov 22, 2017 12:38 am    Post subject: Re: Starting to collect parts for a class 11 build questions Reply with quote
So spend 15K and prep it. You will have a real race car.
LOL so you know the haters from running the golf carts Wink
oldschool5er
PostPosted: Wed Nov 22, 2017 6:04 am    Post subject: Re: Starting to collect parts for a class 11 build questions Reply with quote
This ^
L5wolvesf
PostPosted: Thu Nov 23, 2017 8:25 am    Post subject: Re: Starting to collect parts for a class 11 build questions Reply with quote
FWIW, we bought a car that had run Baja several times and survived. We took it apart (left the body on the chassis) and went through it completely. We improved some things and repaired some things.
Like you said by doing that we knew every part and every nut and bolt – it was well worth it.
The car was essentially flawless – except we forgot to check the windshield wipers. We finished 7th out of 19 and if we didn’t get a flat just before the end of the first day we would have been 4th.
We used the stock tank for short courses (Laughlin and Primm) the extra fuel capacity of a large rear tank and the weight weren’t needed and the front tank gave us a better weight distribution.
Far as people hating Class 11s goes – that is their problem.
Love this attitude -
- ArtSpeed Graphics
S. McQueen
