lowdowndub Samba Member
Posted: Wed Jun 22, 2011 12:42 pm Post subject: Removing Rear Reflectors |
I just scored a set of rear reflector seals and would like to replace the crack crappy ones I have but I'm not sure how to remove the reflector and perch to replace them.
Any help? |
Posted: Wed Jun 22, 2011 12:43 pm Post subject: |
I think I found it.
Do I need to remove the tail light housing to get at the bolt/nut? |
chaosisme Samba Member
Joined: August 29, 2005 Posts: 1164 Location: Orange County, Ca
Posted: Wed Jun 22, 2011 12:50 pm Post subject: |
Yes.
If your old ones are still serviceable, then you might want to hit the old reflector nut/bolt with some penetrating oil or something. They always seem to be rusted up pretty good. I just replaced one on my square and I thought I was turning the nut and I ended up snapping it off. _________________ '65 1500 S [quareback]
'68 FI Sunroof Squareback
'70 Westy
OCT3 - Orange County Type 3's |
68notch Samba Member
Joined: August 16, 2007 Posts: 544 Location: Perth, Western Australia.
Posted: Wed Jun 22, 2011 10:34 pm Post subject: |
I've snapped one of those refector studs too when try to pull one from an old panel with using any oil.
I found one of those flexi shaft (wire like) extensions and socket works perfect to reach through the rear tail light hole and around 180 degrees. _________________ John
68 Aussie notch
2011 Citroen Berlingo
https://www.facebook.com/Fastacraft
RHD dash pad project http://www.thesamba.com/vw/forum/viewtopic.php?t=475227 |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 18050 Location: Eugene, OR
Posted: Thu Jun 23, 2011 9:11 am Post subject: |
I've gotten them out/in with my 1/4" drive. A flex-shaft sounds like a good addition to the setup. _________________ 69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
OhHerrooo Samba Member
Joined: September 12, 2010 Posts: 1291 Location: Costa Mesa, CA
Posted: Thu Jun 23, 2011 11:09 am Post subject: |
I just use a 1/4 driver with a deep socket and that works fine, plenty of room. _________________ '65 1500 S [quareback]
'70 Westy
