Poorjimmy5 Samba Member
Joined: July 11, 2016 Posts: 73 Location: Long Island, New York
Posted: Mon Mar 18, 2019 11:26 am Post subject: Where should this wire from fuse 9 go? |
While troubleshooting the speedometer, I found a wire in the dashboard that was unattached on one end. It comes out from the 9th fuse slot and leads nowhere and has no connector on the end. It is a single red wire and doesn't appear to be the one that splits immediately after leaving the connector into two different gauge wires, both of those are also red. (See just above the number "9" in the picture above.
kenj06 Samba Member
Posted: Mon Mar 18, 2019 6:00 pm Post subject: Re: Wher should this wire from fuse 9 go? |
| Do you have a gas heater? Guessing it used to go there. If it isn't going anywhere, I'd remove it so you don't have a live wire just hanging out there. |
Posted: Mon Mar 18, 2019 7:24 pm Post subject: Re: Where should this wire from fuse 9 go? |
Thanks, but I don't think so. If you look at the top picture (which admittedly might be a bit confusing) you'll see just behind the number 9 is a connector that has two red wires running from it. I assume the thicker gauge one goes to the Heater and the thinner gauge one goes to the Socket Assy as specified in the diagram attached to the bottom of the initial post. It is the third red wire on a separate connector that is leaving the same fuse (9) on the same side of the fuse box that I'm trying to figure out?
I initially was hoping it was the cause of my fuel gauge and some of my speedometer lights not working not working. God this electrical stuff befuddles my small ape-like brain! |
kenj06 Samba Member
Posted: Mon Mar 18, 2019 8:06 pm Post subject: Re: Where should this wire from fuse 9 go? |
OK, next guess, used to go to accessory socket. The small red wire goes to terminal 30 of the heater switch, the thicker to terminal of the heater relay.
on the diagram at the link below, find the fuse panel S. you'll see two red wires come off of it and go to the heater and switch. There is a black/white wire in the diagram going to U, accessory socket.
Those are the only 3 wires on that side of fuse 9.
https://www.thesamba.com/vw/archives/info/wiring/181_Wiring_Diagram_4-73.pdf
If you have the accessory socket, trace where the wire from there goes. Someone may have rewired it elsewhere.
Hopefully the battery is disconnected messing around in there. Easy to short something out with all the spaghetti. |
Bashr52 Samba Member
Joined: July 16, 2006 Posts: 5669 Location: On an island in VA
Posted: Tue Mar 19, 2019 4:52 am Post subject: Re: Where should this wire from fuse 9 go? |
Are you sure that is the #9 position that is empty? According to that diagram you posted #9 is only used on gas heater cars.... Unless there are 2 terminals on #9, and the existing heater wires are plugged in there.
Does your heater work? |
Dougster43 Samba Member
Joined: May 11, 2018 Posts: 189 Location: South Carolina
Posted: Tue Mar 19, 2019 12:06 pm Post subject: Re: Where should this wire from fuse 9 go? |
Is this on a 73 or 74?
I can double check mine tonight, but on a 73, fuses 9 and 10 are tied together on the input side, and there is one red wire with a white stripe that goes to terminal 30 on your headlight switch, and a solid red wire that goes to terminal 30 on the ignition switch.
On the output side of fuse 9 there are two red wires. One goes to the relay on the gas heater and the other to the heater switch.
If yours is a 73 and I am seeing the picture correctly, it looks like the additional wire is coming off of the input side of the fuse block. My guess is that it is a wire that someone added somewhere along the line or it belongs somewhere else. How long is the wire and is it hooked to anything now? |
Posted: Wed Mar 20, 2019 6:22 am Post subject: Re: Where should this wire from fuse 9 go? |
I looked last night and I do not have this wire on my 73.
