GTV Samba Member
Posted: Fri Jun 24, 2011 8:50 am Post subject: Breather Oil Filler Cap? |
I'm looking for an oil filler cap that allows the engine to breathe, and fits on the stock VW oil filler. I see ones for V8's at every parts place, but nothing that fits the VW. Anyone?? _________________ EMPI Power Rules! |
torsionbar Samba Member
Posted: Fri Jun 24, 2011 9:19 am Post subject: Re: Breather Oil Filler Cap? |
MR COSMIC wrote: |
I'm looking for an oil filler cap that allows the engine to breathe, and fits on the stock VW oil filler. I see ones for V8's at every parts place, but nothing that fits the VW. Anyone?? |
huh? the factory vw oil filler already has a breather tube. depending on year, it either vents downward into the air stream under the car, or it vents upward through a hose and into the air cleaner.
post a photo of your engine here. i'm guessing you probably have parts missing, or have some crappy aftermarket filler w/o a breather? |
GTV Samba Member
Posted: Fri Jun 24, 2011 2:01 pm Post subject: |
Not exactly, it's a new build.
I'm venting the 1-2 valve cover to the breather fitting on the stock oil filler, and I'm using the filler that doesn't have the draft tube because I don't like them (designed to leak, designed to fail, IMO). Plus the engine just looks simpler/cleaner without it.
I can't vent to my aircleaners because I wont be running any  _________________ EMPI Power Rules! |
rays-64 Samba Member
Joined: April 02, 2010 Posts: 343 Location: corona, CA
Posted: Fri Jun 24, 2011 3:20 pm Post subject: |
forgot to add, that you would have to run breather box with this and your set-up |
GTV Samba Member
Posted: Fri Jun 24, 2011 3:41 pm Post subject: |
Thanks for the link, but I'd like to retain the stock filler/breather since this is a period correct sort of build. Billet parts are also out. _________________ EMPI Power Rules! |
slalombuggy Samba Member
Posted: Fri Jun 24, 2011 4:08 pm Post subject: |
I just spent the afternoon working on a 57 Fairlane Skyliner. the oil cap was a chromed, dome style breather cap with two spring clips sticking out the bottom to hold it into the valve cover. You might find something like that to use.
brad |
GTV Samba Member
Posted: Fri Jun 24, 2011 4:23 pm Post subject: |
slalombuggy wrote: |
brad |
Those are very common, and would be perfect for my application but unfortunately they do not fit the VW filler. _________________ EMPI Power Rules! |
jsturtlebuggy Samba Member
Joined: August 24, 2005 Posts: 4607 Location: Fair Oaks/Orangevale, CA
Posted: Fri Jun 24, 2011 6:00 pm Post subject: |
SCAT shows two types in it catalog.
Dome one#80084
Flat top style #80330 _________________ Joseph
Elrod Motorsports
Motion Tire Motorsports
Into Volkswagens since 1960 |
TURBOEDVW Samba Member
GTV Samba Member
Posted: Sat Jun 25, 2011 9:02 am Post subject: |
jsturtlebuggy wrote: |
Dome one#80084
Flat top style #80330 |
I saw that and called Scat about a month ago, the guy said they hadn't had those caps in months, maybe years. I did pick up a NOS "chrome dome" cap here on the samba a few weeks ago, but unfortunately it's sealed.
Does anyone know if a breather style cap was ever made as a replacement for the stock cap? _________________ EMPI Power Rules!
GTV Samba Member
Posted: Sat Jun 25, 2011 9:03 am Post subject: |
Thanks for the link, but no, that replaces the oil filler as well. I want to retain the stock oil filler, just replace the cap. _________________ EMPI Power Rules! |
chrisflstf Samba Member
Joined: February 10, 2004 Posts: 4093 Location: San Diego
Posted: Sat Jun 25, 2011 9:13 am Post subject: |
Berg sells breather boxes with a breather cap. I believe the cap fits the stock oil filler. give them a call |
GTV Samba Member
Posted: Sat Jun 25, 2011 9:38 am Post subject: |
chrisflstf wrote: |
I already did. Berg offers breathers that use the stock cap, and the domestic style breather cap. _________________ EMPI Power Rules! |
Randy in Maine Samba Member
Posted: Sat Jun 25, 2011 10:53 am Post subject: |
Why not just make one? |
GTV Samba Member
Posted: Sun Jun 26, 2011 7:52 am Post subject: |
Randy in Maine wrote: |
Ok, any ideas on how to go about that? _________________ EMPI Power Rules! |
Posted: Sun Jun 26, 2011 8:04 am Post subject: |
I would just buy one for a V8 and make it so that it would fit a VW.
But that is just me. |
GTV Samba Member
Posted: Sun Jun 26, 2011 7:06 pm Post subject: |
That has crossed my mind... I'll pick one up this week and give it a shot... at least they're cheap.
I'll let you know how it goes... _________________ EMPI Power Rules! |
Cusser Samba Member
Joined: October 02, 2006 Posts: 33146 Location: Hot Arizona
Posted: Thu Jul 10, 2025 6:24 am Post subject: Re: Breather Oil Filler Cap? |
I run a press-on breather cap (came with the oil fill extender) I bought in the 1970s on my 1835cc engine. I cannot remember the source.
_________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
