DIY cylinder head temp sensor plug
Bikerchris
Bikerchris is offline
PostPosted: Fri Apr 20, 2012 4:36 pm    Post subject: DIY cylinder head temp sensor plug Reply with quote
If I have a VDO cylinder head temperature sensor gauge and all the wiring except the end piece with the plastic plug and ring for the spark plug can I make one? I already have a compatible plug. Does it require special wires for the heat? How do the 2 wires connect to the ring for the spark plug? Thanks.
donmurray
donmurray is offline
PostPosted: Fri Apr 20, 2012 5:24 pm    Post subject: Reply with quote
The thermocouple is made of two wires tightly crimped together. The 2 wires are of different metal types, and I suspect must be very specific types. The 2 metals create a very small current when exposed to heat.
Some threads on CHT sendors:
http://www.thesamba.com/vw/forum/viewtopic.php?t=2...mp;start=0
http://www.thesamba.com/vw/forum/viewtopic.php?t=313506&highlight=omega+connector
http://www.thesamba.com/vw/forum/viewtopic.php?t=395575&highlight=cht+dakota+wire
http://www.thesamba.com/vw/forum/viewtopic.php?t=395989&postdays=0&postorder=asc&start=0
Bikerchris
PostPosted: Fri Apr 20, 2012 7:07 pm    Post subject: Reply with quote
Ahh... they are different metal types. Thank you. I'll just order a sender for $20 and be done with it.
JustBuggy
JustBuggy is offline
PostPosted: Sun Apr 22, 2012 2:52 am    Post subject: Reply with quote
Has anyone modified the sending unit and mounted it on a bolt istead of under a spark plug?
It just seems like a hoaky way to do this as the act of moving the wires while changing plugs, it would seem that eventually the wire will crystalize and break. Anyone?
donmurray
PostPosted: Sun Apr 22, 2012 6:26 am    Post subject: Reply with quote
I cut off just the loop part. Ground a shallow grove close to the spark plug. Secured the crimped part of the sensor in the grove with JB Weld. While the JB set, the crimp was forced tight in the grove by a weight. Seems to read about the same as under the plug. Compared to a head bolt, I thought that location would give a better/quicker sensing of the combustion chamber temp. The temp of the head metal close to the plug should be about the same, but an under-the-plug sensor is getting some high heat from the plug tip that is conducted to the head via the plug body. Thinking about it, the plug tip may be hotter than the head material. What do you really want to measure?
The loop on the plug is just a bad idea when you can't see what's going on as the plug is removed & replaced. I was careful, but still had trouble with the loop on the plug setup. Had to fish the loop around using a mirror and hook.
JustBuggy
PostPosted: Sun Apr 22, 2012 7:07 am    Post subject: Reply with quote
donmurray wrote:
......The loop on the plug is just a bad idea when you can't see what's going on as the plug is removed & replaced. I was careful, but still had trouble with the loop on the plug setup. Had to fish the loop around using a mirror and hook.
That was what I was thinking. I just installed Cyl. head temp gauge and the new engine will be going in within the next couple of months. I'd like to get this small part finallized before engine installation.
If need be I can TIG weld a small raised boss very close to the plug and drill and tap for this purpose.
kadub
kadub is offline
PostPosted: Sun Apr 22, 2012 7:35 am    Post subject: Reply with quote
The problem with mounting the TC sensor anywhere other than under the spark plug is that the temp reading will be different than 90% of the people out there who post temp readings for you to compare to. Under the plug is the "standard" when it comes to head temps. You want to know how hot the heads are getting near the valve seats. If the sensor is mounted anywhere else, it's likely to get a cooler reading that reacts slower to changes, etc. Unless you mount it closer to an exhaust port, but that reading will be more exhaust temp related than combustion chamber temp Wink .
The ring terminals are cheap and easy to replace if they get damaged.