There is also a white wire with a black stripe on the output side of the fuse 9 that goes to the accessory plug. The two red wires that are for the heater are both coming out of a single spade connector on the output side. There are only the two wires I described in the last post on the input side. |
Posted: Wed Mar 20, 2019 10:54 am Post subject: Re: Where should this wire from fuse 9 go? |
| Dougster43 wrote: |
Yes it is a 1973 (BN4 heater & only intake louvers in the rear sides). Assuming the output side of the fuses are up when the dashboard panel is open and towards the front when it's closed, then yes I have the "The two red wires that are for the heater are both coming out of a single spade connector on the output side" as I show in the picture, however I DO NOT have the white wire with a black strip, instead I have this red wire (a third one) coming from the output side of fuse 9 and it is currently attached to nothing, as I said and want to find out. Last year when I used the accessory port (I assume we mean the little outlet with the rubber cover on the right side of the dashboard that you can plug in say a BMW motorcycle phone charger?) it worked, but I will check again today and get back to you, thanks! |
Posted: Wed Mar 20, 2019 11:37 am Post subject: Re: Where should this wire from fuse 9 go? |
| kenj06 wrote: |
I do not have the black/white wire from the output side of Fuse 9, but instead this unconnected (third) red wire, with a separate connector different from the other two red wires for the heater that have their own single connector. I will investigate what I believe to be the accessory outlet later today to see if it still works and let you know. Thanks brother! |
Posted: Wed Mar 20, 2019 11:43 am Post subject: Re: Where should this wire from fuse 9 go? |
| Bashr52 wrote: |
My apologies if I didn't explain myself clearly, but the output side of Fuse 9 is NOT empty. I believe the heater has two red wires of different gauges attached to one connector there as well as a third red wire attached to a separate connector on the output side of fuse 9 which in my case leads nowhere and doesn't have a spade connector on the end of it. Now the diagram above show a black/white wire from the output side of fuse 9 which is not present on my Thing. I will check to see if the accessory port works and will get back to you.
Oh and by the way, my heater doesn't work. |
Posted: Wed Mar 20, 2019 11:47 am Post subject: Re: Where should this wire from fuse 9 go? |
| Dougster43 wrote: |
It is a 1973, made in Mexico. The mystery red wire that currently leads nowhere is about 18" long give or take and comes off the output side of Fuse 9. I do not have the black/white wire as shown in the diagram above. |
Posted: Wed Mar 20, 2019 1:10 pm Post subject: Re: Where should this wire from fuse 9 go? |
OK, BIG CORRECTION!
Upon further investigation, the black/white wire IS present from the output side of Fuse 9 to the Accessory Plug. Evidently it was hidden behind the Heater "Egg Timer", but now this means 4 wires are attached to the output side of Fuse 9. Perhaps I should just remove this wire all together if no one can tell me what it was for and it doesn't appear on any electrical diagram.
ALSO! The mystery wire is much shorted than the 18" I quoted above. It is less then 12", maybe even just 10".
Oh and one other thing...I can now see the wisdom of disconnecting the battery. While I was moving this wire back into the dashboard, the exposed end accidently slipped into the slot between the steering wheel and the steering wheel shaft and entertained me with a little noisy spark show. Check to see if the car started after and it did so I got that going for me. But the horn still doesn't work. |
Posted: Fri Mar 22, 2019 6:38 am Post subject: Re: Where should this wire from fuse 9 go? |
| So like I said, I guess I should just remove the wire then huh? Does that seem to be the general consensus of this learned body? |
Posted: Fri Mar 22, 2019 11:21 am Post subject: Re: Where should this wire from fuse 9 go? |
Sounds like it to me. It is either in the wrong spot or was an addition somewhere along the line. Since it doesn't go anywhere I would probably remove it. There were only 2 solid red wires that should have been connected to the output of the fuse block - these are the ones that combine into one connector on fuse 9 and go to the heater and heater switch.
Regarding your fuel gauge and lights on the speedometer - there should be a smaller black wire that runs from the input side of fuse #1 to the speedometer (I think it connects on the back left side somewhere?). This wire provides power to the fuel gauge vibrator (and gauge), and some of the lights which I think includes the generator warning light, oil pressure warning light, and the turn signal indicator lamp. If that wire is not present those probably wouldn't work. |
Captain Spalding Samba Member
Joined: February 19, 2005 Posts: 2519 Location: . . . in denial.
Posted: Fri Mar 22, 2019 12:33 pm Post subject: Re: Where should this wire from fuse 9 go? |
| Before you remove the wire, confirm that everything works as it should. (I understand that the heater doesn't work.) |
Posted: Sat Mar 30, 2019 7:42 pm Post subject: Re: Where should this wire from fuse 9 go? |
| Good idea! I will just tape up the end of it for the time being. |
